pls help me w/ my program....
Results 1 to 7 of 7
    Mar 2011
    Default pls help me w/ my program....
    Im just a beginer in programing and in making circuits... im currently doing my project... i used PIC16F877A and a GSM benqM23... the problem is the replying of my device... my project are compost of different sensors and when it detect it will send message to the given number and also you can send message to the device and it will reply to you... the sending part is ok but the reply part is not working... when i seperate the program for the reply it works well but when i combined it with the program of my sensor and sending it doesnt work... i dont know the problem if it is my program or my device... some one pls help me... here is my program...
    my current program----> the reply part is not working
    '* Name : UNTITLED.BAS *
    '* Notice : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 2/28/2011 *
    '* Version : 1.0 *
    '* Notes : *
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    DEFINE HSER_SPBRG 12
    adcon1=7
    cmcon=7
    trisa=1
    trisb=1
    trisc=1
    trisd=0
    trise=1
    y1 var byte[2]
    y2 var byte[8]
    pass1 var bit
    pass2 var bit
    pass3 var bit
    a0 var porta.0
    a1 var porta.3
    a2 var porta.5
    a3 var porte.2
    b0 var portb.0
    b1 var portb.1
    b2 var portb.3
    b3 var portb.4
    b4 var portb.5
    b5 var portb.6
    b6 var portb.7
    c0 var portc.0
    c1 var portc.1
    c2 var portc.2
    d0 var portd.0
    d1 var portd.1
    d2 var portd.2
    d3 var portd.3
    d4 var portd.4
    d5 var portd.5
    d6 var portd.6
    d7 var portd.7
    e0 var porte.0
    e1 var porte.1
    y1[0]="0"
    y1[1]="0"
    pass1=0
    pass2=0
    pass3=0
    a0=1
    a1=1
    a2=1
    a3=1
    b0=1
    b1=1
    b2=1
    b3=1
    b4=1
    b5=1
    b6=1
    c0=1
    c1=1
    c2=1
    e0=1
    e1=1
    portd=%11111111
    pause 250
    HSerout ["AT+CMGF=1",13]
    Pause 500
    HSEROUT ["AT+CMGDA=",34,"DEL ALL",34,13]
    portd=%00000000
    while 1
    HSerin 5000, main2, [WAIT("SM")]
    gosub reply
    main2:
    if a0=0 then
    y1[0]="1"
    y1[1]="6"
    y2[0]="C"
    y2[1]="R"
    y2[2]="I"
    y2[3]="T"
    y2[4]="I"
    y2[5]="C"
    y2[6]="A"
    y2[7]="L"
    portd=%00000001
    portd=%00000000
    if pass1=0 then
    gosub send1
    pass1=1
    pass2=0
    pass3=0
    if a1=0 then
    y1[0]="1"
    y1[1]="5"
    y2[0]="A"
    y2[1]="L"
    y2[2]="R"
    y2[3]="M"
    y2[4]=32
    y2[5]=32
    y2[6]=32
    y2[7]=32
    portd=%00000011
    portd=%00000000
    if pass2=0 then
    gosub send1
    pass2=1
    pass1=0
    pass3=0
    if a2=0 then
    y1[0]="1"
    y1[1]="4"
    y2[0]="A"
    y2[1]="L"
    y2[2]="E"
    y2[3]="R"
    y2[4]="T"
    y2[5]=32
    y2[6]=32
    y2[7]=32
    portd=%00000111
    portd=%00000000
    if pass3=0 then
    gosub send1
    pass3=1
    pass1=0
    pass2=0
    IF a3=0 then
    y1[0]="1"
    y1[1]="3"
    IF b0=0 then
    y1[0]="1"
    y1[1]="2"
    IF b1=0 then
    y1[0]="1"
    y1[1]="1"
    IF b2=0 then
    y1[0]="1"
    y1[1]="0"
    IF b3=0 then
    y1[0]="9"
    y1[1]=32
    IF b4=0 then
    y1[0]="8"
    y1[1]=32
    IF b5=0 then
    y1[0]="7"
    y1[1]=32
    IF b6=0 then
    y1[0]="6"
    y1[1]=32
    IF c0=0 then
    y1[0]="5"
    y1[1]=32
    IF c1=0 then
    y1[0]="4"
    y1[1]=32
    IF c2=0 then
    y1[0]="3"
    y1[1]=32
    IF e0=0 then
    y1[0]="2"
    y1[1]=32
