selecting the correct micro controler to use
Results 1 to 9 of 9
    Default selecting the correct micro controler to use
    when selecting microcontrolers for a job i use the two selectors from microchip (MAPS and the newer flash one) and the one from melabs and then cross reference.
    This is an absolute ballach...
    Is their any way to get microchips entire pic list in say excel along with their brief hardware?
    Also...
    microchip do pics with upto 10 PWM's but pbp only supports a limited number of chips with 5PWM's.
    I know i can make copies and modify the pbp incs, but would their be anything else i need to do to make PBP, MPASM and MCS use these nice exotic chips?
    Also #2...
    I came across one pic that had an internal 1V/2V/4V voltage reference for ADC, but i can't find it again and it's not searchable. Anyone know of any of these chips?
    PIC12F615/617/HV615
    for question #2
    Question #1 ???
    Quote Originally Posted by comwarrior View Post
    Also...
    You are referring to the 18F2xJx3 series.
    Those chips will be included in the next patch (2.60B).
    There just haven't been enough problems with 2.60A to warrant a patch yet.
    Mackrackit, PIC12's are just not going to be powerful enough, i need continuous and rapid ADC scanning and quite a bit of number crunching...
    Darrel, Thats correct PIC18F86K22... does pbp currently support/allow 64MHz OSC defines?
    also, any updates for Instant Ints to support more tmr's ect?
    The PIC16F182x & 16F19xx parts have an internal voltage reference.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2011
    Default Re: selecting the correct micro controler to use
    I got this from the selection page and cleaned it up and working on the pin out question.
    -- which is my question, I'm lloking for a chart with the pinout sytles.
    Will add 18f family soon.
    hope it pastes well. -- it did you can copy this and plop it into a spread sheet.
    second section is with the webpages.
    column 2 is for the v+/_mclr pins
    Product Family	VDD/_MCLR	$$-vol	Program Memory KBytes	Program Memory KWords	Self-write	EEPROM Data Memory	RAM	I/O Pins	Pin count	Max. CPU Speed MHz	 Internal Oscillator	32kHz	A/D Ch.	Cap Touch Channels	UART	A/E/usart	-SPI	I2C	8bit	b16	32bit	Temperature Range	Operation Voltage Range
    PIC12F1822 		$0.73	3.5	2	Yes	256	128	6	8	32		32kHz	4	4		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC12F508 		$0.41	0.75	0.5	No	0	25	6	8	4	4		0						1			 -40 to 125	 2V - 5.5V
    PIC12F509 		$0.45	1.5	1	No	0	41	6	8	4	4		0						1			 -40 to 125	 2V - 5.5V
    PIC12F510 		$0.49	1.5	1	No	0	38	6	8	8	4+8		3	3					1			 -40 to 125	 2V - 5.5V
    PIC12F519 		$0.49	1.5	1	No	64	41	6	8	8	4+8		0						1			 -40 to 125	 2V - 5.5V
    PIC12F609 		$0.52	1.75	1	No	0	64	6	8	20	4+8		0						1	1		 -40 to 125	 2V - 15V
    PIC12F615 		$0.55	1.75	1	No	0	64	6	8	20	4+8		4	4					2	1		 -40 to 150	 2V - 15V
    PIC12F617 		$0.59	3.5	2	Yes	0	128	6	8	20	4+8		4	4					2	1		 -40 to 125	 2V - 5.5V
    PIC12F629 		$0.70	1.75	1	No	128	64	6	8	20	4		0						1	1		 -40 to 125	 2V - 5.5V
    PIC12F635 		$0.84	1.75	1	No	128	64	6	8	20	8	32kHz	0						1	1		 -40 to 125	 2V - 5.5V
    PIC12F675 		$0.77	1.75	1	No	128	64	6	8	20	4		4						1	1		 -40 to 125	 2V - 5.5V
    PIC12F683 	1.4	$0.91	3.5	2	No	256	128	6	8	20	8	32kHz	4	3					2	1		 -40 to 125	 2V - 5.5V
    PIC16F505 		$0.48	1.5	1	No	0	72	12	14	20		32kHz	0						1			 -40 to 125	 2V - 5.5V
    PIC16F506 		$0.52	1.5	1	No	0	67	12	14	20	4+8		3						1			 -40 to 125	 2V - 5.5V
    PIC16F526 		$0.55	1.5	1	No	64	67	12	14	20	4+8		3						1			 -40 to 125	 2V - 5.5V
    PIC16F54 		$0.39	0.75	0.5	No	0	25	12	18	20			0						1			 -40 to 125	 2V - 5.5V
    PIC16F57 		$0.52	3	2	No	0	72	20	28	20			0						1			 -40 to 125	 2V - 5.5V
    PIC16F59 		$0.85	3	2	No	0	134	32	40	20			0						1			 -40 to 125	 2V - 5.5V
    PIC16F610 		$0.59	1.75	1	No	0	64	12	14	20	4+8		0	4					1	1		 -40 to 125	 2V - 15V
    PIC16F616 		$0.69	3.5	2	No	0	128	12	14	20	4+8		8	4					2	1		 -40 to 150	 2V - 15V
    PIC16F627A 		$1.30	1.75	1	No	128	224	16	18	20	4		0			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F628A 		$1.47	3.5	2	No	128	224	16	18	20	4		0			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F630 		$0.91	1.75	1	No	128	64	12	14	20	4		0						1	1		 -40 to 125	 2V - 5.5V
