+ Reply to Thread
Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 188
Thread: FineLineIDE
  1. #81
    Default Re: FineLineIDE
    Quote Originally Posted by c_moore View Post
    Hello Everyone,
    I am trying out FL IDE and get the same thing as in this FL1_6_0_0.pdf. The Code compiles fine inn the MCSEX IDE.
    Locate the error file and check the error message file path exactly against the actual file path for any differances.
    Post the file path.
    Norm
  2. #82
    Nov 2008
    Hi Norm,
    From what I can tell the paths are correct. The Path is C:\Users\Charlie\ Documents\PBP Projects. The project compiles fine using MCS.
    CharlieM
    Using PBP3
    MCSPX
  3. #83
    Hi Norm,
    Did you find the .ERR file?
    Open Windows explorer and browse to the "C:\Users\Charlie\ Documents\PBP Projects" directory.
    If not intentionally generate an error to see if it is found.
    Norm
  4. #84
    Nov 2008
    It's there but its called test.er instead of test.err
    CharlieM
    Using PBP3
    MCSPX
  5. #85
    I will start on an update to look for .er if .err isn't found.
    PM me your email address for a test copy.
    Norm
  6. #86
    Coming soon: FineLineIDE Code Collapse and AutoIndent!
    The most requested feature Code Collapse and perfectly indented code "as you type" should be ready this month (May 2012)!
    FL 2.0 is now in Beta.
    Norm
  7. #87
    Very nice indeed Norm! I know I've asked for that very feature and I appreciate the work!
    Have you looked at the possibillity of integrating source level debugging? (Hardware based (PICKit3 for example) not a software "stub" like in MCSP)
    Keep up the nice work!
    Somewhere I read a hardware vs software ICD would require a huge database of all PICs.
    Perhaps someone could further explain.
    Norm
  9. #89
    Nov 2008
    sense when is the debugger in MCSP a software debugger? I would like a software debugger. I think its one thing missing from the Proton IDE.
    CharlieM
    Using PBP3
    MCSPX
  10. #90
    c_moore,
    It's always been a software debugger. With that I mean that a call to a software routine is performed between each PBP command, much like OnInterrupt works. It does use the PIC hardware USART to communicate with the PC but that takes up firmware space and execution cycles.
    Norm,
    I'm afraid I don't know the details about how the hardware debugger works but I'd guess all the files needed are available since it IS possible to debug at the source level from within MPLAB. I think it uses the .coff file generated at compile/assembly time but I don't know what else is needed.
    Now available new FineLineIDE v2.0.0.0 with code collapse and auto indent!
    Collapse unused lines for better view of relevant code.
    Auto indent as you code for perfectly formatted indentation.
    Norm
  12. #92
    Aug 2008
    Portugal
    Thank you for your work Normnet!!!
    Thanks and Regards;
    Gadelhas
  13. #93
    I forgot to mention tabs was also added (smart and regular).
    Smart tabs advance to the next character following a space in the lines preceding.
    Regular tabs advance a preselected number of spaces.
    Norm
  14. #94
    Dec 2007
    Finland
    Hi Norm,
    I tested your latest version, but for some reason include files refuse to open. No matter if I use relative or full path to file locations.
    Any idea what might be wrong?
    In MicroCode Studio environment, include files are working OK.
    BR,
    -Gusse-
  15. #95
    Quote Originally Posted by Gusse View Post
    Hi Norm,
    Attachment 6647
    BR,
    -Gusse-
    Was this on compile or a click on the explorer window include file?
    Please post your
    INCLUDE "include_file_name.xxx"
    line of code.
    Norm
  16. #96
    Dec 2007
    Finland
    Click on the explorer view window.
    Please post your
    line of code.
    Norm
    Basically main program consist of several include files and this was one of them. Same thing with all the other include files, cannot open them.
    INCLUDE "..\incl\Variables_v0_1.pbp"
    It does not help if I change full path, c:\...
    No problems to compile the program.
    EDIT:
    Then other thing that I observed. If I reopen FL (it will open latest file), but then I cannot compile opened file. I have to open same file (Ctrl+O) and then FL can compile file OK.
    -Gusse-
  17. #97
    Dec 2007
    Finland
    Error window says: "Invalid Include File Path:[link to 1st include file]. Aborting Compile"
    PS. 20min timeout for editing sucks!!
