I cannot get the PLL to turn on. I can set the INTRC oscillator to 4 MHz or 8 MHz but I cannot get the 4x PLL to activate. I have scoured the forum but found nothing directly relevant.
MCS+ 3.0.0.5 PBP 2.60L MPASM v5.37
I want to get an internal RC clock of 16 or 32MHz so then I can push the DEBUG speed up.
Any help gratefully received.Code:'************ Config Register setup for USB programmer ************* ' OSC = INTIO2, FSCM = En, IESO = En, PwrupTmr = En, BrownOut = Dis ' BOR Volts = 2, WDT = Off, WDTPS = 1:512, CCP2 mux = RB3, ' PortB reset = Digital, LPT1Osc = Low, MCLR = Reset, LVP = Disabled ' Enhanced CPU = Dis, All memory = Not Protected '******************************************************************* DEFINE OSC 4 'IntOsc <= 32MHz @ 3.7V OK. See page 325. DEFINE DEBUG_REG PORTB 'Debug output pin port DEFINE DEBUG_BIT 6 'Debug output pin bit (= PGC) DEFINE DEBUG_BAUD 28800 'Debug baud rate DEFINE DEBUG_MODE 0 'Debug mode: 0 = True, 1 = Inverted 'DEFINE DEBUG_PACING 50 'Debug character pacing in us ' OSCCON = %01101111 ' Select 4 MHz OSCCON = $62 ' also selects 4 MHz ' OSCCON = %01111111 ' Select 8 MHz ' OSCTUNE = %01000000 'PLL ON, at centre frequency OSCTUNE.6 = 1 ' PLL ON ' OSCTUNE = %00000000 'PLL OFF, at centre frequency
BrianT