    PIC16F631 		$0.91	1.75	1	No	128	64	18	20	20	8	32kHz	0	4					1	1		 -40 to 125	 2V - 5.5V
    PIC16F636 		$0.92	3.5	2	No	256	128	12	14	20	8	32kHz	0						1	1		 -40 to 125	 2V - 5.5V
    PIC16F639 		$2.27	3.5	2	No	256	128	12	20	20	8	32kHz	0						1	1		 -40 to 125	 2V - 5.5V
    PIC16F648A 		$1.67	7	4	No	256	256	16	18	20	4		0			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F676 		$0.98	1.75	1	No	128	64	12	14	20	4		8						1	1		 -40 to 125	 2V - 5.5V
    PIC16F677 		$0.99	3.5	2	No	256	128	18	20	20	8	32kHz	12	4			SSP		1	1		 -40 to 125	 2V - 5.5V
    PIC16F684 		$0.98	3.5	2	No	256	128	12	14	20	8	32kHz	8						2	1		 -40 to 125	 2V - 5.5V
    PIC16F685 		$1.13	7	4	No	256	256	18	20	20	8	32kHz	12	4					2	1		 -40 to 125	 2V - 5.5V
    PIC16F687 		$1.07	3.5	2	No	256	128	18	20	20	8	32kHz	12	4		1	SSP		1	1		 -40 to 125	 2V - 5.5V
    PIC16F688 		$1.04	7	4	No	256	256	12	14	20	8	32kHz	8			1			1	1		 -40 to 125	 2V - 5.5V
    PIC16F689 		$1.13	7	4	No	256	256	18	20	20	8	32kHz	12	4		1	SSP-1		1	1		 -40 to 125	 2V - 5.5V
    PIC16F690 		$1.20	7	4	No	256	256	18	20	20	8	32kHz	12	4		1	SSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F707 		$1.68	14	8	No	0	368	36	40	20	16		14	32		1	SSP-1		3	1		 -40 to 125	 1.8V - 5.5V
    PIC16F716 		$0.77	3.5	2	No	0	128	13	18	20			4						2	1		 -40 to 125	 2V - 5.5V
    PIC16F72 		$1.91	3.5	2	No	0	128	22	28	20			5						2	1		 -40 to 125	 2V - 5.5V
    PIC16F720 		$0.77	3.5	2	Yes	0	128	18	20	16	16		12			1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F721 		$0.84	7	4	Yes	0	256	18	20	16	16		12			1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F722 		$0.95	3.5	2	No	0	128	25	28	20	16		11	8		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F722A 		$0.78	3.5	2	No	0	128	25	28	20	16		11	8		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F723 		$1.09	7	4	No	0	192	25	28	20	16		11	8		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F723A 		$0.85	7	14	No	0	192	25	28	20	16		11	8		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F724 		$1.40	7	4	No	0	192	36	40	20	16		14	16		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F726 		$1.23	14	8	No	0	368	25	28	20	16		11	8		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F727 		$1.54	14	8	No	0	368	36	40	20	16		14	16		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F73 		$2.97	7	4	No	0	192	22	28	20			5			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F737 		$3.13	7	4	No	0	368	25	28	20	8		11			1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F74 		$3.61	7	4	No	0	192	33	40	20			8			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F747 		$3.61	7	4	No	0	368	36	40	20	8		14			1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F76 		$3.73	14	8	No	0	368	22	28	20			5			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F767 		$3.64	14	8	No	0	368	25	28	20	8		11			1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F77 		$4.12	14	8	No	0	368	33	40	20			8			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F777 		$4.00	14	8	No	0	368	36	40	20	8		14			1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F785 		$1.12	3.5	2	No	256	128	18	20	20	8	32kHz	12						2	1		 -40 to 125	 2V - 15V
    PIC16F818 		$1.56	1.75	1	Yes	128	128	16	18	20			5				SSP		22	1		 -40 to 125	 2V - 5.5V
    PIC16F819 		$1.78	3.5	2	Yes	256	256	16	18	20			5				SSP		2	1		 -40 to 125	 2V - 5.5V
    PIC16F84A 		$3.11	1.75	1	No	64	68	13	18	20			0						1			 -40 to 85	 2V - 6V
    PIC16F87 		$2.06	7	4	Yes	256	368	16	18	20	8		0			1	SSP		2	1		 -40 to 125	 2V - 5.5V
    PIC16F88 		$2.20	7	4	Yes	256	368	16	18	20	8		7			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F882 		$1.16	3.5	2	Yes	128	128	25	28	20	8	32kHz	11	11		1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F883 		$1.37	7	4	Yes	256	256	25	28	20	8	32kHz	11	11		1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F884 		$1.63	7	4	Yes	256	256	36	40	20	8	32kHz	14	11		1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F886 		$1.49	14	8	Yes	256	368	25	28	20	8	32kHz	11	11		1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F887 		$1.78	14	8	Yes	256	368	36	40	20	8	32kHz	14	11		1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F913 		$1.72	7	4	No	256	256	25	28	20	8	32kHz	5			1	SSP		2			 -40 to 125	 2V - 5.5V
    PIC16F914 		$2.03	7	4	No	256	256	36	40	20	8	32kHz	8			1	SSP		2	1		 -40 to 125	 2V - 5.5V