  18. #98
    -Gusse-
    I havenít see the use of "..\" in an include before.
    The next version of FL will add that.
    INCLUDE "N-Bit_Math.pbp.txt" 'works OK
    INCLUDE "E:\1PBP3\Nbit Math\N-Bit_Math.pbp.txt" 'works OK
    INCLUDE "..\Nbit Math\N-Bit_Math.pbp.txt" 'not OK in this version of FL
    Could you provide more examples of the exact include line to see if their are more unanticipated items?
    Norm
  19. #99
    Dec 2007
    Finland
    No matter what I enter after INCLUDE, it does not open files ?!?
    Even if I place file in root (c:\) and try to open from there, no success. Also shortening name below 8 char didn't help.
    I downloaded v2 zip and extracted to C:\PIC\FineLine folder. I have not used earlier version of FL with this computer, so am I missing some plug-in or something or should zip include everything?
  20. #100
    FL first looks for the include file as written above in the directory in which your .pbp program is saved.
    Secondly it looks in the PicBasicPro compiler directory as set up in options.
    Third it does additonal searching but try the above first.
    The download includes everything.
    Norm
  21. #101
    Dec 2007
    Finland
    Works if include file is in the same folder as the main pbp (as you said),
    INCLUDE "Variables_v0_1.pbp"
    but if file is in different folder then it fails to open it (path in front of actual file is not working).
    Could this be fixed?
    I prefer kind of "modular coding", which means that I use a lots of includes in main pbp. All the code is in include files, which are located in different folder, etc ../include/ -folder to keep thing more clear and readable. This is working very well with MicroCode Studio.
    -Gusse-
  22. #102
    The INCLUDE command is part of PBP, the text editor used to write the code does not have anything to do with it.
  23. #103
    Correct; for compiling PBP finds the include files.
    Gusse may be opening the include files with a click in the explorer window.
    The next version of FL will also do an explorer open if the full path is provided in the include.
    I'm not sure how to code for a partial path as it could be anywhere on the hard drive and doing a search could take several minutes in some cases unless their is a way to limit it.
    Norm
  24. #104
    Dec 2007
    Finland
    Relative path should be always linked to main pbp-file folder (at least this is how it is done in MicroCode Studio), so that should fix the location in HD.
    -Gusse-
  25. #105
    -Gusse-
    You are saying if the include isn't in the main pbp folder it is within one of it's sub folders?
    Norm
  26. #106
    Dec 2007
    Finland
    It doesn't have to be a sub folder in main pbp-file folder. It can be any folder and path is point to it (same like in command prompt, i.e: "cd .." goes 1 level up for current folder).
    Example:
    If main pbp-file is located
    c:\pic\pbp\prog\
    and include files
    c:\pic\pbp\incl\
    In MCS I can do
    include "..\incl\[filename_to_be_included].pbp"
    so starting folder is "c:\pic\pbp\prog" and then it goes one level up "c:\pic\pbp" and then to "incl"-folder, which is parallel to prog.
    -Gusse-
  27. #107
    -Gusse-
    So FL should look in main pbp file folder and all of its sub folders and all up clicks to root(C:\)?
    Norm
  28. #108
    I think PBP only looks in the directory the code is in and the directory PBP is in. Any other location needs to have the path to the include in the code. So look in the two default locations and parse the INCLUDE line for the other possible locations???
  29. #109
    -Gusse-
    Gusse
    Problem: Opening an include in FL explorer which is located in a parallel directory.
    I have written a include open routine which does what you have requested in FineLineIDE.
    In tests with MCS however I am unable to duplicate opening an .inc in: M:\PBP3\ABC INCLUDE
    with the .pbp program in: M:\PBP3\ABC PROGRAM
    when called out as: Include "...\ABC INCLUDE\TEST1.INC"
    I am using Microcode Studio 5.0.0.0 and compiler PBPX 3.0.1.4
    What versions are you using?
    I can email you a test version of FL with the new include routine if you PM me your email address.
    Norm
  30. #110
    Dec 2007
    Finland
    Hi Horm,
    There are still couple of issues that I noticed in brief trial with v2.0.0.1 BETA.
