I am Completely NEW to PICS and LOST PIC18f252
Results 1 to 8 of 8
    Feb 2011
    Default I am Completely NEW to PICS and LOST PIC18f252
    I am familiar with BS2's and propellers but i am lost with this. When i try and compile this code, i get a series of errors... redefinition of VAR and redefinition of Label. What am i missing. Can anybody help? am i missing some more defines or includes?
    Define OSC 4
    include "bs2defs.bas"
    Progress Var Byte
    Relay1 var PORTC.2
    Relay2 var PORTC.1
    Relay3 var PORTC.0
    StatLED var PORTA.0
    OptoPin var PORTB.0
    ADres	var	byte	' A-to-D result: one byte.
    CS	var PORTB.2		' Chip select is pin 0.
    AData VAR PORTB.7	' ADC data output is pin 1.
    CLK	VAR PORTB.6  	' Clock is pin 2.
    baud  	con   	16468 	' N9600
    i var byte
    Start:
      high CS			' Deselect ADC to start.
      progress = 0
      gosub One
      Gosub Two
      Gosub Three
      If Progress = 3 then
              completegood
      Else
              high Statled
    One:  'This will test the output of relay 1 and check its value through the ADC
      High Relay1
      Pause 10
    'Run ADC code
      Low Relay1
    'Test ADC value to be within range 80-100
      If (ADRes>80) and (ADres<100) then
       i = 0
        REPEAT
         High StatLED
         Pause 500
         Low StatLED
         Pause 500
         i = i + 1
        UNTIL i > 7
       i = 0
        REPEAT
         High Relay1
         Pause 500
         Low Relay1
         Pause 200
         i = i + 1
        UNTIL i > 7
    Two:'This will test the output of relay 2 and check its value through the ADC
      High Relay2
      Pause 10
    'Run ADC code
      Low Relay2
    'Test ADC value to be within range 105-140
      If (ADRes>105) and (ADres<140) then
      goto  BLEDG
        i = 0
       REPEAT
         High Relay1
         Pause 500
         Low Relay1
         Pause 200
         i = i + 1
       UNTIL i > 7
    Three:'This will test the output of relay 3 and check its value through the ADC
      High Relay3
      Pause 10
    'Run ADC code
      If Optopin = 1 then
        Optogood
      Low Relay3
    'Test ADC value to be within range 200-260
      If (ADRes>200) and (ADres<260) then
      goto BLEDG
       i = 0
       REPEAT
         High Relay3
         Pause 500
         Low Relay3
         Pause 200
         i = i + 1
       UNTIL i > 7
       Progress = progress + 1
    BLEDG: 'Tested out good so we will let everyone know.
     i = 0
     REPEAT
       High StatLED
       Pause 500
       Low StatLED
       Pause 500
       i = i + 1
     UNTIL i > 7
    OptoGood: 'Tested out good so we will let everyone know.
      i = 0
     REPEAT
       High StatLED
       Pause 100
       Low StatLED
       Pause 100
       i = i + 1
     UNTIL i > 4
    CompleteGood: 'Tested out good so we will let everyone know.
     REPEAT
       High StatLED
       Pause 100
       Low StatLED
       Pause 300
    ADC:
      low CS		' Activate the ADC0831.
      shiftin AData,CLK,msbpost,[ADres\9]	' Shift in the data.
      high CS		' Deactivate '0831.
      serout 3,baud,[ADres]
    Aug 2010
    Maryland, USA
    Default Re: I am Completely NEW to PICS and LOST PIC18f252
    I don't see where you ever call the ADC routine
    -Bert
    ADRES is already defined in the P18F252.inc file. Change this to something else.
    Your IF/THEN/ELSE has Completegood without a GOTO or GOSUB before it.
    Completegood has a REPEAT with no UNTIL, no RETURN (or goto somewhere else), and END after it.
    Start falls right through to One, which has a RETURN. If you want it to loop back to Start, place a goto Start at the end of Start.
    This should have a GOSUB before Optogood;
     If Optopin = 1 then
        GOSUB Optogood
    You have a few goto BLEDG that need to be gosub BLEDG, etc.
    REPEAT must have an UNTIL to end it. Always GOSUB any routine that RETURNs, and for multiple IF/THEN/ELSE place your goto or gosub on the line after the THEN. IF Optopin = 1 THEN Optogood would work, but when you place Optogood on a line by itself, the compiler sees this as a lable. Not an instruction telling it to jump to Optogood.
    Just go slowly through your code line-by-line. You'll see the errors.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2011
    Thanks so far for the help.
    I have cleaned up the code, see below, and now i have a whole new list of errors.
    What does all of this mean? (errors are in the attachment)
    Define OSC 4
    Progress Var Byte
    Relay1 var PORTC.2
    Relay2 var PORTC.1
    Relay3 var PORTC.0
    StatLED var PORTA.0
    OptoPin var PORTB.0
    ADVar	var	byte	' A-to-D result: one byte.
    i var byte
    A Var PORTA.6
    ' BASIC Stamp II Interface for the ADC0831
    ' 8-bit analog-to-digital converter
    Start:
      progress = 0
      gosub One
      Gosub Two
      Gosub Three
      gosub  completegood
      Else
              high Statled
      High Relay1
      Pause 10
      gosub ADC'Run ADC code
      Low Relay1
      If (ADVar>80) and (ADVar<100) then
       i = 0
        REPEAT
         High StatLED
         Pause 500
         Low StatLED
         Pause 500
         i = i + 1
        UNTIL i > 7
       i = 0
        REPEAT
         High Relay1
         Pause 500
         Low Relay1
         Pause 200
         i = i + 1
        UNTIL i > 7
      High Relay2
      Pause 10
      Gosub ADC'Run ADC code
      Low Relay2
      If (ADVar>105) and (ADVar<140) then
      gosub BLEDG
        i = 0
       REPEAT
         High Relay1
         Pause 500
         Low Relay1
         Pause 200
         i = i + 1
       UNTIL i > 7
      High Relay3
      Pause 10
      If Optopin = 1 then
      gosub Optogood
      Low Relay3
      If (ADVar>200) and (ADVar<260) then
      goto BLEDG
       i = 0
       REPEAT
         High Relay3
         Pause 500
         Low Relay3
         Pause 200
         i = i + 1
       UNTIL i > 7
     i = 0
      REPEAT
       High StatLED
       Pause 500
       Low StatLED
       Pause 500
       i = i + 1
      UNTIL i > 7
      i = 0
      REPEAT
       High StatLED
       Pause 100
       Low StatLED
       Pause 100
       i = i + 1
     UNTIL i > 4
       High StatLED
       Pause 100
       Low StatLED
       Pause 300
    ADC:
      shiftin AData,CLK,msbpost,[ADVar\9]	' Shift in the data.
      serout 3,baud,[ADVar]
    It looks like Mpasm doesn't know where to find its include files. Look in your directory: C:\Program Files\Microchip\MPASM Suite and see if you can find a P18F252.INC file in there.
    Feb 2011
    it is not there? Now what?
    Sounds like a 100 meg download is in order. What version of PBP do you have? If it is 2.60, then you can download the newest version of mplab ide. http://www.microchip.com/stellent/id...&part=SW007002
    Otherwise, you will need 8.15, which can be found here: http://melabs.com/resources/win_ide.htm
    Which version of Mplab ide do you have?
    Feb 2011
    2.60A i just purchased it from mouser this last week.