    IF e1=0 then
    y1[0]="1"
    y1[1]=32
    wend
    send1:
    portd=%11111111
    portd=%00000000
    HSEROUT ["AT+CMGS=",34,"09166494457",34,13]
    HSerout [y2[0],y2[1],y2[2],y2[3],y2[4],y2[5],y2[6],y2[7]," Water Level: ",y1[0],y1[1],26]
    PAUSE 2000
    portd=%01010101
    portd=%00000000
    reply:
    portd=%00001111
    portd=%00000000
    portd.6=1
    HSerout ["Water Level: ",y1[0],y1[1],26]
    portd.5=1
    pause 2000
    my program for replying only----> it works well
    '* Notice : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] *
    '* Date : 11/19/2010 *
    '* Version : 1.0 *
    '* Notes : *
    adcon1=7
    cmcon=7
    'GSMBUFFER VAR BYTE[16]
    'Caller VAR BYTE[13]
    'GSMTime VAR BYTE[17]
    trisa=%11111111
    trisd=%00000000
    text var byte[4]
    text[0]="1"
    text[1]="2"
    text[2]="3"
    text[3]="4"
    portd=%111111111
    pause 2000
    Pause 500
    PAUSE 3000
    WHILE 1
    portd=%00000000
    portd.0=1
    PAUSE 500
    portd=%00000011
    HSERIN 5000, main, [WAIT("SM")]
    portd.7=1
    portd.6=1
    HSerout ["WATER LEVEL: ",text[0],text[1],"m",26]
    portd.5=1
    pause 2000
    HSERIN 2000, main, [WAIT("OK")]
    portd=%11111111
    PAUSE 2000
    HSEROUT ["AT+CMGD=1",13]
    HSERIN [WAIT("OK")]
    portd=%10101010
    PAUSE 400
    portd=%00000000
    PAUSE 400
    WEND
    Default Re: pls help me w/ my program....
    Hi...may i ask first what's the purpose of the a0...a3 variables?
    am I understanding correctly that your program waits for "SM" from the modem for 5 seconds if not goes to main2? then if the modem does reply with "SM" yo go directly to reply...
    Mar 2011
    hellow master_olan... the purpose of the a0...a3 is just to declared it as port.a0...port.a5 and etc... because my input for my sensor is port a,b,c,e...
    yes you are right about the purpose of the program it is to waits for "SM" from the modem for 5 seconds if not it goes to main2... then if the modem does reply with "SM" it go directly to reply.
    The replying program only is working well... but when i put it in the program of sensors and send it doesnt work... i dont know the problem why is not working... may be the declaration of
    adcon1=7
    cmcon=7
    i dont know if i declared it right....
    Well I programmed a PIC16f877a to a GSM modem for a friend some months ago... I also had problems with receiving data from Modem to PIC and added a buffer (74LS125)... It worked after that... also try changing this:
    to this:
    DEFINE HSER_TXSTA 24h
    the manual says 24h works with high speed baud rates.. It's what I did with mine...
    Mar 2011
    Hellow master_olan thanks again for your help and reply... sorry for my noob question but where i should put the buffer... sorry im just a beginer in making circuits... it would be a great help if you can post a schematic diagram of your MUC with buffer... and thanks a lot
    Well... just connect GSM Mod. TX to input of buffer then output of buffer to RX of PIC... Just like this...
    If that doesn't work i suggest you spy in your system by using the PCs hyperterminal.. That way you will know if the Module or the PIC does respond to the commands...
    I hope any of these will help you...
    Mar 2011
    hi master_olan
    I Did all the things you said but it did not work... i also check it in pc but still the reply did not work... any suggestion or solution? thank you for your help and effort
