Hi all!
After trying to build RC5 InfraRed Transmitter for a week
i'm quite frustrated.
I'll be much obliged if anyone could help me with it.
Hi all!
Better are your chance to have an answer if you provide all the details
code
pic used
schematic
some beer
John,
Have a look here: http://www.picbasic.nl/indexes_uk.htm
It's the site from a guy who made some RC5 applications.
The programs are written with Proton Plus so the timing, which is quite important in RC5, might not be correct.
I tried some of the apps. with the PBP compiler and it didn't work.
However when I tried a test version of Proton it worked.
So remember timing issues are to be solved when using PBP.
I ripped the interesting parts from a working program. It transmits RC5 codes via an IRLED, modulation is 38.5kHz. Not exactly 38kHz but close enough. There are loads of information on the net regarding addresses, commands and all the rest you need to know about RC5.
This link seems to cover just about all you need to know.
http://info.fuw.edu.pl/~pablo/s/opis...dge/ir/rc5.htm
Have fun.
/Ingvar
Code:DEFINE OSC 4 SendIRword VAR WORD SendIRcommand VAR BYTE SendIRaddr VAR BYTE SendIRtoggle VAR BIT SendIRbit VAR BIT Counter VAR BYTE SendIRpin VAR PortB.0 'connect IRLED via resistor to ground LOW SendIRpin Send_IR: SendIRword = %0000000000000110 SendIRword = (SendIRword + SendIRtoggle) << 5 SendIRword = (SendIRword + SendIRaddr) << 6 SendIRword = (SendIRword + SendIRcommand) FOR bitcounter = 13 TO 0 STEP -1 SendIRbit = ~(SendIRword.0(bitcounter)) GOSUB ToggleSendPin SendIRbit = SendIRword.0(bitcounter) GOSUB ToggleSendPin NEXT SendIRpin = 0 RETURN ToggleSendPin: IF SendIRbit THEN FOR Counter = 1 TO 34 SendIRpin = 1 ASM nop nop nop nop nop nop nop nop ENDASM SendIRpin = 0 ASM nop nop nop nop nop nop nop nop ENDASM NEXT ELSE PAUSEUS 875 ENDIF RETURN
TIP OF THE DAY: never trust anybody else than youOriginally Posted by jrt4fun
assembly code for RC5 TX
RC5 TX
Paramotor, could you send to me that RC5 TX code?
[email protected]
Thanks a lot!!!
