ADCIN signal conditioning?
Results 1 to 12 of 12
    Nov 2004
    Calabasas, CA
    Default ADCIN signal conditioning?
    I am trying to read a vehicle speed sensor but the LCD output is bouncing all over the place.
    My DMM readout is nice and constant. How can I get good readings?
    What I have done is slow down the sampling time to 20mS.
    Took 25 consecutive samples, and even saved the highest value of the 25, but no help.
    How does the DMM do it?
    I am using a PIC 16F716 on PORTA.
    This is my setup:
    ADCON1 =0 'PIC default, sets PORTA to analog
    DEFINE OSC 3 '3.56 MHz oscilator
    DEFINE ADC_BITS 8 'Result resolution
    DEFINE ADC_CLOCK 3 'Sets internal RC clk(2-6us)
    DEFINE ADC_SAMPLEUS 20000 'Cap sample time of 5us
    I am using this:
    ADCIN 0,vss
    and I've tried this:
    ADC: w2 =0 'Clear var
    For b11 = 1 TO 25
    ADCIN 0,rpm 'Obtain another ADC value
    w2 = w2 max rpm 'save peak vals
    Next b11 'Repeat for 10 samples
    For a constant DMM reading of say 1.750V, my ADC output bounces between 0 & 186.
    James
    Sep 2005
    Campbell, CA
    Do you have PORTA set up as inputs?
    Do you have them set up for analog?
    What are you using for your reference (ADCON1) ? Most of the time, Vcc is not good enough.
    If you want really good accuracy, you have to use an external, precision reference.
    Charles Linquist
    Sometimes a capacitor from the ADC pin to VSS will smooth things out.
    Nov 2004
    Calabasas, CA
    I'll see what a 0.1uF does.
    James
    Nov 2004
    Calabasas, CA
    Quote Originally Posted by Charles Linquis View Post
    Yes, TRISA =255
    ADCON1 =0 (as noted in my setup above?)
    ADCON1 =0 sets Vdd as thew ref I believe.
    Really good accuracy would be nice. Right now I have no accuracy.
    James
    You could try Darrel's averaging include file.
    http://sites.picbasic.net/index.php?...d=70&pageid=25
    Nov 2004
    Calabasas, CA
    I'll have a look see.
    James
    Sep 2005
    Campbell, CA
    If your value goes to zero, there is something more wrong than a little noise. I have found some chips that don't work properly with ADCIN (18F2221 for example).
    Try the following:
    Result = 0
    Channel = 1                     ; Whichever
    Channel = Channel << 3   ; offset the bits
    ADCON0 = %11000001 | Channel  ; OR the channel into the reg.
    For X = 0 to 9
    PAUSEUS 10
    ADCON0.2 = 1     ; Start conversion
    PAUSEUS 2         ; Guarantee min time
    WHILE ADCON0.2:WEND   ; Wait until done
    Result = Result + ADRES
    Next X
    Result = Result/10
    Result is, of course, a WORD var
    Charles Linquist
    Nov 2004
    Calabasas, CA
    Charles,
    This sensor pulses hi to low. I suspect some of my sampling is reading on the low part of the cycle. Thats why I slowed way down the sampling time to 20ms.
    ADC has worked well for me on this PIC.
    I will look at your subr.
    James
    Sep 2005
    Campbell, CA
    Quote Originally Posted by droptail View Post
    Charles,
    An analog sensor that pulses high to low? I don't understand. What sensor are you using.
    Charles Linquist
