This example shows how to switch between internal & external oscillators, with a POT to adjust cycle speeds of the LED bargraph on the LAB-X1 board.
' Name        : BLINK1934X.pbp
' Compiler    : PICBASIC PRO Compiler 2.6
' Assembler   : MPASM
' Target PIC  : 40-pin 16F1934 or similar
' Hardware    : LAB-X1 Experimenter Board
' Oscillator  : 4MHz external crystal
' Keywords    : ADCIN, DO LOOP, EXIT, FOR NEXT, REPEAT UNTIL, STEP
' Description : PICBASIC PRO program to cycle bargraph LEDs on PORTD in different
' patterns, with speed control & oscillator switching from external to internal.
' Uses POT1 on RA0 to set cycle speed, and keypad button #13 to alternate between
' LED patterns & oscillator selection.
' Note: Open the 16F1934.INC file in your PBP directory, and comment out the default
' __config settings.
   __config _CONFIG1, _FOSC_XT & _WDTE_SWDTEN & _PWRTE_ON & _MCLRE_ON & _BOREN_ON & _IESO_ON & _FCMEN_ON
   __config _CONFIG2, _PLLEN_OFF & _LVP_OFF & _VCAPEN_OFF & _STVREN_ON & _BORV_25
' Define ADCIN parameters
Define  ADC_BITS     10  ' Set number of bits in result
Define  ADC_CLOCK    4   ' Set clock source Fosc/4
Define  ADC_SAMPLEUS 50  ' Set sampling time in uS
i     Var Byte           ' Define loop variable
Delay Var Word           ' LED delay time
LEDS  Var PORTD          ' Alias PORTD to LEDS
   Gosub Init            ' Hardware initialization routine
mainloop:
   LEDS = 1              ' First LED on
   Do
     For i = 1 To 7      ' Go through For..Next loop 7 times
       LEDS = LEDS << 1  ' Shift on LED to the left
       Gosub GetDelay    ' Get new Delay value
       Pause Delay       ' Pause for Delay period
     Next i
     ' Exit allows us to exit the loop mid-stream
     IF !PORTB.4 Then Exit ' Exit Do Loop if key pressed
     For i = 7 To 1 Step-1 ' Go through For..Next loop 7 times
       LEDS = LEDS >> 1  ' Shift on LED to the right
     Next i
   Loop Until PORTB.4 = 0  ' Loop until press on keypad button #13
   ' Flipping OSCCON.1 to 1 selects the internal oscillator.
   ' Flipping OSCCON.1 to 0 selects the external oscillator.
   OSCCON.1 = 1        ' Switch from 4MHz external to 16MHz internal oscillator
   Repeat              ' Change LED pattern on keypad button #13 press
     Gosub GetDelay
     LEDS = %00011000
     Pause Delay
     LEDS = %00100100
     Pause Delay
     LEDS = %01000010
     Pause Delay
     LEDS = %10000001
     Pause Delay
     LEDS = %01000010
     Pause Delay
     LEDS = %00100100
     Pause Delay
   Until PORTB.4 = 1   ' Repeat above until keypad button #13 is released
   OSCCON.1 = 0        ' Switch back to external 4MHz oscillator
   Goto mainloop       ' Blink LEDs forever
GetDelay:
   Adcin 0,Delay       ' Read POT1 on RA0 input for 10-bit Delay value
Init:
   OSCCON = %01111000  ' Internal osc is 16MHz, but using external for now
   TRISD = 0           ' Set PORTD to all outputs
   TRISB = %11110111   ' RB3 to output, rest inputs
   PORTB.3 = 0         ' RB3 low for keypad button #13 low input
   ANSELA = 1          ' Set PortA 0 to analog POT1 input, rest digital
   ANSELB = 0          ' portb all digital
   ANSELD = 0          ' portd all digital
   ANSELE = 0          ' porte all digital
   ADCON1 = %11000000  ' Right justify for 10-bit, Fosc/4, +Vref/-Vref = Vdd/gnd
   OPTION_REG.7 = 0    ' Internal pull-ups on (RB4 is held high until key #13 is pressed)
   Return              ' Setup complete, return to caller