    PIC16F916 		$1.93	14	8	No	256	352	25	28	20	8	32kHz	5			1	SSP		2	1		 -40 to 125	 2V - 5.5V
    PIC16F917 		$2.17	14	8	No	256	352	36	40	20	8	32kHz	8			1	SSP		2	1		 -40 to 125	 2V - 5.5V
    PIC16F946 		$2.31	14	8	No	256	336	54	64	20	8	32kHz	8			1	SSP		2	1		 -40 to 125	 2V - 5.5V
    PIC16F1516 		$0.95	14	8	Yes	0	512	25	28	20	16	32kHz	17	17		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1517 		$1.32	14	8	Yes	0	512	36	40	20		32kHz	28	28		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1518 		$1.01	28	16	Yes	0	1024	25	28	20		32kHz	17	17		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1519 		$1.37	28	16	Yes	0	1024	36	40	20		32kHz	28	28		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1526 		$1.47	14	8	Yes	0	768	55	64	20		32kHz	30	30		2	MSSP-2		6	3		 -40 to 125	 1.8V - 5.5V
    PIC16F1527 		$1.54	28	16	Yes	0	1536	55	64	20		32kHz	30	30		2	MSSP-2		6	3		 -40 to 125	 1.8V - 5.5V
    PIC16F1823 		$0.78	3.5	2	Yes	256	128	12	14	32		32kHz	8	8		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1824 		$0.84	7	4	Yes	256	256	12	14	32		32kHz	8	8		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1825 		$0.92	14	8	Yes	256	1024	12	14	32	32	32kHz	8	12		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1826 		$0.97	3.5	2	Yes	256	256	16	18	32		32kHz	12	12		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1827 		$1.04	7	4	Yes	256	384	16	18	32		32kHz	12	12		1	MSSP-2		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1828 		$0.99	7	4	Yes	256	256	18	20	32		32kHz	12	12		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1829 		$1.06	14	8	Yes	256	1024	18	20	32	32	32kHz	12	12		1	MSSP-2		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1933 		$1.23	7	4	Yes	256	256	25	28	32		32kHz	11	8		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1934 		$1.46	7	4	Yes	256	256	36	40	32		32kHz	14	16		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1936 		$1.30	14	8	Yes	256	512	25	28	32		32kHz	11	8		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1937 		$1.53	14	8	Yes	256	512	36	40	32		32kHz	14	16		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1938 		$1.37	28	16	Yes	256	1024	25	28	32		32kHz	11	8		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1939 		$1.61	28	16	Yes	256	1024	36	40	32		32kHz	14	16		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1946 		$1.75	14	8	Yes	256	512	53	64	32		32kHz	17	17		2	MSSP-2		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1947 		$1.82	28	16	Yes	256	1024	53	64	32		32kHz	17	17		2	MSSP-2		4	1		 -40 to 125	 1.8V - 5.5V
    											CLOCK MHz					Communications				Timers
    Product Family	VDD/_MCLR	Documents	$$-vol	Program Memory KBytes	Program Memory KWords	Self-write	EEPROM Data Memory	RAM	I/O Pins	Pin count	Max. CPU Speed MHz	 Internal Oscillator	32kHz	A/D Ch.	Cap Touch Channels	UART	A/E/usart	-SPI	I2C	8bit	b16	32bit	Temperature Range	Operation Voltage Range
    PIC12F1822 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en544839	$0.73	3.5	2	Yes	256	128	6	8	32		32kHz	4	4		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC12F508 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en020094	$0.41	0.75	0.5	No	0	25	6	8	4	4		0						1			 -40 to 125	 2V - 5.5V
    PIC12F509 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en020095	$0.45	1.5	1	No	0	41	6	8	4	4		0						1			 -40 to 125	 2V - 5.5V
    PIC12F510 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en023670	$0.49	1.5	1	No	0	38	6	8	8	4+8		3	3					1			 -40 to 125	 2V - 5.5V
    PIC12F519 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en530188	$0.49	1.5	1	No	64	41	6	8	8	4+8		0						1			 -40 to 125	 2V - 5.5V
    PIC12F609 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en028259	$0.52	1.75	1	No	0	64	6	8	20	4+8		0						1	1		 -40 to 125	 2V - 15V
    PIC12F615 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en027148	$0.55	1.75	1	No	0	64	6	8	20	4+8		4	4					2	1		 -40 to 150	 2V - 15V
    PIC12F617 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en544446	$0.59	3.5	2	Yes	0	128	6	8	20	4+8		4	4					2	1		 -40 to 125	 2V - 5.5V
    PIC12F629 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010113	$0.70	1.75	1	No	128	64	6	8	20	4		0						1	1		 -40 to 125	 2V - 5.5V
    PIC12F635 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en019829	$0.84	1.75	1	No	128	64	6	8	20	8	32kHz	0						1	1		 -40 to 125	 2V - 5.5V
