+ Reply to Thread
Results 1 to 6 of 6
Thread: enfora gsm to pic 16f877
    Feb 2010
    Default enfora gsm to pic 16f877
    First of all i would like to thank everyone in this forum for their help and support, This form helped me a lot and i thank you for it.
    i Just bought an enfora rs232 gsm modem which i tested with hyperterminal at baud 9600 and i was able to send sms as well as receiving tried a lot of AT command 100% working.
    I have succeded to conect my pic(16f877) to rs232 using serout2 and serin2 without max232 using the hardware inverter(baud=16468), Every project with pic to rs232 has been a succes!!.
    Now i want to connect the modem to my pic and all went wrong, Here what i tried:
    1) set the pic baud=84 for non inverted(9600) to talk to the mode no luck(no max232,since the modem talking to the serial port then no need for inverter)
    1)baud=16468 same as above
    2)on the gsm rs232 i tied pins 1,4,6 and 7,8(handshaking) no luck
    i read a lot of post here regarding gsm and i noticed most of the codes using hserout which required max232 why not using serout2 with inverted or debug?
    Also most of the posts recommend using 20mhz i'm only using 4mhz will that cause a problem? i think since the modem is working 100% at 9600 baud using hyperterminal it should work with the pic @9600.
    Any help is appreciated.This this my first post so please help!!!!
    Best regard,
    4MHz is border line for 9600 baud. That is mentioned in the manual.
    Other problems could be in your code. You need to post it so the GSM guys can see what you are doing.
    http://mackrackit.cambs.net/
    Feb 2010
    Default Enfora Gl GSM
    Thank for the reply. As for the code i'm just using a simple code to check the modem respose(OK):
    Include "modedefs.bas"
    '***************************LCD DEFINE*******************************
    DEFINE LCD_DREG PORTD 'LCD data port
    DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTD 'LCD register select port
    DEFINE LCD_RSBIT 4 'LCD register select bit , RS=PORTC.4
    DEFINE LCD_EREG PORTD 'LCD enable port
    DEFINE LCD_EBIT 5 'LCD enable bit E=PORTC.5
    DEFINE LCD_RWREG PORTD 'LCD read/write port
    DEFINE LCD_RWBIT 6 'LCD read/write bit R/W=POTRA.1
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 4 'Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 'Command delay time in us
    DEFINE LCD_DATAUS 50
    ADCON1 =7
    TRISA = $FF
    TRISB = 0
    TRISC = 0
    TRISD = 0
    TRISE = 0
    LCDATA VAR BYTE(8)
    CLEAR
    PAUSE 1000
    LCDOUT $FE,1
    LCDOUT $FE, 2
    LCDOUT " STARWICK GSM V1.0"
    MAIN:
    serout2 PORTC.6,84, ["AT",13,10]
    SERIN2 PORTC.7,16468, [WAIT("OK")]
    LCDOUT $FE,$C0
    LCDOUT "OK"
    SEROUT2 PORTC.6,84,["AT+CMGR=1",13,10]
    SERIN2 PORTC.7, 84,[STR LCDATA\8\13]
    LCDOUT $FE,1
    LCDOUT $FE,2
    LCDOUT STR LCDATA\8
    PAUSE 3000
    GOTO MAIN
    I don't get any response from the modem. i also tried SERIN2 PORTC.6.84,[STR LCDATA\2] And display LCDATA with no luck. Thanks for any help.
    Feb 2010
    Default on step forward
    so far i was able to send A TEST sms via the pic from the gsm modem no max232 4mhz 16F877 below is the code:
    MAIN:
    Serout2 PORTC.6,16468, ["AT",13,10]
    SERIN2 PORTC.7,16468,[WAIT ("OK")]
    LCDOUT $FE,$C0
    LCDOUT "SENDING MESSAGE..."
    SEROUT2 PORTC.6,16468,["AT+CMGS=",34,"18155295213",34,13,10]
    PAUSE 1000
    SEROUT2 PORTC.6,16468,["TEST FROM PIC",13,10]
    PAUSE 1000
    SEROUT2 PORTC.6,16468,[26]
    LCDOUT $FE,$C0
    LCDOUT "MESSAGE SENT "
    PAUSE 1000
    Now corredct me if i'm wrong the pic will not pass the second line of the code(SERIN2 PORTC.7,16468,[WAIT ("OK")]) unless it received OK is that coreect? That means that the pic is receiving the correct chars from the gsm correct?
    will try to send and read to an array.
    Thanks for any response or help....
    Best regards,
    Joe
    That is correct.
    Feb 2010
    Post still mtestin
    Thanks a lot for the response.
    Here is the latest i was able to receive a text messege,TIME, caller id(C_ID) and dispaly the exact length of the message.
    I don't know why but it seems that the modem is responding with the commands i send first then the answer for ex :
    SEROUT2 PORTC.6,16468,["AT+CMGR=1",13,10]
    the modem will respond AT+CMGR=1 THEN the rest (+CMGR: "REC........"), I found that by making LCDATA var byte(80) and display all 80 chars received(max chars in my 20x4 lcd), But the modem will not do that with hyperterminal if you enter AT+CMGR=1 in hyperterminal the response will be ERROR if no messages or +CMGR:....., So i decided to just look for READ after AT+CMGR=1 and... and it worked.rs232 at the modem side is 4=6 and 7=8 before i tried 1=4=6 but the modem didn't respond at all.
    MAIN:
    serout2 PORTC.6,16468, ["AT",13,10]
    SEROUT2 PORTC.6,16468,["AT+CMGR=1",13,10]'read messaage at SIM #1
    SERIN2 PORTC.7,16468,[wait ("READ"),SKIP 4,STR C_ID\11,SKIP 4,STR TIME\17,SKIP 6, STR LCDATA\20\10]
    LCDOUT $FE,1
    LCDOUT $FE,2
    LCDOUT STR TIME\17 'display date and time
    FOR J=1 TO 20
    IF LCDATA(J)=13 THEN' wait for 13 char then put in LA where la is length of the message
    LA=J
    GOTO GOTLA
    NEXT J
    GOTLA:
    LCDOUT $FE,$C0
    LCDOUT "SMS LA=", DEC LA ' display the length of the message
    LCDOUT $FE,$D4
    LCDOUT STR LCDATA\LA'display the message
    since i got the WAIT command to work and i used it to read the messages, I don't care if it is read or unread for now i only sent one message and i try to read it. Still having problem with the connection between the pic and the modem with the above setup will work but when i turn the power off it may work or not then i try again and it will work, I don't know if it's a speed problem as you mention before or just a loose connection(breadboard)...
    Once again thank for any help
    Hi, we are pleased to see that you are using our forum.
    We'd like you to become a member of our community. Membership is FREE, please REGISTER and view our forums without these annoying reminders!
    Once registered you may post on the forums, download from the file areas and use the WIKI without interruption.
    Best regards,
    Joe
+ Reply to Thread
Members who have read this thread : 10
