Use Timer1 Gate to Capture Pulse Widths
THE BOOK of DT's INTERRUPTS is an organization of interrupt service routines and other works written by Darrel Taylor, RIP.
Interrupt routines are arranged per Darrel's original list. Darrel Taylor's Instant Interrupts are an extension of the work of Tim Box whom in October of 2002 wrote INT_CTRL.pbp
Many of the forum members felt this is a long overdue project.
will be a valuable resource and a tribute to Darrel Taylor the "Fanatical Contributor".
THE BOOK of DT's INTERRUPTS is located at http://dt.picbasic.co.uk/
+ Reply to Thread
Results 1 to 2 of 2
    Default Use Timer1 Gate to Capture Pulse Widths
    Here's an example of using the Timer1 gate peripheral to capture/display external pulse widths on an LCD. This PIC has a lot of cool features.
    ' Name        : T1G_1934X.pbp
    ' Compiler    : PICBASIC PRO Compiler 2.6
    ' Assembler   : MPASM
    ' Target PIC  : 40-pin 16F1934 or similar
    ' Hardware    : LAB-X1 Experimenter Board
    ' Oscillator  : 4MHz external crystal
    ' Keywords    : LCDOUT
    ' Description : PICBASIC PRO program to demonstrate using Timer1 gate
    ' in single-pulse mode to capture single pulse event times.
    ' Port B4 connects to port B5 (Timer1 gate), and provides pulse to
    ' measure by setting B4 high, pausing, then to setting B4 low.
    ' Note: Open the 16F1934.INC file in your PBP directory, and comment out the default
    ' __config settings.
       __config _CONFIG1, _FOSC_XT & _WDTE_SWDTEN & _PWRTE_ON & _MCLRE_ON & _BOREN_ON & _IESO_ON & _FCMEN_ON
       __config _CONFIG2, _PLLEN_OFF & _LVP_OFF & _VCAPEN_OFF & _STVREN_ON & _BORV_25
    ' Define LCD pins
    Define LCD_DREG  PORTD
    Define LCD_DBIT  4
    Define LCD_RSREG PORTE
    Define LCD_RSBIT 0
    Define LCD_EREG  PORTE
    Define LCD_EBIT  1
    Pval Var Word    ' Holds pulse time from Timer1
       Gosub Init    ' Hardware initialization routine
       Lcdout $fe, 1 ' Clear LCD at POR
    mainloop:
       PORTB.4 = 1   ' Toggle RB4 on Timer1 gate pin high
       Pauseus 1550  ' Set pulse time by adjusting pause value here
       PORTB.4 = 0   ' Toggle Timer1 gate pin low to stop Timer1
       Pval.LowByte = TMR1L   ' Read Timer1 value
       Pval.HighByte = TMR1H
       Lcdout $fe, 1, "High Pulse = ",DEC Pval,"uS"
       Gosub Reset   ' Clear Timer1 count & reset T1 gate
       Pause 500
       Goto mainloop ' Do it forever
    Reset:
       T1GCON.3 = 1  ' Reset Timer1 Gate Single-Pulse Acquisition Status bit
       TMR1H = 0     ' Clear previous count
       TMR1L = 0
    Init:
       ANSELA = 0    ' porta all digital
       ANSELB = 0    ' portb all digital
       ANSELD = 0    ' portd all digital
       ANSELE = 0    ' porte all digital
       TRISB = %00100000  ' RB5 = input for T1 gate, RB4 = output to gate
       PORTB = 0          ' Hold T1 gate low at start
       T1CON = %00000001  ' Timer1 on, clock is internal Fosc/4
       T1GCON = %11011000 ' Timer1 gate enabled, active high, single-pulse mode
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    brighton
    Default Re: Use Timer1 Gate to Capture Pulse Widths
    Bruce can this be applied to pic18f452?
