+ Reply to Thread
Results 1 to 18 of 18
    Jun 2006
    Default read/write eeprom
    First give credit to Peter Olsen who wrote these programs for a picaxe. I'm trying to convert using a 12F683 to write to a 24LC256 and read back from it. The Angel file downloads file to 24lc256 from PC. Newtoyshop is suppose to read from the 24lc256 and output to 2 74hc595's. When I write to eeprom then read back I get jumbled up mess. The Angel file runs in power basic.
    In my opinion..
    You would be better off not wasting time trying to convert a program that may or may not have worked for another platform.
    You know what you want the program to do?
    Write from scratch. In PBP...
    Jun 2006
    It did work on a picaxe. I'm trying to write it in PBP with the other program as a reference, being new at this having a heck of a time. Not giving up.
    Not giving up is good!
    To learn how to work with external eeproms try the I2C sample here
    http://www.melabs.com/resources/samples.htm
    Or wait till someone comes along that knows picaxe...
    and this may help with the 595s.
    http://www.picbasic.co.uk/forum/showthread.php?t=10200
    Put something together in PBP and we will help you debug it.
    May 2008
    Italy
    Tray adding the following two defines:
    DEFINE I2C_SLOW 1
    DEFINE I2C_HOLD 1
    Al.
    DOH!!!
    My apologies...
    The way I read the first post I did not think you had any code of your own.
    And I hate opening attachments...
    Use code tags in the future.
    Jun 2006
    I'll try the Defines and whenever I use code tags the code jumbles up or leaves stuff out, tried this a couple times on other questions and it left parts of the code out.
    Quote Originally Posted by mel4853 View Post
    replace the word magic with the word code
    [magic] your code goes here [/magic]
    Jun 2006
    The Defines worked!!! Couple other little changes and I believe it works, except for when I download from PC it just hangs. Cycle power and all takes off and works fine. Seems to get stuck in interrupt. Here's the code now trying Joe S. method.
    [magic] Include "modedefs.bas"
    define osc 8
    define DEBUGIN_REG GPIO
    define DEBUGIN_BIT 3
    define DEBUGIN_BAUD 2400
    define DEBUGIN_MODE 1
    define I2C_SLOW 1
    define I2C_HOLD 1
    Dpin var GPIO.2 'Data pin
    Cpin var GPIO.0 'Clock pin
    Lpin var GPIO.1 'Latch pin
    Dapin var GPIO.4 '24LC256 data pin
    Clpin var GPIO.5 '24lc256 clock pin
    serialin var GPIO.3 'Input from PC
    cont con $A0
    addr var word
    CMCON0=$07 'Shut off comparators
    ANSEL=$00 'Set all digital
    ADCON0=$00 'Shut off A/D Converter
    TRISIO=$08 'Set all to outputs except GPIO.3 is input
    INTCON.7=1 'Enable all unmasked interrupts
    IOC=$08 'Enable interrupts on input3
    GPIO=$00
    b1 var byte
    b2 var byte
    chipnum var byte
    thischip var byte
    INT_Handler GPC_INT, _ToggleLED1, PBP, yes
    INT_ENABLE GPC_INT ; enable external (INT) interrupts
    Start:
    addr=0
    loop:
    I2Cread dapin,clpin,cont,addr,[b1,b2] 'Read from 24lc256
    if b2=$FF then goto Start 'If b2=FF start over
    for chipnum=0 to 1 'Load into 74hc595
    lookup2 chipnum,[b2,b1],thischip 'Load into 74hc595
    shiftout dpin,cpin,LSBFIRST,[thischip] 'Put out onto chips
    next chipnum
    pulsout lpin,10 'Latch data onto 74hc595
    addr=addr+2 'Next eeprom location
    pause 600
    goto loop
    ToggleLED1:
    addr=0 'Start writing at eeprom location 0
    NEXTSTEP:
    debugin[#b1,#b2] 'Read input
    i2cwrite dapin,clpin,cont,addr,[b1,b2] 'Store in eeprom
    pause 10 'Wait between writes
    if b2 <> $FF then nextstep 'FF means end of data
    low serialin
    Finish:
    @ INT_RETURN
    end [/magic]
    Joe said to replace the word magic with the word code
    Jun 2006
    Sorry trying to fix supper for my daughter and was reading to fast.
    define osc 8
    define I2C_SLOW 1
    define I2C_HOLD 1
    cont con $A0
    addr var word
    GPIO=$00
    b1 var byte
    b2 var byte
    chipnum  var byte
    thischip var byte
    Start:
      addr=0
    loop:
      next chipnum
      pause 600
      goto loop
    ToggleLED1:
    NEXTSTEP:
        low serialin
    Finish:
    @ INT_RETURN
    I am thinking it is looping @ nexstep maybe it is not seeing $FF as there is no way out of the loop until it does = $FF
    Jun 2006
    At the end of PC download (Angel.bas) it puts out 255 on all
    May 2008
    Italy
    How many bytes you need to tx?
    This piece of code is not working properly, since the delay due to the instructions to be executed plus the pause will surely make you loose Tx data.
    NEXTSTEP:
    Think about to tx the whole packet in one go using array.
    Replace pause 600 with For A0=1 to 120 :Pause 5:Next A0
    Al.
    Jun 2006
    I'm sending a varible amount of bytes, so far have lost none. The pause 600 is up where I read from eeprom. There's a pause 10 in interrupt routine to give time to write to eeprom. Everything works but doesn't seem to want to exit interrupt routine.
    May 2008
    Italy
    Because you have a problem with the timing in serial TX/RX.(as mentioned in post#14)
    Use a timeout to exit from DEBUGIN because you get stack there.
    Al.
    Jun 2006
    Shouldn't it exit when b2=$FF? I send a $FF at the end of all the data I want sent.
    That's the way I understand, but I've been wrong alot of times.(As my wife says) If not I'll sure put in a timeout. Thanks.
    Jun 2006
    Put in the timeout and works perfectly. Thanks to all that helped.
    Mike
    Last Post: - 18th February 2010, 14:46
  2. External EEPROM can't read/write
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 22:13
  3. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  4. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 19:42
  5. word variable to 25lc640
    By TONIGALEA in forum mel PIC BASIC Pro
    Last Post: - 6th July 2004, 19:59
