PBP migration from 16F88 to 16F1827
Results 1 to 21 of 21
    Omaha, Nebraska USA
    Question PBP migration from 16F88 to 16F1827
    Okay, I'm overlooking something. This program worked (albeit slowly) on a 16F88.
    5 analog pins sample and (after manipulation) produce a high or low to a pin. Here's the correspondence:
    AN0 to B5
    AN1 to B4
    AN2 to B3
    AN3 to B2
    AN4 to B1
    AN5 and AN6 each have the wiper of a different pot on them.
    Now, only AN4 to B1 works correctly. B5 is stuck high all the time (from power-up), even with no signal on AN0. The three in between are off if there is no signal but stick high as soon as a small signal is applied and remain that way until power-down.
    The pot on AN5 has the correct effect on the one working channel but AN6 does not appear to be working.
    Here's what I had in the (totally working) 16F88 version:
    DEFINE OSC 8
    ANSEL= %01111111
    CMCON= %00000111
    OSCCON= %01110000
    TRISA= %01111111
    TRISB= %11000001
    ADCON1.7=1
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 5
    DEFINE ADC_SAMPLEUS 12
    . . . and here's what I have for the 16F1827:
    DEFINE OSC 32
    ANSELA= %00011111
    ANSELB= %11000000
    OSCCON= %11110000
    TRISA = %01111111
    TRISB = %11000001
    ADCON1.7 =1
    CM1CON0.7=0
    CM2CON0.7=0
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 6
    What thing(s) am I failing to do?
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Omaha, Nebraska USA
    I discovered the capacitive sensing module and have added:
    CPSCON0.7=0 to turn it off.
    The effect was that the one working channel continues to work.
    The pot on AN6 also now works.
    But now all the other four channels lock high at power-up, even with no signal, and stay there.
    I guess that's a tiny speck of progress.
    Russ
    I have had trouble in the past with the built in ADC commands.
    You may want to try the method used here.
    http://www.picbasic.co.uk/forum/show...2&postcount=16
    Omaha, Nebraska USA
    I've also tried to make sure the CCP/ECCP modules were off by adding:
    CCP1CON=%00000000
    CCP2CON=%00000000
    CCP3CON=%00000000
    CCP4CON=%00000000
    No change from previous result.
    Russ
    Quote Originally Posted by RussMartin View Post
    Well, you failed to include the part that reads the A/D, "Manipulates" it, then outputs it to a pin.
    Omaha, Nebraska USA
    I didn't include anything else because (a) everything ran fine on the '88 and (b) one of the five identically-processed channels is working just fine.
    All five channels are handled like this (different VARs, of course) in a loop, with the interrupt enabled:
    FOR SAMPLX=4 TO 1 STEP -1
    ADCIN 2,INMD
    IF INMD>TEMPMD THEN TEMPMD=INMD
    NEXT SAMPLX
    INMD=TEMPMD
    IF MODE=1 THEN GOTO HOP3
    IF INMD>341 THEN
    INMD=(INMD-342)*3
    INMD=0
    HOP3:
    IF INMD<10 THEN COMP=0
    IF INMD<THRES THEN INMD=THRES+INMD+COMP
    INMD=INMD+COMP
    IF INMD>1023 THEN INMD=1023
    TEMPMD=0
    XMD=INMD/2
    The INT_INT handler looks like this:
    STATE:
    FOR INDEX=511 TO 1 STEP -1
    IF INDEX=XLO THEN OLO=1
    IF INDEX=XLM THEN OLM=1
    IF INDEX=XMD THEN OMD=1
    IF INDEX=XMH THEN OMH=1
    IF INDEX=XHI THEN OHI=1
    NEXT INDEX
    OLO=0 : OLM=0 : OMD=0 : OMH=0 : OHI=0
    @ INT_RETURN
    Russ
    Omaha, Nebraska USA
    Default When all else fails . . . "blinky" test!