    If you re-open FL, then it cannot compile file. (require that file has been once openned with FL earlier). Same issue that I noticed also earlier.
    "Invalid Include Path: "..\incl\PIC18F4520_config.pbp" Aborting Compile"
    If you open same file again (with Ctrl+O or with button) then it will compile the file.
    Include files are accessible, but when you try to close them then FL says (pop-up):
    "FL THREAD ERROR 0" and there is OK button. Once pressed OK, another pop-up will come up with same error again. And again and again... Only by pressing "Close Tab" button again error message will disappear.
    At least I can repeat this issue when I open all include files and close FL, then re-open FL and try to close include tabs.
    Used test file: http://www.mediafire.com/?yty070ruqh4ycyh
    BR,
    -Gusse-
  31. #111
    Dec 2007
    Finland
    v2.0.0.2 BETA seems to work OK
    There is still an issue about saving & closing tabs. If you open and close tab without leaving tab and content is untouched, FL will not prompt "Save Changes" question. But if you change to other tab and return and then close without modifying tab content, FL always ask if you would like to save changes. I think this is minor problem but fixable.
    Good job Norm!
    BR,
    -Gusse-
    EDIT: If you click "***CURRENT LINE***" in exlorer view (includes), it tries to open same name include file without success. Could it be changed/removed?
  32. #112
    Nov 2008
    Monrovia, AL
    Thanks for writing such a nice editor, Norm.
    Locate the error file and check the error message file path exactly against the actual file path for any differences.
    Post the file path.
    Norm
    I'm seeing this behavior with 2.0.0.0:
    Source path is C:\Users\dlkerl\picstuff\oven
    The path is identical in the error message, but the file name in the source directory only has one 'R': OVEN_V0_3.ER (empty file)
    MCS launches PBP with no problems (PBP 2.45)
    Unrelated question: Is it possible to stop automatic indentation of labels in ASM blocks?
    Thanks-Dan
  33. #113
    Hey Norm,
    Could you make available the pre PBP3 version of FineLine. I am still having trouble on machines that do not have PBP3 with the current FineLine.
  34. #114
    Quote Originally Posted by lurker View Post
    Attachment 6662
    Thanks-Dan
    The .ER file is the PBP compiler text to assy error file.
    The .ERR file is the MPSAM assy to hex error file.
    Possibly the "Users" in C:\Users\dlkerl\picstuff\oven is throwing FL off?
    Try compiling with your program file in a non Users directory.
    Yes I should be able to disable all auto indent of assy lines if that would be best?
    Anyone familiar with assy please advise.
    I am presently finishing up the pre beta of FL 2.1.0.0 with several fixes.
    Norm
  35. #115
    Hey Norm,
    I have added an Archives Page.
    See FineLineIDE.
    Email me the trouble you are having.
    I am presently at pre beta 2.1.0.0 and this would be a good time to do fixes.
    Norm
  36. #116
    Thanks Norm,
    The problem is the same as mentioned in post #112 of this thread and if I recall correctly in another thread. When you added support for PBP3 older versions without the registration code from MeLabs does not work. The screen shot in post #112 is typical.
    Sooner or later everyone will be updated... but in my case I have more than three machines with PBP and I really do not want to pay the fee multiple times. So I am still using PBP2.6x on a few.
  37. #117
    Sep 2012
    Thank you for the program, upon start up i receive an access violation, it is probably because i have denied it access to the internet, can you tell me please why it calls home.
  38. #118
    Quote Originally Posted by pigglet View Post
    An access violation occurs when the program is attempting to read/write to an array element beyond the length of the array.
    Try temporarily renaming the FineLineIDE.ini file in the FL directory for a clean start up to see if that solves the problem.
    Norm
  39. #119
    Thanks Norm,
    Thanks again Norm!!!!
    The test "beta" program you gave me to try is working great!!!
  40. #120
    Oct 2009
    Utah, USA
    Hey Norm,
    Here is a suggestion for FineLine...
    How about having the ability to link a basic program to a schematic file. Or to be able to attach a drawing to a given program. That way when months or years later you open an old program you can easily pull up the schematic for the project.
    Just a thought... possibly it would be just as easy to reference the given schematic in the notes or comments at the beginning of your program.
    others thoughts??
    Dwight
Members who have read this thread : 23
