Blink Programme for 16F876
Results 1 to 12 of 12
    banjaxxed's Avatar
    banjaxxed Guest
    Question Blink Programme for 16F876
    My first project.
    PicBasic Pro + Microcode Studio Plus v2.1.0.8 + Epic Plus Programmer + Prototype Board + XT 4Mhz
    Tried first setup with C508 and BLINK.BAS programme no problem.
    Selected different processor and successfully loaded programme into F876.
    Can turn outputs ON at any pin position, but when i use the PAUSE instruction and any time setting within the programme nothing runs at all.
    What am doing wrong?
    Feb 2004
    Germany
    banjaxxed
    see: here
    regards
    Ralph
    1. Read the Datasheet.
    2. You will discover the F876 has ADC's (and Comparators I believe in the case of the A version). By default, PortA comes up in Analogue mode. You must set the pins to Digital. See the sections for A/D Convertor Module (and Comparator Module section if it has one) to see how to do this.
    I really am trying to force people to read the Datasheets (the solution is very simple) before asking for answers on the forum.
    read the Datasheets
    And if it still doesn't work -- take a peek at the "errata sheet"....;o]
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    And by the time you've done that, you'll discover the part has been obsoleted by the 'A' version!
    banjaxxed's Avatar
    banjaxxed Guest
    after spending a fortune, getting no answers or support from my suppliers... only more questions - in getting this thing going...... i'll be obsolete myself before it's over
    (should have spent my hundreads of pounds on a decent micro plc)
    Post your code that's not working with a note on your config fuse settings.
    -Bruce
    tech at rentron.com
    banjaxxed's Avatar
    banjaxxed Guest
    Thumbs up 16F876 PicBasic Pro Program Fault Corrected For Blink
    <thanks to all for any advice>
    After a long hair pulling session, figured out the 16F876 starts with the A/D running. I wanted digital out Pin 22 (RB1). This is turned off by command 'ADCON1=7' line.
    Working code below to save someone else fustration:
    ' Ricky V
    ' 28 March 2005
    ' Blink Program
    ' MCU PIC16F876
    ' Rev 56,098,345
    ADCON1=7 'disable analogue to digital converter
    TRISB = 0 'set all pins on Port B to outputs
    LED VAR PORTB.1 'Sets which PIN the LED is on, Pin 22 +5V
    loop:
    High LED ' Turn on LED connected to PORTB.1 as Set in VAR LED
    Pause 500 ' Delay for .5 seconds
    Low LED ' Turn off LED connected to PORTB.1 as Set in VAR LED
    Goto loop ' Go back to loop and blink LED forever
    I'm glad to hear you got it working, but ADCON1 has no affect on PORTB.
    PORTA is the 16F876 A/D port.
    AN4 = RA5
    AN3 = RA3
    AN2 = RA2
    AN1 = RA1
    AN0 = RA0
    -Bruce
    tech at rentron.com
    4Lewis's Avatar
    4Lewis Guest
    Default Same Code for blink 16F876A and "not working"
    I used your exact code (which I know works just from looking at it) and I get this error "Code Programming error at 0000" - any suggestions, help?
    loop:
    Your device programmer should have a help file listing several possible causes
    for this particular error message. Lots of things can cause this one. Have you
    worked through the list in the help file?
    -Bruce
    tech at rentron.com
    4Lewis's Avatar
    4Lewis Guest
    Default solution is simple
    The problem was simple (once I got the installation documentation)
    My Zif programmer is screwed down to a board, so I couldn't turn it around. NOW, I know what was happening and why.
    I didn't just put my chip in a different direction, I had to turn aroud the Zif programmer and move the cable connector to the other side as well. So my school gave me a new programmer that was't screwed down so I could do that. It was simple, so I feel silly but all ends well.
  1. Trouble with most basic BLINK on PIC 16F819
    By confusedperson in forum mel PIC BASIC Pro
    Last Post: - 16th April 2009, 22:46
  2. Simple Blink program doesnt work.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 1st March 2009, 21:30
  3. Can't get blink circuit to work :(
    By Techbuilder in forum mel PIC BASIC Pro
    Last Post: - 31st January 2008, 14:00
  4. Execution time in programme
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 16th November 2007, 23:29
  5. I Just Can't Get it to Blink - 16F628
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 31st May 2005, 16:54
