Iam using an older demo board from Microchip. The MXDEV Analog evaluation driver board and the Digital Pot evaluation board. The problem I am having is getting the ICSP to work with the LCD plugged in. The RB6 & RB7 lines are shared with LCD data lines. The melabs usb programmer won't do it's job unless I unplug the LCD. I downloaded the data sheet for the LCD but it doesn't have any electrical specs on the data lines except logic levels required. No mention of input impedance. My question is do any of you have experience with this particular board regarding ICSP functionality. I was considering cutting the data lines and inserting a switch so I could switch out the LCD when programming through the ICSP connection but I would rather keep the board stock if possible. Any ideas?
