FineLineIDE - Page 5
Page 5 of 5 FirstFirst 12345
Results 161 to 188 of 188
Thread: FineLineIDE
  1. #161
    Default Re: FineLineIDE
    No... clicking inside the dropdown box it says Find PBPx.EXE in Options.
    I have installed the PBP in a secondary drive (D:\ ...) as I have an SSD as primary disk.
    What FL needs is a setting in options tab "PicBasicPro Compiler". FL needs to know the location of the PBP compiler in order to find the list of devices located there.
    Norm
  3. #163
    Yes I did that, but no joy...
    Ioannis, I'm with you, It doesn't work for me either.
    EN82fn
  5. #165
    OK I am testing FL v3.76 as per Ioannis.
    My version of PBP3 is 3.0.8.4
    FL > Options > PicBasicPro Compiler on my PC is found at C:\PBP3\PBPX.EXE
    FL looks in directory C:\PBP3\DEVICES
    In that location it finds the following:
    PIC10F202.PBPINC
    PIC10F206.PBPINC
    PIC10F222.PBPINC
    PIC12C508.PBPINC
    etc.
    What might be different on other PC's or PBP versions other than the users specific choice of PBP3 location?
    Norm
  6. #166
    On my installation:
    PBP 3.1 is in:
    D:\Program Files (x86)\PBP3_1
    and DEVICES is in:
    D:\Program Files (x86)\PBP3_1\DEVICES
    My new install is the same as yours Ionnis except on my c:/ drive. After doing what Norm suggested and finding it manually it says it has been found but when clicking on the processor selection box it still comes back saying "Find PBPx.EXE in Options"
    EN82fn
  8. #168
    Got it...thanks
    Ioannis what is your PBP version? Mine apparently is out of date.
    Norm
  9. #169
    Dave, I have exactly the same response.
    Norm, my PBP is the latest 3.1
    See this example from "MicrocCode Studio > Help > About" for the full version number. Mine is an older v3.0.8.4
    Norm
  11. #171
    My exact version is 3.1.0.4
    Mine too....
    EN82fn
  13. #173
    I setup the compiler as in the attached picture but still asks for the compiler. It does not want to cooperate with me!
  14. #174
    Norm, My work does not allow that site. I'll be monitoring the conversation as it goes along.
    EN82fn
  15. #175
    Dave, do you have two seperate disk?
    Also, Norm, I have Win-7, 64 bit if that matters.
    Dave, do you have two separate disk?
    I'm presently working on the addition of a separate category settable in options for v3.1
    Hopefully ready in the not too distant future.
    Perhaps will have a copy of v3.1 soon.
    Norm
  17. #177
    Ioannis, Everything is mounted on my root drive C:/.
    EN82fn
  18. #178
    Norm
    First of all I wish to thank all those interested in FineLineIDE BETA 3.76. To be honest though FL BETA 3.76 wasn't intended to be released for use with PBP as of yet and wasn't provided on this forum.
    I began what I thought might be a fairly straight forward tweak to enable use of FL BETA 3.76 however am finding it a bit more than anticipated. Also I need PicBasicPro v3.1 to do testing as well.
    As I am well into a more recent addition of a "replace all" feature which displays all and only the lines containing the replace terms and it has become obvious it would be difficult to track the changes made in FL BETA 3.76 to be certain of making the same changes in the FL currently in development.
    Sorry for the misunderstanding and will be offering the next version of FL including PBP as soon as it is available. For now please use FineLineIDE v3.3
    Norm
  19. #179
    SWITZERLAND (french speaking)
    Hi Normnet,
    I was wondering if I can, like MCS does, avoid the Crossing page boundary error?
    Name:  2018-01-06-FineLineIDE   D__PBP_Timer_16F690_01-01-18A.bas   PicBasicPro.jpg
    I'm using your version 3.3
    Roger
  20. #180
    Default FineLineIDE - Crossing page boundary
    ...I forgot to mention that I currently use this method as a turnaround to avoid the error message:
    @ ERRORLEVEL -306 ; turn off crossing page boundary message
    Roger
  21. #181
    Hi Normnet,
    [I'm using your version 3.3
    Not at present...sorry.
    Norm
  22. #182
    Okay, thanks anyway.
    Fantastic editor!!!
    BTW, what or where is your official website or depository apart from the one I found in the PROTON forum, if there is one of course?
    Roger
  23. #183
    The PBP download site is available in the PBP WiKi.
  24. #184
    Default Lines left out at COMPILE time
    Hi Norm,
    I've read the FL's manual and couldn't find what I'm searching for so I ask here.
    I was wondering if you have included an option to have lines of code that will be left out at COMPILE time?
    I have also tested your version 3.76 but it crashes from the start - impossible to test Maybe something with my PC's configuration?
    Roger
  25. #185
    Default Re: Lines left out at COMPILE time
    Hi Norm,
    See above post #178. Version 3.76 wasn't offered on this site and isn't compatible with PBP.
    Norm
  26. #186
    Thanks Norm,
    What about lines not to be compiled?
    Roger
  27. #187
    I have been working steadily with the replace all feature as well as rewrites of the find dialog and replace dialog and am not planning past it.
    Norm
  28. #188
    Okay. Thanks Norm.
    Roger
Members who have read this thread : 4
