pic16f886
Results 1 to 6 of 6
Thread: pic16f886
    May 2010
    Default pic16f886
    hi,
    i would like to ask if anyone hv use pic16f886...i do have problem dealing with port A and B..is there any configuration that i need to for this 2 ports?
    thanks
    I've never used it but that chip has analog functions (ADC and comparator inputs) across both PortA and PortB.... You're not saying what the problem you're having IS but a wild guess is you're not using them for analog inputs, yet you haven't configured them to be digital I/O's.
    See the ADC and comparator section in the datasheet.
    May 2010
    Thumbs up pic16f886
    the problem is that when i connect a switch at port A&B it's not working....but when i connect the switch at port C it's OK....i'll the datasheet again...thanks for the info....
    As Henrik pointed out, its most likely because you havent disabled the ADCs and the comparators. If you dont need them, perhaps the easiest way to do it in one stroke is to use DT's Alldigital.pbp as an include. Check this thread:
    http://www.picbasic.co.uk/forum/showthread.php?t=11100
    Should solve your problem.
    Anand
    May 2010
    Smile
    tq for the idea....i would like to ask any of you to check my code...it seems like noting wrong but when the m=1 suppose that there is something display...but notting happens accept for OK that been send by XBEE....
    @ DEVICE HS_OSC
    define OSC 20
    DEFINE HSER_BAUD 9600
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 129
    ANSEL = 0          'All Digital, konfigurasi ini utk jadikan semua port
    ANSELH = 0          'digital utk high, low, serin/out, if.
    'DEFINE OSC 8
    'OSCCON = %01110001
    dta1 var word
    LED var PORTb.0
    m var PORTb.1
    bilangan var byte
    main1:low LED
    if m = 1 then main
    serout2 portb.2, 16468,["SELAMAT DATANG KE CEDEC...:",34,13,26]
    pause 200
    goto main1
    main: high LED : pause 300
    hserout ["+++"]
    'hserout ["+"] Pause 50:hserout ["+"]Pause 50:hserout ["+"]
    hserin 2000,main1,[dta1(0),dta1(1)]
    'For bilangan = 0 to 2
        'HSerIn 2000,main1,[dta1(bilangan)]
    'Next bilangan
    'hserin 3000, main1,[wait("OK"),dta1]
    serout2 portb.2, 16468,[dta1(0), dta1(1)]
    pause 2000
    in : if m = 1 then main1
    hserout ["ATID 100"]: pause 50:hserout [26]
    'hserout ["ATID",26] : pause 200: hserout [26,13] ause 500
    hserin 2000, in,[dta1(0),dta1(1),dta1(2)]:pause 200
    serout2 portb.2, 16468,[dec dta1(0),dec dta1(1),dec dta1(2)]
    low LED : Pause 200
    goto main1
    thanks
    May 2010
    Post read at command from xbee using picbasic
    hi guys...
    as the above title clearly state...i would like to how to read AT command from XBEE using picbasic....thanks...
