12F683 ADCIN - both channels the same
+ Reply to Thread
Results 1 to 4 of 4
    Default 12F683 ADCIN - both channels the same
    I'm having a problem with reading two analog inputs. The first channel (GPIO.0) works well but the issue is that the next channel reads identically even though the voltage going into the pin is clearly different.
    I must be missing something simple, I think that what I am trying to do is quite basic. I've looked at the PicBasic Pro manual, the datasheet and searched the forum. I did see that someone had a similar problem but the solution was not effective for me.
    The wiring has been checked over many times, I am confident that the error is in the code.
    The intention is to read the two axis and the button of a mini joystick and send the data serially to another uC.
    @ DEVICE PIC12F683, MCLR_OFF
    @ DEVICE PIC12F683, INTRC_OSC_NOCLKOUT
    @ DEVICE PIC12F683, WDT_OFF
    @ DEVICE PIC12F683, BOD_ON
    @ DEVICE PIC12F683, PWRT_ON
    DEFINE  OSC 8
    Define	ADC_BITS	8	' Set number of bits in result
    Define	ADC_CLOCK	3	' Set clock source (3=rc)
    Define	ADC_SAMPLEUS	50	' Set sampling time in uS
    define  CHAR_PACING 1000
    OSCCON = %01110001     ' internal oscillator at 4 MHZ
    CMCON0 = 0             ' Comparators off
    ANSEL  = %00000011	   ' Set 0, 1, analog
    WPU    = 0             ' Internal pull-ups = off
    GPIO   = %00000000     ' All outputs = 0 on boot
    TRISIO = %00011111     ' GPIO.0,1,2,3,4 input, GPIO.5 output
    joyY         var   GPIO.0
    joyX         var   GPIO.1
    joyBtn       var   GPIO.2
    Sout         var   GPIO.5
    AD      var     byte
    X       var     byte
    Y       var     byte
    Btn     var     byte
    B       var     bit
    adcin joyX, AD
    X = AD
    AD = 0
    pause 1
    adcin joyY, AD
    Y = AD
    AD = 0
    B = joyBtn
    if B  then
    Btn = Btn + 1
    Btn = 0
    if Btn > 100 then Btn = 100
    serout Sout, 2, ["cmd", X, Y, Btn, 128, 128]
    goto Main
    Rich H
    Yet another one where the PBP manual explain it all, but no one seems to bother reading Just kidding
    ADCIN ADCHannel, Var
    ADCHannel must be a decimal value, 0,1,2,3,4,5 etc... you use the ADC channel number, NOT the port PIN name.
    ADCIN 0, Var
    ADCIN 1, Var2
    plah plah plah
    Ahh, I just knew it was going to be something simple.
    Thanks!
    Rich H
    Hi, Rich
    The way to give a decent name to ADC inputs ... :
    joyY CON 0 ' ADC pin number must be set as a CONstant ...
    joyX CON 1
    joyBtn var GPIO.2
    Sout var GPIO.5
    AD var byte
    X var byte
    adcin joyX, AD
    X = AD
    AD = 0
    pause 1
    adcin joyY, AD
    Y = AD
