Xbee Communication (simple Question)
+ Reply to Thread
Results 1 to 2 of 2
    gmdii80's Avatar
    gmdii80 Guest
    Default Xbee Communication (simple Question)
    This is basically a no brainer.. the prob is i cant think right now.
    Does the Xbee need to connect to the RX and TX lines of the PIC or will any Pin work?
    I have PIC 16F876A and my RX, TX lines are used Elsewhere.
    Thnx.
    gmdii
    Loveland CO USA
    From my bad memory....
    There is a hardware serial command that must use RX & TX pins.
    There is a 'software' serial command that can use almost any pin.
