No... clicking inside the dropdown box it says Find PBPx.EXE in Options.
I have installed the PBP in a secondary drive (D:\ ...) as I have an SSD as primary disk.
Ioannis, I'm with you, It doesn't work for me either.
EN82fn
OK I am testing FL v3.76 as per Ioannis.
My version of PBP3 is 3.0.8.4
FL > Options > PicBasicPro Compiler on my PC is found at C:\PBP3\PBPX.EXE
FL looks in directory C:\PBP3\DEVICES
In that location it finds the following:
PIC10F202.PBPINC
PIC10F206.PBPINC
PIC10F222.PBPINC
PIC12C508.PBPINC
etc.
What might be different on other PC's or PBP versions other than the users specific choice of PBP3 location?
Norm
On my installation:
PBP 3.1 is in:
D:\Program Files (x86)\PBP3_1
and DEVICES is in:
D:\Program Files (x86)\PBP3_1\DEVICES
My new install is the same as yours Ionnis except on my c:/ drive. After doing what Norm suggested and finding it manually it says it has been found but when clicking on the processor selection box it still comes back saying "Find PBPx.EXE in Options"
EN82fn
Got it...thanks
Ioannis what is your PBP version? Mine apparently is out of date.
Norm
Dave, I have exactly the same response.
Norm, my PBP is the latest 3.1
See this example from "MicrocCode Studio > Help > About" for the full version number. Mine is an older v3.0.8.4
Norm
I setup the compiler as in the attached picture but still asks for the compiler. It does not want to cooperate with me!
Norm, My work does not allow that site. I'll be monitoring the conversation as it goes along.
EN82fn
Dave, do you have two seperate disk?
Also, Norm, I have Win-7, 64 bit if that matters.
Ioannis, Everything is mounted on my root drive C:/.
EN82fn
First of all I wish to thank all those interested in FineLineIDE BETA 3.76. To be honest though FL BETA 3.76 wasn't intended to be released for use with PBP as of yet and wasn't provided on this forum.
I began what I thought might be a fairly straight forward tweak to enable use of FL BETA 3.76 however am finding it a bit more than anticipated. Also I need PicBasicPro v3.1 to do testing as well.
As I am well into a more recent addition of a "replace all" feature which displays all and only the lines containing the replace terms and it has become obvious it would be difficult to track the changes made in FL BETA 3.76 to be certain of making the same changes in the FL currently in development.
Sorry for the misunderstanding and will be offering the next version of FL including PBP as soon as it is available. For now please use FineLineIDE v3.3
Norm
Hi Normnet,
I was wondering if I can, like MCS does, avoid the Crossing page boundary error?
I'm using your version 3.3
Roger
...I forgot to mention that I currently use this method as a turnaround to avoid the error message:
@ ERRORLEVEL -306 ; turn off crossing page boundary message
Roger
Okay, thanks anyway.
Fantastic editor!!!
BTW, what or where is your official website or depository apart from the one I found in the PROTON forum, if there is one of course?
Roger
The PBP download site is available in the PBP WiKi.
Hi Norm,
I've read the FL's manual and couldn't find what I'm searching for so I ask here.
I was wondering if you have included an option to have lines of code that will be left out at COMPILE time?
I have also tested your version 3.76 but it crashes from the start - impossible to test Maybe something with my PC's configuration?
Roger
Thanks Norm,
What about lines not to be compiled?
Roger
I have been working steadily with the replace all feature as well as rewrites of the find dialog and replace dialog and am not planning past it.
Norm
