Unable to pass a variable to LCDOUT without getting compile errors
Results 1 to 3 of 3
    Default Unable to pass a variable to LCDOUT without getting compile errors
    I'm having trouble getting LCDOUT to accept a variable. Currently if I type in actual text it'll work fine and display, on the other hand if I feed it a variable it'll refuse to compile.
    '*  Notice  : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 12/22/2009                                        *
    define OSC 20
    DEFINE LCD_DREG PORTC
    DEFINE LCD_DBIT 8
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RWREG PORTB
    DEFINE LCD_RWBIT 4
    var h as int
    var m as int
    var s as int
    ADCON1 = %00000000
    ADCON0 = %00000001
    h = 0
    m = 0
    s = 0
    Lcdprint:
    lcdout $FE, $80, h         'this is where I get compile errors.
    lcdout $FE, $80, ":"
    lcdout $FE, $80, m         'this is where I get compile errors.
    lcdout $FE, $80, s         'this is where I get compile errors.
    s = s + 1
        if (s = 60)
        then
        m = m + 1
        s = 0
        end if
        if (m = 60)
        then
        h = h + 1
        m = 0
        end if
        if (h = 25)
        then
        h = 0
        end if
    goto Lcdprint
    California, USA
    Your variable declarations are unfamiliar to me...
    var h as int
    var m as int
    var s as int
    Try:
    h   var   byte
    m   var   byte
    s   var   byte
    steve
    OK it works now
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 08:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
