size of program vs mem on pic
Results 1 to 2 of 2
    PICMAN's Avatar
    PICMAN Guest
    Default size of program vs mem on pic
    ok microcode studio compiles my program, its set for the right pic,
    it says 314 words used, how does this relate to memory in pic chips, im curently planing on using pic 16f84a, (asuming it can handle the code)
    i plan to add a lil bit of code still but after seeing how many words im using i think mebe i need to check on how many it can hold,
    if 450 words is more then pic can hold is there pin compatable which meets requirements?
    MicroCode return Bytes of code. If your PIC is out of memory, MicoCode is suppose to tell you.
    If you want to have more codespace with the same pinout, as i know, all 18pins have the same. Common replacement used : PIC16F628 with 2K of code space.
    I post some links here
    See PIC Selector guides section.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. vb6 to program PIC
    By redpeak in forum mel PIC BASIC Pro
    Last Post: - 1st September 2009, 00:25
  3. Octave synthesizer PIC program for PIC16f84A
    By esgrimae in forum Code Examples
    Last Post: - 21st July 2009, 05:15
  4. Making Program Code Space your playground...
  5. program a pic 12f629
    By cancan in forum General
    Last Post: - 28th April 2008, 16:15
