I2C with MCP23016
Results 1 to 8 of 8
    Apr 2010
    Default I2C with MCP23016
    Hi, i'm trying to get this IO expander chip to work with a 18F8720(have others in stock and same results), I wired the clock and i'm able to measure it at the TestPin of the MCP and i get a 1Mhz clock there, on the SDL, SCL lines(pulled up by 2 (4.7K resistors), i can see, something passing on my scope, but when the device does not put its port 0 to outputs and do not drive them, i think they are floating, in order of 2mV so nothing meanfull, tried to pull them up and down. But no luck.
    Here is the code i use
    ADCON0 = 0;
    ADCON1 = %00001111;
    DEFINE OSC 24
    DEFINE I2C_SLOW
    PAUSE 200
    ct var byte
    reg var byte
    val VAR BYTE
    ct = %01000000
    reg = $6
    val = 0
    ' Set direction for PORT0 to all outs
    I2CWrite PORTC.4,PORTC.3, ct,reg,[val]
    LOW PORTH.0
    reg = $0 'MCP23... IO LATCH
    val = 255
    I2CWrite PORTC.4,PORTC.3,ct,reg,[val]
    PAUSE 500
    HIGH PORTH.0
    reg = $0 'MCP IO LATCH
    val = 0
    PAUSE 500
    Apr 2010
    i got the code working by stripping the reg value and using a PCF8574 which has no clock circuit, and it worked directly, this lead me to re-analize the clock on the test pin of the MCP and i got a quite noisy signal, how can i get this more stable, i tried adding condos at the powersupply but still got noise on it. i assume that due to an unstable clock, the data is not handled right by the device.
    You've not told us how your MCP23016 is connected.
    Do a SEARCH on MCP23016 on this forum - there are code examples.
    Apr 2010
    Hi melanie,
    the mcp is on portc.3 and 4 for SDA SCL, and thats it. All vss & vdd's are connected and address pins are all grounded.
    I've seen those code samples and I inpired my code from them, but it doesn't want to work...grrrr. I don't get anything on the outputs of the MCP.
    I really think it is more a clock issue, on the MCP, than an I2C problem. I've tested other I2C devices and they work, they do not need an external RC.
    The datasheet says 33Pf and 3.9KOhms for a res and condo between clk pin of the mcp and VSS,VDD.
    That should give a 1Mhz clock on test pin, but that clock is very unstable here, and i can't clean it out.
    Oct 2007
    The Netherlands
    I ones worked with those chips, I only had it working without the 33 pF capacitor. The MCP23017 seems a better choice, it does not need an external capacitor.
    Wink
    Hi, Sebastien
    an interesting reading: Microchip AN 245 ...
    Apr 2010
    Quote Originally Posted by eggman View Post
    Yeah I prefered the 17's but i could not grab that chip at my local store so gone for the 16. I will try without the cap. Thanks for that tip
    I'm now managing to do it with the philips component, but it has only 8, so i will have to make 2 other SDA, SCL lines.
    Apr 2010
    Hi, Sebastien
    Seen that appnote and did not find new info compared to the datasheet.
    But thanks anyway
