LM34D with a F675 woes
Results 1 to 5 of 5
    Default LM34D with a F675 woes
    I'm trying making a simple temp controler.
    I get no value change on the AD pin (GPIO.0) when connected to the LM34. But if I use a simple pot, the value changes just peachy (all through a serout2) So I figure the AD is set up right.
    Other oddity is that with the Lm34 running standalone, my scope (a Fluke 196C Scope meter reads it just fine, but once connected to the PIC it jumps up a lot)
    I'm figuring some sort of impedance prob?
    TIA,
    Oct 2003
    holland
    Please post your code so that we can see what you forgot in the config word to setup the adc, switchoff the comperator, etc. etc.
    Got it sorta working. Moved to a different pin and its working well.
    (though not sure why you'd think its a code issue if the pot as a voltage divider worked on that pin in question)
    Oct 2003
    holland
    Which pin did you use first and what pin later on?
    Quote Originally Posted by anode505 View Post
    Below is the reason. Kind of hard to answer questions with out information...
