16F1827 ASM Interrupt
Results 1 to 5 of 5
    Apr 2010
    Default 16F1827 ASM Interrupt
    I am using a 16F1827 I need to use the ASM style interrupt routine to free up some program space. There are two pins that will fire if they go high. Either fires the interrupt properly, the existing output can be turned low properly but for some reason changing the input to an output and making it high is not functioning and the LED flashing routine doesn't change based on the interrupt as it should. I am sure I am missing something simple but I just can't seem to figure it out...
    The interrupt is very simple, all I am needing to do is:
    • Change an input to an output
    • Make the new output high
    • Make an existing output low
    • Determine which one of two interrupts got tripped and goto a LED flashing routine for user feedback
    • Continue in an endless loop flashing the indication LED
        'setup the interrupts
        DEFINE INTHAND intRoutine  'where to go when an interrupt fires
        IOCBP = %00001100
        INTCON = %10011000	' Enable interrupt
    ;the following is the interrupt routine
    intRoutine
        ;turn off interrupts
        MOVLW   b'00000000'
        MOVWF   INTCON
        ;disable all interrupts that were previously enabled
        MOVLW   b'00000000'
        MOVWF   IOCBP
        ;RB3 is currently an input, change it to an output and make it high
        ;prior to this operation TRISB would be 11111110
        MOVLW     b'11110110'
        MOVWF    TRISB
        ;turn on RB3  (doesn't go high)
        BSF PORTB,3
        ;turn off detection power (this is working fine)
        BCF PORTA,0
        ;check to see what tripped the interrupt
        ;(this always goes to detectionFlash even when lighting activated the interrupt)
        ;IOCBF.2 = detection
        ;IOCBF.3 = lighting
        BTFSS IOCBF,3
        GOTO detectionFlash
        GOTO lightingFlash
    lightingFlash
        BSF _overCurrentLED
        CALL    Delay
        BCF _overCurrentLED
        CALL    Delay
        CALL    Delay
        GOTO    lightingFlash
    detectionFlash
        BSF _overCurrentLED
        CALL    Delay
        BCF _overCurrentLED
        CALL    Delay
        BSF _overCurrentLED
        CALL    Delay
        BCF _overCurrentLED
        CALL    Delay
        CALL    Delay
        GOTO    detectionFlash
    endASM
    Default Re: 16F1827 ASM Interrupt
    When it gets to the ISR, it could be in any bank at the time.
    INTCON is available from any bank, but ...
    PORTB is in BANK0.
    TRISB is in BANK1.
    IOCBF is in BANK7.
    Use BSR to change banks.
    Aug 2010
    Maryland, USA
    Could also use BANKSEL reg_name
    For instance:
    BANKSEL TRISB
    bla
    bla
    bla
    BANKSEL IOCBF
    bla
    bla
    bla
    works just like BSR but no need to lookup the bank number.
    -Bert
    Apr 2010
    Thanks Darrel that clears up why things were not working as I expected!
    Most things are working great now except one very strange thing. The LED that is to be used to indicate this interrupt state (on RB0) works fine when RB3 has initiated the interrupt however when RB2 has initiated the interrupt when I attempt to flash RB0 it somehow turns off RB2 which is the pin that was changed from an input to an output and made high.
    In the code shown below I am using the wrong LED (RA6) to indicate the RB2 interrupt condition and everything works fine other than the wrong LED flashing.
    I am thinking that there is some strange property that RB0 has but I am very confused why it doesn't mess up when RB3 has initiated the interrupt.
    intRoutine
        MOVLW   b'00000000'
        MOVWF   INTCON
        MOVLB   0x07    ;select BANK 7
        MOVLW   b'00000000'
        MOVWF   IOCBP
        MOVLB   0x01    ;select BANK 1
        MOVLW   b'11110110'
        MOVWF   TRISB
        MOVLB   0x00    ;select BANK 0
        BSF PORTB,3
        BCF PORTA,0
        ;IOCBF.3 = lighting
        BTFSS   IOCBF,3
        GOTO    detectionFlash
        GOTO    lightingFlash
    lightingFlash
        BSF    PORTB,0
        CALL    Delay
        BCF    PORTB,0
        CALL    Delay
        CALL    Delay
        GOTO    lightingFlash
    detectionFlash
        BSF    PORTA,6 ;this is the wrong LED but works properly when this one is selected instead of PORTB,0
        CALL    Delay
        BCF    PORTA,6
        CALL    Delay
        BSF    PORTA,6
        CALL    Delay
        BCF    PORTA,6
        CALL    Delay
        CALL    Delay
        GOTO    detectionFlash
    endASM
    Apr 2010
    Thanks for the code example cncmachineguy.
    I have it working properly now. I am thinking there must be some type of race condition with the way I had it coded. I have added a delay right after B3 was made high and everything works fine. Without the delay B3 goes low as soon as B0 is made high.
    Thanks for the help guys!
