The "Reload(instr. Cycle)" value is important for Long-Term accuracy.
It represents the number of Clock Cycles (instructions) that it takes to Reload the timer.
In the case of Elapsed_INT ... there are 7 cycles between the point where the timer is stopped until it's been reloaded and turned back on again.
; ----------------- ADD TimerConst to TMR1H:TMR1L
ADD2_TIMER macro
CHK?RP T1CON
BCF T1CON,TMR1ON ; Turn off timer
MOVLW LOW(TimerConst) ;1 1
ADDWF TMR1L,F ;2 1 ; reload timer with correct value
BTFSC STATUS,C ;3 1/2
INCF TMR1H,F ;4 1
MOVLW HIGH(TimerConst) ;5 1
ADDWF TMR1H,F ;6 1
; ----------------- ADD TimerConst to TMR1H:TMR1L and restart TIMER1 ----------
RELOAD_TIMER macro
ADD2_TIMER
BSF T1CON,TMR1ON ;7 1 ; Turn TIMER1 back on
7 is also the default number in mister-e's program, but different reload routines may take longer, or shorter times.
hth,
