how to hserin compare with known value?
Results 1 to 7 of 7
    Oct 2008
    Post how to hserin compare with known value?
    hi all ,
    this is my first post and i hope help from all .My problem is i can not compare my file my file is
    $07 $06 $0D $CA $2E $56 $00 $C9 $77 .when this file recive i want flash led portc.3 on with pic16f688. i get corect boud 115200 with crystal 11.0592 Mhz i also check hserin and hserout
    same. my code is below
    @ DEVICE PIC16F688, HS_OSC, WDT_OFF, PWRT_OFF, MCLR_OFF, BOD_OFF,PROTECT_OFF
    DEFINE HSER_SPBRG 5 ' 115200 Baud @ 11.0592MHz, 0.0%
    RCSTA = $90 ' Enable serial port & continuous receive
    TXSTA = $24 ' Enable transmit, BRGH = 1
    SPBRG = 5 ' 115200 Baud @ 11.0592MHz, 0.0%
    ANSEL = 0 'ALL DIGITAL
    INTCON = 0 'Disable interrupts
    DATAIN VAR byte[9]
    HSERIN [WAIT($07), str DATAIN\8]
    'if datain = $07,$06,$0D,$CA,$2E,$56,$00,$C9,$77
    hserout [str datain\9]
    sorry for my english
    Sep 2009
    Try something like this
    if datain[0] = $07 and  datain[1] =$06 and  datain[2] =$0D  and  datain[3] =$CA  and  datain[4] =$2E  and  datain[5] =$56 and  datain[6] =$00 and  datain[7] =$C9  and  datain[8] =$77 then hserout [str datain\8]
    or this
    str[0]= $07:.....:str[7]=$77
    for i = 0 to 8
    IF str[i]<>datain[i] then goto DO_NOT_SEND
    next i
    do_not_send:
    Oct 2008
    first of all many thanks for repply dear pedja089
    now my code like this,
    if datain[1] = $06 then high portc.3
    this not working
    Sep 2009
    Datain[1] is second byte in string.
    If you wait number 7, then that byte isn't in datain array.
    If you sent 7,6,12, then in datain first byte is 6, second is 12, so you need something like this
    if datain[0] = $06 then high portc.3
    And now if you send 7,then 6, and 6 more byte portc will go high.
    Oct 2008
    many many thanks dear pedja089
    now code is working
    what methed in short becuse i have too bytes for compare for example
    hex :07 06 00 82 2D A1 00 D7 D8 , 07 06 00 82 2D CF 35 C4 90 , 07 06 00 82 2E 2F 35 C4 73 , many more ,so
    i want further help?
    Sep 2009
    Try both ways and see which is faster.
    Oct 2008
    thanks ,
    now i want write this 9 byte data and read its back .How this posible my mean how to write aray and read it again.
