ADC not working - I'm a new member
Results 1 to 13 of 13
    Jun 2011
    Kwa Dukuza, South Africa
    Default ADC not working - I'm a new member
    I've migrated from the Parallax sx but I'm new to PICs and PicBasic Pro
    How do I use ADCIN
    The following program is meant to display the binary value of a pot on AN2 on 8 LEDs on port RC. It doesn't work!!!
    ' Name : LearningADC.bas
    LEDs var PORTC
    ' Allocate variables
    PotVal Var Byte
    ANSEL = %00000100 ' Set PORTA.1 analog, rest digital
    ANSELH = %00000000
    mainloop:
    Adcin 2, x ' Read ADC value on AN2 (PORTA.2)
    LEDs = potval
    Pause 100 ' Do it about 10 times a second
    Goto mainloop
    Thanks from Kwa Dukuza, lost somewhere in South Africa
    John Bond
    Aug 2010
    Maryland, USA
    Default Re: ADC not working - I'm a new member
    I think your problem is here:
    you are reading the value of AN2, then storing in x
    You should be storing in potval
    And WELCOME to the forum!!
    -Bert
    Jun 2011
    Sorry, I spotted that after I posted but this is still not working...
    I've added
    ADCON1 = %10000100 ' Set PORTA analog and RIGHT justify result
    ADCON0 = %01000001 ' Configure and turn on A/D Module channel o Fosc 8
    and changed
    Adcin 0, PotVal
    I don't understand registers. I've read the PIC16F690 DATASHEET a couple of times. I seem to handle these issues best using the "Monkey see... monkey do" philosophy when trying to grasp complex problems. (Maybe the Monkey see, monkey do is part of my African heritage )
    Aug 2010
    Maryland, USA
    I don't have my book handy, but if you look at the ADCIN section of the PBP manual, there are several DEFINES you need in order to use the ADCIN command. Also to post code in the cool code box, you need to use tags. Really simple:
    [code[ <----should be the other, but then you won't see the tag
    All your code here
    [/code[ <----Again the second bracket should be } without the shift key.
    Maje sense?
    -Bert
    Jun 2011
    Thanks for your help Bert,
    Bert said "[code[ <----should be the other, but then you won't see the tag
    All your code here
    [/code[ <----Again the second bracket should be } without the shift key."
    Ja dit maak sense, dis cool! (Afrikaans response to Bert's last question - For English, replace "this" for "dit" and "dis")
    I've tried the various DEFINE and REGISTER options but I really don't know what I am doing. Nothing happens. I haven't linked up a UART/USART yet so I can't debug and I am in the dark. Hardware RS232 is my next exercise and I think I'll need to understand REGISTERS for that.
    Kind regards from Kwa Dukuza, lost somewhere in darkest Africa
    John Bond
    Aug 2010
    Maryland, USA
    Well now we need the basic stuff - lol. What pic? what version PBP? MPLAB or MCS? PM or MPASM? Internal osc or external? Some of it we don't need for this problem, but its a good idea to let us know what you are working with.
    What doesn't work? do any led's work? Can you make them blink? Is the value just wrong?
    -Bert
    Mar 2009
    I've just glanced at an old 16f690 program, which was unfeasibly huge so I've hacked it down & hopefully not missed anything during the slimming process...
    DEFINE ADC_BITS  8     ' ADCIN resolution  (Bits)
    DEFINE ADC_CLOCK 1     ' ADC clock source  (Fosc/8)
    DEFINE ADC_SAMPLEUS 11 ' ADC sampling time (uSec)
    ADCON1 = %0100000 ' FOSC/4
    CM1CON0 = 0  'turn the pesky comparators off
    CM1CON1 = 0  'turn the pesky comparators off
    CM2CON0 = 0 'turn the pesky comparators off
    CM2CON1 = 0 'turn the pesky comparators off
    ANSEL       = %0000010        'RA1 (pin 18) AN1 analogue
    PotVal Var Byte
    '********program starts......