    Here it is:
    @ __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _BOREN_OFF & _FCMEN_OFF
    @ __config _CONFIG2, _STVREN_OFF & _LVP_OFF
    OLO VAR PORTB.5
    OLM VAR PORTB.4
    OMD VAR PORTB.3
    OMH VAR PORTB.2
    OHI VAR PORTB.1
    DEFINE OSC 32
    ANSELA= %00011111
    ANSELB= %11000000
    CCP1CON=%00000000
    CCP2CON=%00000000
    CCP3CON=%00000000
    CCP4CON=%00000000
    OSCCON= %11110000
    TRISA = %01111111
    TRISB = %11000001
    MAIN:
    OLO=1 : PAUSE 1000 : OLO=0
    OLM=1 : PAUSE 1000 : OLM=0
    OMD=1 : PAUSE 1000 : OMD=0
    OMH=1 : PAUSE 1000 : OMH=0
    OHI=1 : PAUSE 1000 : OHI=0
    GOTO MAIN
    No ADCs, no triac output, nothing but outputs low to high and back.
    Results:
    Each channel comes on in succession. The first four, however, than simply stay on. The fifth goes on and off exactly as you would expect.
    I even tried this on a "fresh" '1827. No difference.
    This is why I remain convinced that the problem hides in how I'm configuring something that affects B.2 through B.5 but permits B.1 to operate normally.
    Russ
    Try this Russ,
    OLO     VAR LATB.5
    OLM     VAR LATB.4
    OMD     VAR LATB.3
    OMH     VAR LATB.2
    OHI     VAR LATB.1
    Omaha, Nebraska USA
    Sonofagun! It works. Thanks!
    What did we just do?
    And why was PORTB.1 working but not the others?
    Russ
    . . . and what is the "real" difference between LATB & PortB ?
    I am sensing a RMW issue . . . Thanks Darrel, in advance.
    It's the old R-M-W issue (Read-Modify-Write).
    PIC's can't write to individual Pins in a PORT. It's not possible for the hardware to just set a pin high or low directly.
    It has to Read the entire PORT, Modify the bit it wants to change, then Write the value back to the Entire PORT.
    When it Reads the PORT, it actually reads the state of the Pins, not the state it was told to be in last.
    In your code ...
    MAIN:
    GOTO MAIN
    The OLM=1 statement is executed immediately(125nS) after the OLO=0 statement.
    If the voltage on the OLO pin has not reached the level required to register a 0, then it reads OLO as 1 and writes that back to the PORT, ignoring that fact that you just told it to be 0.
    Capacitance on the Pin will increase the amount of time it takes to reach the requested state.
    Solderless breadboards can add quite a bit. LED's add some too.
    Just like the 18F's, the 16F1's have LATx (DATA LATCH) registers.
    If you use PORTB.0, it does the RMW on the PORT, then writes it to the LATB register which controls the pins state.
    If you write directly to LATB.0, it doesn't read the port first.
    It still does a read-modify-write, but what it reads is the LATB value (last requested state), not the state of the Pins.
    DO NOT! use HIGH, LOW, TOGGLE, or any other PBP commands like SERIN/OUT, PULSIN/OUT etc. with LATx.x as a Pin.
    It will cause big problems.
    But writing to the LATx bits directly with a 1 or 0 can eliminate the dreaded R-M-W problem.
    hth,
    Omaha, Nebraska USA
    Then:
    The reason the old PORTB.1 worked is that little scootch of additional time between OHI=0 and OLO=1 caused by the GOTO?
    Were there Olympic Gold for PBP help, you'd get it!
    Russ
    Then:
    Exactly!
    <table><tr><td align=right>
    Hmmm, I could go for some gold ... &nbsp; &nbsp;</td><td> </td></tr></table>
    I came across the R-M-W issue today, I thought I was losing my mind. I am glad I searched the archive for 16F1827 because for the life of me I couldn't get the darn ports to set and reset after a pause statement.
    Has this problem been reported? Will it be fixed in the next PBP version update?
    I am sorry for the 20 questions, it is just that I spent 2hrs troubleshooting my hardware. When that didn't pan out I dove into getting rudimentary features to work before seeking help. All in all a dang port toggle ate up 4hrs of my day...sigh.
