Remove Text Formatting
Loading...
+ Reply to Thread
Page 4 of 5 FirstFirst 12345 LastLast
Results 121 to 160 of 178
Thread: FineLineIDE
  1. #121
    Default Re: FineLineIDE
    Or just keep everything for the given project in a directory of its own...
  2. #122
    May 2005
    Hello,
    Impossible to download a correct version of the newest FineLineIde. In fact the Zip is corrupted and cannot be decompressed.
    Could you please help.
    Thank you
  3. #123
    I just tried it from here and it worked fine
    http://www.norm-online.net/FineLineIDE.php
  4. #124
    thank you.
  5. #125
    May 2005
    Thank you. In fact and always i tried on an other computer i encountered the same problem( file corrupted wrong CRC..). I could obtain same in downloading the file "FineLineIDE.php?action=download1" which is the short cut for download with the help of a downloader, i renamed it in . rar and finally obtained the good file. What is the mystery??
    Anyhow thank you again.
  6. #126
    I just tested the download and it unzipped without error.
    Norm
  7. #127
    Hi Norm,
    Is FineLineIDE still alive?
  8. #128
    Hi Norm,
    FineLine IDE is undergoing a rewrite as time permits.
    No ETA.
    Norm
  9. #129
    Cool !!
    Is the last version still available? I seem to have misplaced it.
  10. #130
    Cool !!
    The hosting site is apparently down.
    Try FineLineIDE.
    Unzip and change .abc to .exe
    Norm
  11. #131
    No ETA.
    Norm
    Is it ready now?
    (Couldn't resist )
  12. #132
    Try FineLineIDE.
    Norm
    Thanks Norm!!
  13. #133
    Are we there yet?
    (I couldn't resist either)
    George
  14. #134
    The new FineLineIDE v3.0 is now available!
    A rewrite for reliability, Bookmarks and Unused.
    Less code collapse as it doubled the size and complexity of the program.
    Norm
  15. #135
    Thanks Norm!!!
    Question, what does
    "Did Not Find New .bas File. Aborting"
    message mean when I try to compile?
  16. #136
    Thanks Norm!!!
    Question, what does
    Dave I sent you an email.
    Norm
  17. #137
    Dec 2007
    Finland
    Hi Norm,
    Thanks for the new version of FineLineIDE. I was trying it when I noticed something strange. Only part of code was visible in FineLineIDE and after debugging reason was Scandinavian letter in comment line. There is something weird happening if code have one or more of these letters: ,, or ,,.
    Also, I had difficulties to set PicBasicPro Compiler in Options menu. I fix this, by manually editing FineLineIDE.ini file. After manual modification to ini-file, file compiled OK.
    -Gusse-
  18. #138
    Quote Originally Posted by Gusse View Post
    Hi Norm,
    -Gusse-
    Gusse I PM you a beta 3.01 to test retaining non English text.
    Norm
  19. #139
    Hi Norm,
    I think I found the problem. I am running windows in a VirtualBox but the files are stored on the host OS. I tried putting the file in the windows environment and the error went away.
    If it is any help, the machine I tried this on has openSUSE as the host and Windows7 as the guest.
  20. #140
    Hi Norm, first, a big thank you for the wonderful tool.
    I use it as my default IDE, but go over to the 'other' IDE every time I need to use the ICD.
    I believe you had released a plugin for Proton to be able to compile for ICD; is there a chance a similar feature would be available for PBP?
    Thanks again.
  21. #141
    Thanks again.
    Glad to see your making good use of FL!
    It wasn't me who made the ICD plugin for Proton.
    There are no plans to add one to FL as time doesn't permit.
    FL does include a "Compile and MPLAB sim" button to help load for sim in MPLAB however.
    Else continue to use the "Open in Orig IDE" to sim in Microcode Studio as needed.
    Norm
  22. #142
    Oh okay, thanks for the prompt response.
  23. #143
    FineLineIDE v3.2 is now available.
    FL v3.1 changes FL's method of opening files as some users files didn't fully open.