    adcin 1, PotVal
    '[do cool stuff with contents of PotVal here, then have a cup of tea & a nap]
    You don't need to worry about ADCON0 (since the ADCIN command selects the ADC channel for you) *unless* you start wanting to use 10 bits, then you need to modify ADCON0.7 to suit (LH or RH Justify)
    Jun 2011
    Thanks Bert and Hank
    No time for tea or a nap but I'm sure this will solve my ADC problem. I now have a problem with the compiler. It crashes after a couple of downloads and only works again after reloading both PBP and MPLAB. I will make a new post on these issues
    Hank - Thanks for that warning on 10 bit (LH or RH Justify) because I will be using 10 bit to measure piezo pressure sensor and I will discarding the upper 1 or 2 bits to reduce the span to 8 bits. I am looking for a 0.05 Bar (peak to peak pressure fluctuation) to determine the speed of an air motor running at between 5 bar and 6 bar. 8 bit, without reducing the span, makes it a bit tight!
    Thanks again and kind regards
    John
    Oct 2009
    Utah, USA
    Here is another example of a small test program that will read the AN2 a/d converter and send it to a debug window.
    one thing to remember is that the a/d converter names do not always match the pin #. example... AN2 does match PortA.2 but AN3 is actually on PortA.4.
    If you have not used the debug feature of the PICkit programmer, you program the chip, power it up and then goto the Tools Menu and choose UART Tool. This will open up another Terminal window where you choose 2400 baud in the upper left and then click on Connect.
    ' 16F690
    '*  Notice  : Copyright (c) 2007 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 12/4/2007                                         *
    ' 10-bit A/D conversion
    ' Connect analog input to channel-2 (RA2)
    ' -----[ I/O Definitions ]-------------------------------------------------
     DEFINE DEBUG_REGG PORTA        'set debug port to porta
     DEFINE DEBUG_BIT 0             'use pin a0 of porta for debug
     DEFINE DEBUG_BAUD 2400         'set baud rate to 2400
     DEFINE DEBUG_MODE 0            'communicate in true mode
    ' Define ADCIN parameters
    ' Set number of bits in result
    DEFINE  ADC_BITS        10
    ' Set clock source (3=rc)
    DEFINE  ADC_CLOCK       3
    ' Set sampling time in microseconds
    DEFINE  ADC_SAMPLEUS    50
    adcVar  VAR WORD ' Create variable to store result
    ' Set PORTA to all input
    'TRISA = %11111111
    ' Set up AD
    ANSEL  = %00000100  'enable AN2, ALL THE REST DIGITAL
    ANSELH = %00000000  'AN8-11 DIGITAL
    ADCON0 = %10001000   ' RIGHT JUSTIFIED
    ADCON1 = %00010000  'fOSC/8
    Pause 500               ' Wait .5 second
      ADCIN 2, adcVar ' Read channel 0
      ' do something with adVar here
      debug DEC adcvar,"  ",BIN adcVar,$0D,$0A
      Pause 100              ' Wait.01 second
    GoTo main                   ' Do it forever
    Good Luck
    Dwight
    Jun 2011
    Thanks Dwight - that will sort me out once I've got my Microchip PICKit 2 dongle to start working again. The fault with the dongle seems like it may be electronic, not software.
    When I started this thread, I didn't have a MAX232 rigged up but I do now so from now on I can use the debug
    John Bond
    Check out the PBP manual under DEBUG.
    Then look at
    DEFINE DEBUG_MODE X 'X being 0 or 1 - TRUE or INVERTED
    Jun 2011
    Thanks for that "Heads-Up" Dave. I am scared of PC Com Ports after I got a 100V shock from one (half our 220V phase). I prefer using a MAX232 to a fried PCB. We tend to get Kong Fu PCs here and you never know what fascinating undocumented features are included. Maybe it's just Chinese revenge
    Regards form the dark continent - Africa
    John Bond
    Jun 2011
    OK Dwight, so you're a Gentleman! Thanks for that neat code. I works like clockwork
    I now understand both ADC and DEBUG!
    Regards from Kwa Dukuza on the dark continent of Africa
    John Bond
