Copying Array to Array
+ Reply to Thread
Results 1 to 5 of 5
    Mar 2010
    Default Copying Array to Array
    I am having trouble copying from one array to another.
    if I do this it works:
    array1   VAR BYTE [30]
    CopyMe VAR BYTE[30]
    For I = 0 to 29
     array1[I] = CopyMe[I]
    Next I
    If I try this it does not work:
    Arraywrite Array1, [CopyMe\30]
    OR
    Arraywrite Array1, [CopyMe]
    I have even tried
    ARRAYWRITE Array1, 30, [CopyMe]
    And
    ARRAYWRITE Array1, [STR CopyMe\30]
    But these result in compile errors or in the later example, code not functioning correctly.
    What am I missing with the Arraywrite command?
    ARRAYWRITE ArrayVar, length, label, [data]
    Last edited by vamtbrider; - 23rd April 2010 at 16:05. Reason: Added declaration of arrays
    Which version of PBP do you own?
    Mar 2010
    running version 2.6
    Works fine here!
    String1 Var Byte(26)
    String2 Var Byte(26)
    Index Var Byte
       PAUSE 5000
       Hserout ["Testing",13,10]
       Clear     ' Clear RAM before entry
       ' Load String1 with data
       ARRAYWRITE String1,["ABCDEFGHIJKLMNOPQRSTUVWXYZ"]
       ' Show what's in String1
       Hserout [13,10,"String1 = "]
       For Index = 0 TO 25
           Hserout [String1(Index)]
       Next Index
       ' Copy String1 to String2
       ARRAYWRITE String2, [STR String1\26]
       ' Show what's in String2
       Hserout [13,10,"String2 = "]
       For Index = 0 TO 25
           Hserout [String2(Index)]
       Next Index
       Pause 500
       Goto Main
    Returns;
    Testing
    String1 = ABCDEFGHIJKLMNOPQRSTUVWXYZ
    String2 = ABCDEFGHIJKLMNOPQRSTUVWXYZ
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2010
    Thanks for the response Bruce. I will try your example when I get to my bench later tonight.
    For some reason I am having a hard time getting my head around how PBP handles arrays and formatting (DEC, STR, HEX, etc.)
    Here is what I am attempting:
    From VB using USB I pass 64 bytes of data that contain numbers in the range of 0-255
    I assume this shows up in the PIC USBRXBuffer (var from DT and Mistere demos) in hex form of 0x00 through 0xFF.
    For example,
    PC side:
    Bufferout(2) = 150
    Bufferout(3) = 200
    Bufferout(4) = 8
    Bufferout(63) = 233
    On the PIC side the USBRXBuffer needs to be copied into another array, USBDataIn. I then use the data in USBDataIn to make program decisions and store some of the data in EEPROM.
    If I use
    ARRAYWRITE USBDataIn, [USBRXBuffer]
    I get random data in the USBDataIn array. By random I mean I can not make the data look anything like the data sent from the PC. This would make sense since I never specified a length for the Arraywrite command.
    If I use the for...next loop method then the data in USBDataIn matches what came from the PC.
    If I try to do the
    ARRAYWRITE USBDataIN, [STR USBRXBuffer\24]
    the processor runs off into la la land. It looks like that method should work, so I guess I need to fire up the debugger and see where the code is getting lost.
    So what would happen if you filled your array this way:
    For I = 0 to 25
      String1(I) = I * 10
    Next I
    So instead of having "ABCDE..." it now has (0,10, 20, 30...250)
    Does the
    produce an output of 0,10,20,30,40...250?
