Voltage issue 16f627a
+ Reply to Thread
Results 1 to 5 of 5
    Jun 2011
    Default Voltage issue 16f627a
    I have a voltage issue with my project. When portA.0 is taken to +5v, PortB.5 and PortB.6 outputs +5v. When PortA.0 is taken to 0v,GND. PortB.5 and PortB.6outputs 2.7V. I need B.5 and B.6 to go low 0v when A.0 is taken low. I've tried using PortB.7 in place of PortA.0, same results. little help with the program please.
    @ DEVICE pic16F627A, INTRC_OSC_NOCLKOUT
    CMCON = 7
    TRISB = %10000000
    TRISA = %00000011
    start:
    if PORTA.0 = 0 then pivot1
    if PORTA.0 = 1 then pivot2
    pivot1: low 0
    low 1
    low 2
    low 3
    low 4
    low 5
    low 6
    pivot2: low 0
    low 1
    low 2
    low 3
    low 4
    high 5
    high 6
    goto start:
    Default Re: Voltage issue 16f627a
    Not sure about Pic Basic, but with PBP it is a good idea to set the pin as a VAR
    low0 VAR PORTB.6
    Nah, it won't change anything, HIGH/LOW work as expected. HOWEVER, when you write to consecutive pin, you may want to Write to the whole port, or use a Shadow register. This is to avoid the R-M-W issue.
    PORTB=%11000000
    or
    ShadowRegister VAR BYTE
    ' some code here
    ShadowRegister.7=1
    ShadowRegister.6=1
    'etc etc
    PORTB=SHadowRegister
    Also, make sure all your config fuses are properly set, LVP_OFF, MCLR_OFF (assuming your don't use MCLR pin), OSC (INT or XT, whatever)
    Your pivot1 routine "Falls Thru" to the pivot2 routine.
    So the pins will have a 50% dutycycle signal and your voltmeter is averaging them to read 2.7V.
    Just add a goto after pivot1.
    Quote Originally Posted by yasky1 View Post
    start:
    pivot1: low 0
    low 1
    low 2
    low 3
    low 4
    low 5
    low 6
    goto start
    pivot2: low 0
    low 1
    low 2
    low 3
    low 4
    high 5
    high 6
    goto start:
    "Mister E, You want to post less, think more"
    Going back to my batcave...ashamed...