    Nick
    It's not an issue with PBP.
    It's just the way the PIC Hardware works.
    And I assume it's why Microchip eventually added the LATx registers in the 18F's, and now the 16F1's.
    Just keep it in mind when you try to change pin states really fast and they don't work (or they affect other pins in the same port).
    Usually a minor change can fix it, even with 16F's.
    Thanks Darrel for the explanation. I guess it's good I cut my teeth on this problem early on. My next (week) project is using an 18F.....good to know what I am in store for.
    Nick
    Hello Darrel,
    I have some more weirdness going on. I got my code to work, but not the way I want it to.
    When I read PortB using LatB, I can't seem to detect a set bit on B1. When I write directly to the
    variable in my case statement I can step through the values and the outputs are correct. I can't
    what is wrong with what I have. Code below.
    __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
    __config _CONFIG2, _PLLEN_OFF & _LVP_OFF & _LVP_OFF & _STVREN_OFF
    DEFINE OSC 8
    ; System hardware configuration
    OSCCON = %01110000 ' 8MHz internal
    ANSELA = %00000000 ' all digital. A/D disabled
    ANSELB = %00000000
    TRISB = %00111111 ' set port directions 0 = output, 1 = input
    TRISA = %00000000
    Servo1 var byte
    Servo2 var byte
    srv2 VAR LATA.1
    srv1 VAR LATA.0
    PrtB VAR LATB
    Program_init:
    PortA = 0
    POrtB = 0
    Main_Loop:
    Servo1 = PrtB and %00000111
    gosub Servo_update1
    Servo2 = PrtB and %00111000
    gosub servo_update2
    pause 10
    goto main_loop
    Servo_update1:
    select case Servo1
    case 0
    srv1 = 1 : pauseus 1000 : srv1 = 0
    CASE 1
    srv1 = 1 : pauseus 1143 : srv1 = 0
    case 2
    srv1 = 1 : pauseus 1286 : srv1 = 0
    case 3
    srv1 = 1 : pauseus 1429 : srv1 = 0
    CASE 4
    srv1 = 1 : pauseus 1572 : srv1 = 0
    case 5
    srv1 = 1 : pauseus 1715 : srv1 = 0
    Case 6
    srv1 = 1 : pauseus 1858 : srv1 = 0
    Case 7
    srv1 = 1 : pauseus 2000 : srv1 = 0
    END SELECT
    Servo_update2:
    select case Servo2
    case 0
    srv2 = 1 : pauseus 1000 : srv2 = 0
    CASE 8
    srv2 = 1 : pauseus 1143 : srv2 = 0
    case 16
    srv2 = 1 : pauseus 1286 : srv2 = 0
    case 24
    srv2 = 1 : pauseus 1429 : srv2 = 0
    CASE 32
    srv2 = 1 : pauseus 1572 : srv2 = 0
    case 40
    srv2 = 1 : pauseus 1715 : srv2 = 0
    Case 48
    srv2 = 1 : pauseus 1858 : srv2 = 0
    Case 56
    srv2 = 1 : pauseus 2000 : srv2 = 0
    END SELECT
    Quote Originally Posted by Macgman2000 View Post
    The LATx registers only control the Output state of the pins.
    When you Read LATx, you are reading the requested Output state.
    If the pin is in Input mode, you need to read PORTx to see the state of the PIN.
    When I switch to portB instead of LATB to read, I get nothing from my code.
    BTW I have 20K pull downs and dip switches tied to +vcc to switch in the bit pattern. There should
    be NO case when the output is nothing....even if pullups or pulldowns are messed up.
    Nick
    Try it with a bitwise & instead of a logical AND.
    You are absolutely correct !!! Thanks for the fresh pair of eyes
    Nick
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. PBP, 16F1827, FSR, and Error 113
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 13th January 2014, 10:04
  3. Can PBP & 16f88 really do 9600,8,E,1
    Last Post: - 7th November 2010, 13:12
  4. Compiler differences between PBP 2.33 & 2.46
    Last Post: - 2nd May 2006, 20:01
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
