12F683 trailing and rising edges in option_reg
Results 1 to 6 of 6
    Sep 2010
    Las Vegas, NV
    Default 12F683 trailing and rising edges in option_reg
    What advantage is there to using trailing vs. rising edge interrupts?
    in the option_reg line you can
    bit 6 INTEDG: Interrupt Edge Select bit
    1 = Interrupt on rising edge of INT pin
    0 = Interrupt on falling edge of INT pin
    bit 4 T0SE: Timer0 Source Edge Select bit
    1 = Increment on high-to-low transition on T0CKI pin
    0 = Increment on low-to-high transition on T0CKI pin
    So why would you use one over the other?
    If there is something I should have read please send a link but nothing I've seen gives a reason for either.
    Default Re: 12F683 trailing and rising edges in option_reg
    Here are some interactive examples of Rising/Falling edge differences.
    http://www.darreltaylor.com/DT_INTS-14/hello.html
    As Usual, Very good (Great?) treatise on the subject. And Thank You !
    Have you ever thought about assembling these little training aids into a course
    in programming ? I think 1000 words would not explain rising and falling edge so eloquently. You have put a lot of work into these, I hope everyone is grateful for them, I am.
    Thanks Joe,
    Yes I've thought about it. Started it. Then never finished it.
    There's always the NEXT problem to solve, and that's what I like doing.
    Putting hundreds of hours into something I've already figured out, doesn't stand much of a chance.
    Now that I get new problems every day ... even less of a chance.
    Old saying: There's no problems... only learning opportunities...
    Sep 2010
    Las Vegas, NV
    Thanks. Nicely done and illustrated.