    PIC12F675 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010114	$0.77	1.75	1	No	128	64	6	8	20	4		4						1	1		 -40 to 125	 2V - 5.5V
    PIC12F683 	1.4	http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010115	$0.91	3.5	2	No	256	128	6	8	20	8	32kHz	4	3					2	1		 -40 to 125	 2V - 5.5V
    PIC16F505 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en020096	$0.48	1.5	1	No	0	72	12	14	20		32kHz	0						1			 -40 to 125	 2V - 5.5V
    PIC16F506 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en023671	$0.52	1.5	1	No	0	67	12	14	20	4+8		3						1			 -40 to 125	 2V - 5.5V
    PIC16F526 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en530189	$0.55	1.5	1	No	64	67	12	14	20	4+8		3						1			 -40 to 125	 2V - 5.5V
    PIC16F54 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010205	$0.39	0.75	0.5	No	0	25	12	18	20			0						1			 -40 to 125	 2V - 5.5V
    PIC16F57 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010206	$0.52	3	2	No	0	72	20	28	20			0						1			 -40 to 125	 2V - 5.5V
    PIC16F59 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en021222	$0.85	3	2	No	0	134	32	40	20			0						1			 -40 to 125	 2V - 5.5V
    PIC16F610 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en028257	$0.59	1.75	1	No	0	64	12	14	20	4+8		0	4					1	1		 -40 to 125	 2V - 15V
    PIC16F616 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en026028	$0.69	3.5	2	No	0	128	12	14	20	4+8		8	4					2	1		 -40 to 150	 2V - 15V
    PIC16F627A 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010208	$1.30	1.75	1	No	128	224	16	18	20	4		0			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F628A 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010210	$1.47	3.5	2	No	128	224	16	18	20	4		0			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F630 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010211	$0.91	1.75	1	No	128	64	12	14	20	4		0						1	1		 -40 to 125	 2V - 5.5V
    PIC16F631 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en026027	$0.91	1.75	1	No	128	64	18	20	20	8	32kHz	0	4					1	1		 -40 to 125	 2V - 5.5V
    PIC16F636 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en019833	$0.92	3.5	2	No	256	128	12	14	20	8	32kHz	0						1	1		 -40 to 125	 2V - 5.5V
    PIC16F639 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en022266	$2.27	3.5	2	No	256	128	12	20	20	8	32kHz	0						1	1		 -40 to 125	 2V - 5.5V
    PIC16F648A 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010212	$1.67	7	4	No	256	256	16	18	20	4		0			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F676 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010213	$0.98	1.75	1	No	128	64	12	14	20	4		8						1	1		 -40 to 125	 2V - 5.5V
    PIC16F677 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en026026	$0.99	3.5	2	No	256	128	18	20	20	8	32kHz	12	4			SSP		1	1		 -40 to 125	 2V - 5.5V
    PIC16F684 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010214	$0.98	3.5	2	No	256	128	12	14	20	8	32kHz	8						2	1		 -40 to 125	 2V - 5.5V
    PIC16F685 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en023115	$1.13	7	4	No	256	256	18	20	20	8	32kHz	12	4					2	1		 -40 to 125	 2V - 5.5V
    PIC16F687 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en023114	$1.07	3.5	2	No	256	128	18	20	20	8	32kHz	12	4		1	SSP		1	1		 -40 to 125	 2V - 5.5V
    PIC16F688 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010215	$1.04	7	4	No	256	256	12	14	20	8	32kHz	8			1			1	1		 -40 to 125	 2V - 5.5V
    PIC16F689 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en023113	$1.13	7	4	No	256	256	18	20	20	8	32kHz	12	4		1	SSP-1		1	1		 -40 to 125	 2V - 5.5V
    PIC16F690 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en023112	$1.20	7	4	No	256	256	18	20	20	8	32kHz	12	4		1	SSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F707 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en548149	$1.68	14	8	No	0	368	36	40	20	16		14	32		1	SSP-1		3	1		 -40 to 125	 1.8V - 5.5V
    PIC16F716 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010216	$0.77	3.5	2	No	0	128	13	18	20			4						2	1		 -40 to 125	 2V - 5.5V
    PIC16F72 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010217	$1.91	3.5	2	No	0	128	22	28	20			5						2	1		 -40 to 125	 2V - 5.5V