    FL v3.2 replaces non English text with spaces on open, paste and save.
    The non English text was causing FL to freeze as FL does not support UNICODE.
    Norm
  24. #144
    FineLineIDE v3.3 is now available.
    v3.3 has a low profile toolbar with selectable large or small icons and view or hide individual icons.
    Should benefit laptops or smaller screens.
    Norm
  25. #145
    Sep 2010
    Las Vegas, NV
    The link takes you to the FineLine page but I cannot download the program. Anyone else having issues?
  26. #146
    Worked fine here. Took me to this page
    https://app.box.com/s/f1e9ab3i4vgres9nhdh3fahdumtq5jto
    I downloaded but have not had time to use it yet.
  27. #147
    Quote Originally Posted by AvionicsMaster1 View Post
    Its a little misleading about not previewing a zip file but it should download.
    Norm
  28. #148
    SWITZERLAND (french part)
    Default unlisted devices
    I can't find the 16F690 device in the list. Is it my eyes?
    On the other hand, I didn't find any clue about how to create new devices, if needed of course.
    Is this possible?
    Roger
  29. #149
    Default Re: unlisted devices
    Is this possible?
    See attached screenshot:
    FineLineIDE v3.3
    Norm
  30. #150
    My face finally revealed!!!
    Name:  2016-01-13 15_35_38-blind smiley face - Google Search.jpg
    Roger
  31. #151
    Lancashire
    Hi All
    Has anyone got V3.3 running on windows 10?. I can set PBP3 path etc in options but it forgets it after selection.
    Cheers Pete
  32. #152
    Quote Originally Posted by enigma View Post
    Hi All
    Cheers Pete
    Quick question: Did you check the box for the PBP3 path as in some cases there are multiple versions and click OK to close options?
    Norm
  33. #153
    Lancashire
    Hi Norm
    Yes, I tried both adding it manually and also ticking the box when its automatically found. It does the same thing with the compiler too. I did add it manually to the ini file and that worked. I`ve not done that yet for the compiler as I'd like to see why its happening.
    Cheers Pete
  34. #154
    Hi Norm
    Cheers Pete
    What directory is FineLineIDE.exe located?
    It may be a Windows protected directory which wont allow changes to the ini file.
    Try a new location even a folder on the desktop should work.
    Norm
  35. #155
    Lancashire
    Hi Norm
    Tried it root C: Program files, desktop even via dropbox. I can find and select for example the compiler, click OK then if I try to select a PIC from the dropdown I get "Find PBPx.EXE in Options". If I go back in the selection has gone. I`m wondering if its Windows 10 specific. Cheers Pete
  36. #156
    Hi Norm
    I see Windows 10 is still a free upgrade so I will see how it goes.
    Meanwhile perhaps you could try a new FL download in case the ini portion became corrupted.
    Norm
  37. #157
    I just now downloaded FL 3.3 onto a Windows 10 machine and it compiles OK and closes and reopens and compiles again.
    On compile FL does prompt to switch from PBP3 to prePBP3 when needed and if so you will need to find the other compiler in options but just once for each.
    Not likely but I wonder if administrative privileges are required for an ini save?
    Norm
  38. #158
    Lancashire
    Hi Norm
    I`m wondering if its permissions. If I edit the ini file manually and add in the paths its OK, it just wont select and add from the program. Long shot but have you a debug version which will log what's happening so I could provide you with some solid data. Cheers Pete
  39. #159
    Hi Norm.
    I just gave 3,76 version a test drive, but I can't seem to be able to select a device. The device drop down menu does not show any chip not can I write any device there.
    Then after trying to insert my chip in that window, it crashed. I have a crash report if you want me to send you.
    Hi Norm.
    Be sure the PBP compiler is located in options > PicBasicPro Compiler as FL searches for devices within that directory.
    I will add a message for instances when FL doesn't find the devices to prompt for locating the compiler. Also if a device is entered to take some safeguards.
    Norm
Members who have read this thread : 26
