One more thing ...
The compiler doesn't like " ° " ( "Maj" + "=" ) character ...
better use
Lcdout $FE,$C0,"ITS: ",DEC3 tb0,".",DEC2 tb1, 223, "C"
where 223 ( sometimes 178 ) is supposed to be the ASCII code of " ° " ...
That said ... ADC value NEVER is > 1023 ...
from your firsts explanations ( post #1) ... I get That : ( 16F877A on EasyPic5 )
DEFINE ADC_BITS 10 ' Set number of bits in result
DEFINE LCD_DREG PORTB ' Set LCD Data port
DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus .7
DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
DEFINE LCD_RSBIT 4 ' Set LCD Register Select bit
DEFINE LCD_EREG PORTB ' Set LCD Enable port
DEFINE LCD_EBIT 5 ' Set LCD Enable bit i.e, PORTE.4
DEFINE LCD_BITS 4 ' Set LCD bus size ot 4 bit Upper Nibble (4 or 8 bits)
DEFINE LCD_LINES 2 ' Set number of lines on LCD to 4 Lines
TRISA = %11111111
TRISB = 0
TRISC = 0
CMCON = 7
ADCON0 = %11000001
ADCON1 = %10000100
ntc VAR WORD
tb0 VAR WORD
tb1 VAR WORD
tb2 VAR WORD
PAUSE 700
LCDOUT $fe,1
lp:
ADCIN 1,ntc
tb0 = ntc * 33 /92
tb1 = tb0*721
tb2 = Div32 255
tb2 = tb2 - 64
tb0 = tb2/10
tb1 = tb2//10
PAUSE 200
LCDOUT $FE,2,DEC4 ntc
Lcdout $FE,$C0,"ITS: ",DEC3 tb0,".",DEC1 tb1,178,"C"
goto lp
Gives me a 0 - 100°C scale for adc = 67 to 1023 ...
so, i suppose it to be " not so bad , but to confirm "