    PIC16F720 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en546017	$0.77	3.5	2	Yes	0	128	18	20	16	16		12			1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F721 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en546016	$0.84	7	4	Yes	0	256	18	20	16	16		12			1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F722 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en533502	$0.95	3.5	2	No	0	128	25	28	20	16		11	8		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F722A 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en547286	$0.78	3.5	2	No	0	128	25	28	20	16		11	8		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F723 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en533505	$1.09	7	4	No	0	192	25	28	20	16		11	8		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F723A 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en547287	$0.85	7	14	No	0	192	25	28	20	16		11	8		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F724 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en533509	$1.40	7	4	No	0	192	36	40	20	16		14	16		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F726 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en533506	$1.23	14	8	No	0	368	25	28	20	16		11	8		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F727 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en533510	$1.54	14	8	No	0	368	36	40	20	16		14	16		1	SSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F73 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010218	$2.97	7	4	No	0	192	22	28	20			5			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F737 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010219	$3.13	7	4	No	0	368	25	28	20	8		11			1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F74 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010220	$3.61	7	4	No	0	192	33	40	20			8			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F747 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010221	$3.61	7	4	No	0	368	36	40	20	8		14			1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F76 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010222	$3.73	14	8	No	0	368	22	28	20			5			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F767 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010223	$3.64	14	8	No	0	368	25	28	20	8		11			1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F77 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010224	$4.12	14	8	No	0	368	33	40	20			8			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F777 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010225	$4.00	14	8	No	0	368	36	40	20	8		14			1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F785 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en020257	$1.12	3.5	2	No	256	128	18	20	20	8	32kHz	12						2	1		 -40 to 125	 2V - 15V
    PIC16F818 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010226	$1.56	1.75	1	Yes	128	128	16	18	20			5				SSP		22	1		 -40 to 125	 2V - 5.5V
    PIC16F819 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010227	$1.78	3.5	2	Yes	256	256	16	18	20			5				SSP		2	1		 -40 to 125	 2V - 5.5V
    PIC16F84A 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010230	$3.11	1.75	1	No	64	68	13	18	20			0						1			 -40 to 85	 2V - 6V
    PIC16F87 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010231	$2.06	7	4	Yes	256	368	16	18	20	8		0			1	SSP		2	1		 -40 to 125	 2V - 5.5V
    PIC16F88 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010243	$2.20	7	4	Yes	256	368	16	18	20	8		7			1			2	1		 -40 to 125	 2V - 5.5V
    PIC16F882 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en530146	$1.16	3.5	2	Yes	128	128	25	28	20	8	32kHz	11	11		1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F883 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en026563	$1.37	7	4	Yes	256	256	25	28	20	8	32kHz	11	11		1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F884 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en026564	$1.63	7	4	Yes	256	256	36	40	20	8	32kHz	14	11		1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F886 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en026562	$1.49	14	8	Yes	256	368	25	28	20	8	32kHz	11	11		1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F887 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en026561	$1.78	14	8	Yes	256	368	36	40	20	8	32kHz	14	11		1	MSSP-1		2	1		 -40 to 125	 2V - 5.5V
