Astronomy Hardware - converting serial to USB and DC Motor control via PC
Results 1 to 11 of 11
    Oct 2009
    Default Astronomy Hardware - converting serial to USB and DC Motor control via PC
    Guys,
    Recently got back into astronomy and purchased a computerised goto 8" Newtonian Reflector, and was amazed at all the electronic gismos and software that's on the market, both retail and DIY for controlling the scope and camera's etc. However most seem to be based around RS232, and work by making the RTS and DTR lines go high and as most of the new netbooks and notebooks only have USB ports, have to resort to using clunky serial to usb converters.
    Is there any simple way of using a PIC (say an 18F2550) with USB port(s) to work in the same way... or would it require some form of driver to work ? There is a standard called ASCOM which a lot of these devices use, which is also open source, but is way above my level of understanding.
    One project I would like to get off the ground is the ability of controlling a DC motor used as a focuser. The idea being that you can set the rate at which the motor would run by pressing 0 to 9 on the keyboard and then use the left / right or forward /back arrow keys to make the motor run. Again via USB if possible
    Any pointers or ideas would help
    Malcolm
    Default Re: Astronomy Hardware - converting serial to USB and DC Motor control via PC
    Hi Malcom,
    I believe most of the PIC USB gizmos log into the PC as an HID type device, using generic drivers. You could go with one of the USB interface miniboards like viniculum or even I think Parralax sells one too. Only issue I see with HID is it is a bit slower than Full speed USB, certainly slower than USB3. (USB 3 runs something like 287MBS ). Those devices have their own drivers license.
    Dec 2005
    It's not at all clear what you want to do. If you want to replace the laptop, then almost any PIC can send RS232 serial commands to the device. If you only wish to replace the USB-serial converters, there are some which are not clunky as well as single chip USB-serial converters.Either way, there is no need for a USB capable PIC if you are interfacing to an RS232 device.
    Dec 2005
    To elaborate on my earlier post...
    Both FTDI and Silicon Labs have USB-Serial chips that also include GPIO pins. Since you also have the modem control lines, these may give you enough control. The drawback is they are surface mount chips. However, Spark Fun Electronics has them on breakout boards. They have schematics on each product page.
    Spark Fun also has the USB Bit Whacker which is a development board for PIC18F2553. It has numerous GPIO pins.
    All the above are here...http://www.sparkfun.com/search/resul...&what=products
    The product page for the USB Bit Whacker is at...http://www.sparkfun.com/products/762
    All of these are seen as virtual serial ports on a PC. I've not tried the Bit Whacker but have used FTDI, Silicon Labs and Prolific chips and all work with Windows, Linux and OSX. Most are recognized by the latest versions of Windows and by the Linux kernel and you do not need to install drivers. OSX recognizes them but you must install the driver to use it.
    Oct 2009
    Thanks for the links. Yes basically I was wondering if there a simple way to use a PIC with a USB rather than using RS232 with a RS232 to USB converter.
    For example, I currently use a cable release for my canon camera. This uses the DTR line to activate the shutter (ie DTR stays high for 10 seconds as controlled by the software on the PC). This is one example.
    The other is a focuser.. this uses a handset with simple push buttons to control the motors direction. It would be great if you could remove the cable from the handset, plug it into a small box with a PIC inside and plug that into a laptop via USB and use the arrow keys on the keypad to control the motor..
    Hope that makes things clearer ?
    Malc
    Dec 2005
    USB is doing it the hard way on both ends of the line. If you really want to go that way take a look at Jan Axelson's USB website...http://www.lvr.com/usb.htm
    Both of your examples can be done simply and easily using the CP2103 breakout board from Spark Fun. You have 4 GPIO pins which you can control from the PC.
    The USB Bit Whacker gives you a great deal more power. You can create your own PBP programs and download the hex file using the USB bootloader.
    Both connect via a USB cable but appear like COM ports to the PC allowing simple serial commands to control them. The only drawback is they are a bit slower than pure USB because they translate between serial and USB.
    Apr 2011
    Due to the lack of handshaking signals on 'some' USB-to-serial cables there are now a number of 'recommended' USB-to-serial leads that are used in astro control systems. Pop in to http://www.ukastroimaging.co.uk and enquire. You will also find articles on focussing etc that might appeal.
    Oct 2009
    Thanks once again for the input. Having ready the datasheet and application notes the CP2103 seems like an ideal option...
    @kellyeye Thanks for the link, will take a look now
    I've looked at piggybacking signals on the controls for MEADE. Autostar has "Meade Telescope Serial Command Protocol" via ASCOM that includes commands for focus (and you could just "listen in" on the receiving end).
    If your gear is using RS232, why are you messing with USB?
    Oct 2009
    Ioannis, I started this thread five years ago, and since then commercial items have appeared on the market, so opted for that.
