32 and 64bit Floating Point, PBP and a 16F648A...
Results 1 to 8 of 8
    Default 32 and 64bit Floating Point, PBP and a 16F648A...
    I need to process some GPS data that is in 32bit and 64bit Floating Point format.
    My PIC16F648A project gathers serial data from a GPS Disciplined Oscillator unit and stores it in a array.
    This past week I didn't even know what 32 or 64bit Floating Point was, now I understand how to assemble the floating point data into a decimal number, from the HEX bytes, on paper. But, I need to have PBP do the math for me.
    Here is an example of the oscillator temperature data in 32bit FP:
    MSB..........LSB
    41E99BBE
    Here is what I have been trying to do with PBP...
    The following code ignores the 'Sign' bit in Byte1 and is to extract the 'Exponent' from the next 11 bits.
    B0 = 0 'EXPONENT
    B1 = BYTE1.BIT6
    IF B1 = 1 THEN LET B0 = B0 + 128
    B1 = BYTE1.BIT5
    IF B1 = 1 THEN LET B0 = B0 + 64
    The following code example is to extract the Mantissa from the remaining bits
    B2 = 0 'MANTISSA
    B3 = BYTE2.BIT3
    IF B3 = 1 THEN LET B2 = B2 + .5
    B3 = BYTE2.BIT2
    IF B3 = 1 THEN LET B2 = B2 + .125
    Unfortunately, I get the following PBP messages when trying to compile.:
    ERROR Line 158: Bad variable modifier: .125.
    ERROR Line 158: Bad expression. (vmon5_0.pbp)
    Is there an easier way?
    John
    See N-Bit_MATH
    Norm
    Jul 2010
    Thanks Norm, I will see if that thread can help me out. I should have mentioned the oscillator temp of $41E99BBE is decimal 36.25xxxxxx degs C.
    John
    Jul 2010
    I give up, how do I get $3FE3586328F97ED5 AND $C000D1A6DD4B949E into the N-Bit Math Value32 variable?
    The above two 64 bit hex numbers reside in an array and represent latitude (34.xxxxxx) and longitude (-120.xxxxxx).
    John
    Wow, is your gps accurate to 3.6 inches? I wish mine was.
    http://www.scalerobotics.com
    Quote Originally Posted by N6VMO_ View Post
    What format are they in the array. ASCII hex digits or Binary values?
    Are they always the same length? With padding 0's to the left if lower values?
    And you mean a Value64 variable, right?
    Jul 2010
    Him Darrel,
    The data is stored in ASCII hex digits and are always the same length. Yes, I meant Value64.
    Well, assuming you have PBP 2.60, and the number starts at the beginning of the array, you could do this ...
    ARRAYREAD  MyArray,[HEX2 Value64(7),HEX2 Value64(6),HEX2 Value64(5),HEX2 Value64(4), _
                        HEX2 Value64(3),HEX2 Value64(2),HEX2 Value64(1),HEX2 Value64(0)]
    You can add a SKIP n, if it starts later in the array.
    HTH,