    PIC16F913 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en020199	$1.72	7	4	No	256	256	25	28	20	8	32kHz	5			1	SSP		2			 -40 to 125	 2V - 5.5V
    PIC16F914 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en020200	$2.03	7	4	No	256	256	36	40	20	8	32kHz	8			1	SSP		2	1		 -40 to 125	 2V - 5.5V
    PIC16F916 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en020201	$1.93	14	8	No	256	352	25	28	20	8	32kHz	5			1	SSP		2	1		 -40 to 125	 2V - 5.5V
    PIC16F917 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en020202	$2.17	14	8	No	256	352	36	40	20	8	32kHz	8			1	SSP		2	1		 -40 to 125	 2V - 5.5V
    PIC16F946 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en023674	$2.31	14	8	No	256	336	54	64	20	8	32kHz	8			1	SSP		2	1		 -40 to 125	 2V - 5.5V
    PIC16F1516 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en549050	$0.95	14	8	Yes	0	512	25	28	20	16	32kHz	17	17		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1517 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en549051	$1.32	14	8	Yes	0	512	36	40	20		32kHz	28	28		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1518 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en549052	$1.01	28	16	Yes	0	1024	25	28	20		32kHz	17	17		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1519 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en549053	$1.37	28	16	Yes	0	1024	36	40	20		32kHz	28	28		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1526 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en549054	$1.47	14	8	Yes	0	768	55	64	20		32kHz	30	30		2	MSSP-2		6	3		 -40 to 125	 1.8V - 5.5V
    PIC16F1527 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en549055	$1.54	28	16	Yes	0	1536	55	64	20		32kHz	30	30		2	MSSP-2		6	3		 -40 to 125	 1.8V - 5.5V
    PIC16F1823 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en544838	$0.78	3.5	2	Yes	256	128	12	14	32		32kHz	8	8		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1824 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en546901	$0.84	7	4	Yes	256	256	12	14	32		32kHz	8	8		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1825 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en546902	$0.92	14	8	Yes	256	1024	12	14	32	32	32kHz	8	12		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1826 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en538964	$0.97	3.5	2	Yes	256	256	16	18	32		32kHz	12	12		1	MSSP-1		2	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1827 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en538963	$1.04	7	4	Yes	256	384	16	18	32		32kHz	12	12		1	MSSP-2		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1828 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en546918	$0.99	7	4	Yes	256	256	18	20	32		32kHz	12	12		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1829 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en546919	$1.06	14	8	Yes	256	1024	18	20	32	32	32kHz	12	12		1	MSSP-2		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1933 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en538159	$1.23	7	4	Yes	256	256	25	28	32		32kHz	11	8		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1934 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en538156	$1.46	7	4	Yes	256	256	36	40	32		32kHz	14	16		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1936 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en538158	$1.30	14	8	Yes	256	512	25	28	32		32kHz	11	8		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1937 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en538149	$1.53	14	8	Yes	256	512	36	40	32		32kHz	14	16		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1938 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en538157	$1.37	28	16	Yes	256	1024	25	28	32		32kHz	11	8		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1939 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en538148	$1.61	28	16	Yes	256	1024	36	40	32		32kHz	14	16		1	MSSP-1		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1946 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en538147	$1.75	14	8	Yes	256	512	53	64	32		32kHz	17	17		2	MSSP-2		4	1		 -40 to 125	 1.8V - 5.5V
    PIC16F1947 		http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en538146	$1.82	28	16	Yes	256	1024	53	64	32		32kHz	17	17		2	MSSP-2		4	1		 -40 to 125	 1.8V - 5.5V
    Mar 2008
    Will we have support for the PIC16F18446 soon?
    upgrade to 3.1 and its already there
