How to Read / Write I2c 24LC16B EEprom
Results 1 to 3 of 3
    Feb 2010
    Indiana
    Default How to Read / Write I2c 24LC16B EEprom
    This is my first ever post...
    I read a lot but not enough...
    I am using an 18F4520 pic with a 24LC16B external EEprom with proper pullups ect.
    Circuit works great using the I2CRead and Write commands with Word addresses and Byte Variables for the data.
    I am having lots of difficulty getting it to work with word size Variables in the data to read and write.
    I understand from the spec sheet that the 16B is a byte size variable and a word size address and using this I2Cwrite command
    addsout var word
    myvariable var byte
    I2CWRITE DPIN,CPIN,$A0,addsout,[myvariable]
    This works great for numbers <=255
    I need numbers stored <= 65535 which requires a WORD size stored variable.
    I have tried so many different ways to Highbyte Lowbyte the data - I have lost count.
    Please Help!
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default Writing to external EEPROM
    Odie52,
    Here is an example of writing 16 bytes, in one go, to external EEPROM. Some of the variables are byte sized:
    ' * EEPROM WRITE. 512k EEPROM used. Control Byte for this one is $A8          *
    ' * Stores weather readings, 16 bytes/Record.  4096 Records/Chip              *
    ' * At one Record every 6 minutes this holds data for 17 days                 *
    ' * Write address 'Eaddress' stored in PIC EEPROM at addresses 1 and 2        *
    EEPROM_write:
        read 1,Eaddress.Byte0                     ' Next free EEPROM address for chip $A8
        read 2,Eaddress.Byte1                     ' TempInt is not stored
        i2cwrite Eprom_D, Eprom_C, $A8, Eaddress,_' Write to $A8 on ETT board
            [Mont,Days,Hour,Mins,_
            Pressure.lowbyte,Pressure.highbyte,_
            Humidity,_
            TempExt.byte0,TempExt.byte1,_
            Wind_S,_
            Wind_S_Ave,_
            Wind_D,_
            Wind_D_Ave,_
            Rain,_
            Voltage,_                             ' Spare
            Voltage]                              ' Spare
        pause 10
        Eaddress = Eaddress+16                    ' 16 bytes per record, must be an integer of 128/No of rcds
        write 1,Eaddress.Byte0                    ' Write new Eaddress to PIC EEPROM
        write 2,Eaddress.Byte1
    And reading it back:
    ' * DATA DUMP. Read EEPROM $A8 from Address 0 to Address Eaddres              *
    ' * and send it to the PC                                                     *
    Data_dump:
    	RCSTA=$90:TXSTA=$24:SPBRG=21	' Set up for 115200 Baud when oscillator is at 40 MHz
    	pause 10
    	hserout [13,13,"DUMP OF DATA FROM EEPROM CHIP $A8",13]' Print column headings with TAB command
    	hserout [_
        "Recd" ,9,_
        "Month",9,_
    		"Date ",9,_
    		"Hours",9,_
    		"Mins ",9,_
    		"Press",9,_
    		"ReHum",9,_
    		"TeExt",9,_
    		"WinSp",9,_
    		"WinSA",9,_
    		"WinDr",9,_
    		"WinDA",9,_
    		"Rain ",9,_
    		"Volts",9,_
    		"Volts",13]
        for Address=0 to Eaddress-16 step 16' 16 bytes per record
    	   i2cread  Eprom_D, Eprom_C, $A8, Address,_' Read from %1010100X on ETT board
           [Mont,_
                Days,_
                Hour,_
                Mins,_
                Humidity,_
                TempExt.lowbyte,TempExt.highbyte,_
                Wind_S,_
                Wind_S_Ave,_
                Wind_D,_
                Wind_D_Ave,_
                Rain,_
                Voltage,_
                Voltage]
            hserout[_' Print weather data with TAB command
                dec5 Address,9,_
                dec2 Mont,9,_' Read from EEPROM $A8
                dec2 Days,9,_' Read from EEPROM $A8
                dec2 Hour,9,_' Read from EEPROM $A8
                dec2 Mins,9,_' Read from EEPROM $A8
                dec4 Pressure/10,".",dec1 Pressure,9,_ ' Read from EEPROM $A8
                dec2 Humidity,9,_ ' Read from EEPROM $A8
                dec2 TempExt/10,".", dec1 TempExt,9,_' Read from EEPROM $A8
                dec3 Wind_S,9,_' Read from EEPROM $A8
                dec3 Wind_S_Ave,9,_' Read from EEPROM $A8
                dec3 Wind_D,9,_' Read from EEPROM $A8
                dec3 Wind_D_Ave,9,_	' Read from EEPROM $A8
                dec2 Rain/10,".", dec1 Rain,9,_ ' Read from EEPROM $A8
                dec2 Voltage/10,".", dec1 Voltage,9,_' Read from EEPROM $A8
                dec2 Voltage/10,".", dec1 Voltage,13]' Read from EEPROM $A8
                pause 10
        next Address
        hserout [13,13]
    Note the 'WRITE' command to stores the address on the internal PIC EEPROM and the 'I2CWRITE' stores the variables on the external EEPROM
    hope this helps?
    Regards Bill Legge
    Feb 2010
    Indiana
    Default It works now.....
    Well well, read.. read.. and read some more... then go back and read it again and again...
    The spec sheet & syntax that is....
    If you have tried everything... go back and read the spec sheet & syntax of the command one more time ...
    Yep that is exactly what I did .. still couldn't make it work so I asked for my first time ever on this forum a question and the answer was given right there in front of me.. there it was in the spec sheet. the external eeprom 24LC16B uses a byte as the address not a word. You then I2Cwrite to an address using a byte of information 0 to 256. You can use ether a byte or word of information sent to eeprom up to 1 page depending on the eeprom size for the information to store. Reading it back is just the oposite...
    By the way THANKS!
    Next time before I ask a question on this forum I promise you I will read Just one more time the spec sheet and the syntax of the promblem..
    THANKS again... Odie52
