AD conversion
Results 1 to 9 of 9
Thread: AD conversion
    May 2011
    Default AD conversion
    Hello
    Does anyone know what is the maximum and minimum value of variable at 8 bit AD conversion (PIC 16f877A)
    For example:
    pw var byte
    adcin 0, pw "read AD value on pin 0 and store it at variable pw"
    now I am wondering what is the max and min value of that AD
    is it 0 and 255 since variable is Byte or there is some formula to count that
    Default Re: AD conversion
    Bingo! 0-255 it is.
    May 2011
    then why this doesnt work:
    I have a potentiometer on pin 0 (AD), and when I turn that pot to one end (left or right) my values of variable should be 0 or 255. And when I wrote IF function nothing happens
    for example:
    start:
    ADCIN 0, pw
    if pw = 0 then
    Pulsout portd.2, 220
    goto start
    goto start
    when ever I wrote pw = 255 or pw = 0 it doesnt do anything, but when I wrote If pw > 220 then it works ????
    For debugging purpose I always suggest people use a LCD, ICD or use PC Terminal to see what's happen INSIDE the PIC.
    Also, post your PIC model, whole code so we see your ADC DEFINES. Is the ADC result left or right justified, stuff like that.
    May 2011
    I am using PIC 16f877A
    this is the code
    DEFINE ADC_BITS 8 ' Set number of bits in result
    DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
    DEFINE ADC_SAMPLEUS 50
    ADCON1 = 0 ' PORTA is analog
    pw VAR BYTE
    TRISA = 255
    TRISD = 0
    start:
    ADCIN 0,pw
    if (pw > 220) and (pw<252) then
    pulsout portd.3,220
    goto start
    goto start
    This program works, when I move Joypad to the right motor move to the coresponding postion, I wanna know what is the right value of variable pw, when my joypad is moved al the way to the right and al the way to the left??
    OK, so you have the results left justified, it should work. BUT maybe you have some nifty noise on the line or something like that. Allow a certain error margin.
    test 0
    If pw<5 then
    test 255
    if pw>250 then
    still stucked?!? well let's try a variant of it
    Test 0
    if ADRESH<5 then
    test 255
    if ADRESH>250 then
    about now?
    May 2011
    So this ADRESH is the adress where AD save it's value ?
    what if I have two, three or four AD, is it all stored in same adress ?
    Yup they all have the same register.
    ADCIN select the channel, perform the conversion, then read it from ADRESH/ADRESL register, then dump it to your variable.
    May 2011
    thx Steve
    I will probably have few questions, now I will contion on my work
    thx
