MCP4261 Digital Pot Control example - A quick little project
Results 1 to 3 of 3
    Default MCP4261 Digital Pot Control example - A quick little project
    I'm working on a project using the Microchip MCP4261 Digital Pots. Cute little parts...
    Here's a code snippet and a schematic as example. The code is an example of reading a "real" pot via A/D and updating a "digital pot" with the value. I'm using the LAB-X2 board from meLabs for testing. The code uses the on-board POT1 for one channel (RA0) and a second off-board pot for channel two (RA1). Put a voltmeter on the wiper of the digital pot to see the values update. There are a few other features of the digital pot that can be used simply by changing the "address" value. There's code in there for writing the A/D value to a serial LCD display for testing - ignore it. Simple but maybe useful to someone...
    Have fun.
    MT
    MCP4261.pdf
    '* Name    : MCP4261POT_000.bas                                               *
    '* Compiler: PICBASIC PRO Compiler microEngineering Labs                      *
    '* Author  : Mike Tripoli                                                     *
    '* Notes:        *
    '* Read an analog voltage on RA.0 and and RA.1                                *
    '* copy the 8 bit value to a digital pot value register                       *
    '* Display value on serial LCD display                                        *
    '* 8-bit conversion yields 0-255 result for 0-5 volt input.                   *
    '* Uses meLabs LAB-X2 demo board                                              *
    '* Date    : 03/03/2011                                                       *
    'Setup some defaults for programming the device.
    'High-speed OSC, Watch dog timer-OFF, Brown-out detect OFF, Low Voltage Program OFF, Protect code OFF
    @ DEVICE HS_OSC,WDT_OFF,BOD_OFF,LVP_OFF,PROTECT_OFF
    include "modedefs.bas"      'Shiftout mode definitions
    ' Define ADCIN parameters
    Define  ADC_BITS        8	' Set number of bits in result
    Define  ADC_CLOCK       3	' Set clock source (3=rc)
    Define  ADC_SAMPLEUS    50	' Set sampling time in uS
    ADC_VAL_0 Var     byte      ' Only using 8 bits of ADC Channel 0
    ADC_VAL_1 Var     byte      ' Only using 8 bits of ADC Channel 1
    POT0    var     word        ' WORD variable to for address (high byte) and pot value (low byte) POT0
    POT1    var     word        ' WORD variable to for address (high byte) and pot value (low byte) POT1
    LED1    Var     PORTB.0	    ' Alias PORTB.0 to LED1 on LAB-X2 board from meLabs
    LED2    VAR     PORTB.1     ' Alias PORTB.1 to LED2
    LED3    VAR     PORTB.2     ' Alias PORTB.2 to LED3
    SCK     var     PORTC.3     ' Alias PORTC.3 to SCK (serial data clock)
    SDO     var     PORTC.5     ' Alias PORTC.5 to SDO (serial data out)
    CS      var     PORTC.2     ' Alias PORTC.2 to C_EN (chip enable)
    LCD_DISP    var PORTB.3     ' LCD connected to PORTB.3 - LAB-X2
    TRISA   =   %11111111	    ' Set PORTA to all input
    TRISB   =   %00000000       ' Set PORTB to all output
    TRISC   =   %00000000	    ' Set PORTC to all output
    ADCON1  =   %00000010	    ' Set PORTA analog
    'Initialize registers and variables
            LOW     LED1    'Initialize LEDs OFF
            LOW     LED2    ' "
            LOW     LED3    ' "
            HIGH    CS                  'Chip enable high to start
            high     sck                'Mode 1,1 SCK idles high
    ;	    Serout2 LCD_DISP,396,[12]	' Clear the LCD display
    ;Initialize POT WORD
    pot0.Highbyte = %00000000    'POT0 address in hex - easier for me to see which pot selected
    pot0.lowbyte = 0             'POT0 value in DEC - initialize pot - can be any value
    pot1.Highbyte = %00010000    'POT1 address in hex
    pot1.lowbyte = 0             'POT1 value in DEC
    mainloop:
            ADCIN 0, adc_val_0      	' Read channel RA.0 to ADC_VAL_0 - Uses onboard "POT1" on LAB - X2
            pot0.lowbyte = adc_val_0    'copy input voltage from pot to digital pot
            pause 10
            ADCIN 1, adc_val_1    	    ' Read channel RA.1 to ADC_VAL_1
            pot1.lowbyte = adc_val_1    'copy input voltage from pot to digital pot
    ;***** DELETE THIS SECTION - ONLY FOR TESTING ***************
    ;	    Serout2 PORTB.3,396,[12]	                            'Set to beginning of LCD display
    ;	    Serout2 PORTB.3,396,["ADC_VAL_0=",DEC3 adc_val_0,148]	' Display adc channel 0
    ;	    Serout2 PORTB.3,396,["ADC_VAL_1=",DEC3 adc_val_1,13]	' Display adc channel 1
    ;        PAUSE 10
            GOSUB   write_pots
            goto    mainloop
    WRITE_POTS:                                 ; Routine writes value to pots
    WR_POT_0:
            low     CS                          ' Make chip active
            pause   1                           ' Delay after making chip active per data sheet - only need 60nS
            shiftout    sdo,sck,5,[pot0\16]     ' Mode 1,1 in MCP4261 DS / Mode 5 PBP - clock idles high, MSB shift out first
            high    CS                          ' MCP4261 DS recommends toggling /CS between commands
            pause   1                           ' Delay keeps from banging CS pin
    WR_POT_1:
            low     CS                          'Make chip active
            pause   1                           'Delay after making chip active
            shiftout    sdo,sck,5,[pot1\16]
            high    CS
            END 'ALL PROGRAMS NEED AN END STATEMENT!
    Feb 2004
    Michigan, USA
    Default Re: MCP4261 Digital Pot Control example - A quick little project
    Quick question. You reference SDO. Is this PIC side or pot side?
    Quote Originally Posted by jmgelba View Post
    The code and the schematic show SDO on the PIC side...
