Debug Watch does not show all of an array
Results 1 to 4 of 4
    May 2011
    Default Debug Watch does not show all of an array
    I am hoping someone here will know about this. Microchips forum has not helped.
    I am using MPLAB 8.63, PicBasic Pro 2.60C, 18F2525 and PicKit3 for debugging.
    I am reading GPS - GPGSV sentence data into an array: GPGSV var byte[90]. Then parse the data using the arrayread command.
    I am seeing some unexpected data in my parsed data and would like to see the original array to determine where it is coming from.
    When I try to Watch the GPGSV array in debug I only get 1 byte for data. I have tried changing the Watch to GPGSV[some index] but that gives an error.
    What can I do to see the whole array???
    Default Re: Debug Watch does not show all of an array
    Easiest way I know is to add absolute watches.
    assuming this snip
            MyArray     VAR BYTE [20]
            CounterA VAR BYTE
    START:
            FOR CounterA = 0 TO 20
                    MyArray[CounterA] = 20-CounterA
                    NEXT
                    MyArray[CounterA] = CounterA
                    NEXT
            GOTO START
    In watch window, If I add _MyArray, it's address is set to 0x01D. That's MyArray[0]... period. If I want to watch the whole thing, what I'll do is to add Absolute addresses watches.
    Easy step-by step:
    1. in watch windows right click ...somewhere then select add
    2. At the bottom of the window, you'll have 2 fields... start address & end address. I set start address with 0x01D (begining of MyArray), and end address with 0x031...
    3. click on add address.
    4. click on done
    Congrats, you're done.
    May 2011
    That worked. Thank you very much.
    You're welcome! You can also use the File Registers Window, but I think the Watch windows is more convenient...
