Need help on ADC : Software R/C filter
Results 1 to 4 of 4
    May 2007
    Area 71
    Default Need help on ADC : Software R/C filter
    Instead of hardware R/C filer to delay ACD input, is it possible to do it with PBP ?
    Depends on what you need.
    FFT, Sorting and Average, DSP are some ideas.
    What is your application?
    What is your PIC?
    What is your data to filter?
    Maybe also your current program?
    May 2007
    Area 71
    Hi Ioannis,
    My application is simple, it just read the potentiometer / analog pins and then output the pulse accordingly.
    Usually I put a hardware RC filter between the pots and the pins. It serves as delay
    'PIC 12F683
    OSCCON = $60                    ' Internal oscillator frequency 4 Mhz
    TRISIO = %00000011              ' Set TRIS to all input
    ANSEL = %00000011               ' Analog channel RA0 & RA1
    ADCON0= %00000000               ' VDD as VREF
    CMCON0 = 7
    DEFINE ADC_BITS 8               ' ADC resolution 8 bit
    DEFINE ADC_CLOCK 1              ' Set clock source (rc = 1)
    DEFINE ADC_SAMPLEUS 11          ' Sampling time 11ms
    anpin0 CON 0                 ' Analog port pin RA.0
    anpin0val VAR byte            ' Value digital 0 - 255
    anpin1 CON 1                 ' Analog port pin RA.1
    anpin1val VAR byte             ' Value digital 0- 255
    PAUSE 1000
    LOOP:
    adcin anpin0,anpin0val
    adcin anpin1,anpin1val
    pulsout porta.4,anpin0val
    pulsout porta.5,anpin1val
    pause 10
    goto loop
    The great Tracey Allen has a couple of filter routines here. Make sure you read thry the explaination as it describes how to alter the timeconstant etc. Then there's Darrels averaging routine which might be interesting as well.
