DS1307 RTC example
Results 1 to 14 of 14
    malc-c's Avatar
    malc-c Guest
    Default DS1307 RTC example
    I have an EasyPIC5 development board and one of the Microelectonica RTC2 add on modules which has been breadboarded and needed to be tested as part of an ongoing project. The following example simply shows todays date (14/2/10) and starts running from 19:00 hrs.
    Although this example was simply used to test the comms between PIC and Module, it should be a simple matter to add a few tweaks to allow the date and time to be set.
    '*  Name    : RTCtest877A.BAS                                   *
    '*  Author  : Malcolm Crabbe                                    *
    '*  Notice  : Copyright (c) 2010 M.Crabbe                       *
    '*  Date    : 14/02/2010                                        *
    '*  Notes   : Test of breadboarded RTC2 Module to prove         *
    '*          : hardware                                          *
    '*  Target  : 16F877A
    @   __config _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
    DEFINE  OSC 20
    CLEAR
    ;----[LCD definitions]------------------------------------------------------
    DEFINE LCD_DREG  PORTB              ' LCD Data port
    DEFINE LCD_DBIT  0                  ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB              ' LCD Enable port
    DEFINE LCD_EBIT  5                  ' Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB              ' LCD Register Select port
    DEFINE LCD_RSBIT 4                  ' Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4                  ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2                  ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000           ' Command delay time in us
    DEFINE LCD_DATAUS 50                ' Data delay time in us
    SDA var PORTC.1                     ' RTC data
    SCL var PORTC.0                     ' RTC clock
    TRISC= %11111111
    DB0 var byte[8]
    CMCON = %00000111                   ' Comparators = off
    gosub write_1307
    read_1307:                          ' Read time Secs,Mins,Hours,Day,Date,Month,Year,Control
    I2CREAD SDA,SCL,$D1,$00,[STR DB0\8] ' Read 8 bytes from DS1307
    lcdout $fe,1,"Time=",hex2 DB0[2],":",hex2 DB0[1],":",hex2 DB0[0]    'bit 0=sec, bit 1=min, bit 2=hrs
    lcdout $fe,$c0,"Date=",hex2 DB0[4],":",hex2 DB0[5],":",hex2 db0[6]  'bit 4=day, bit 5=month, bit 6=year
    goto read_1307
    Write_1307:                          ' Set time & date to 19:00:00  14th Feb 201
    I2CWRITE SDA,SCL,$D0,$00,[$00,$00,$19,$7,$14,$2,$10,$90] ' Write to DS1307
    pause 10
    Feb 2010
    Unhappy Canīt read from it.
    Hi Malcolm.
    I'm trying this code but can't make it work. It only displays:
    Time= 00:00:00
    Date= 00:00:00
    but does not show the date and time that was set or advance.
    Tried grounding DS1307's Vbat pin and using a lithium battery between this pin and ground. Tried 1k, 4.7K and 10k resistors to Vcc from SCL & SDA.
    I know I can write to the DS1307 and I know it's ticking since I can make the SQWE pin stop or go 1 Hz by changing the last byte while writing, I just don't seem to be able to read from it.
    I'm using a 16F887 at 4 mhz, pin PortB.1 is SCL, pin PortB.2 is SDA.
    Any ideas?
    Thanks!
    Rogerio
    DEFINE  OSC 4
    CLEAR
    DEFINE LCD_DREG  PORTC              ' LCD Data port
    DEFINE LCD_EREG  PORTD              ' LCD Enable port
    DEFINE LCD_EBIT  0                  ' Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTD              ' LCD Register Select port
    DEFINE LCD_RSBIT 1                  ' Register Select bit   (on EasyPIC 5 LCD)
    'DEFINE LCD_BITS  4                  ' LCD bus size (4 or 8 bits)
    'DEFINE LCD_LINES 2                  ' number of lines on LCD
    SDA var PORTB.2                     ' RTC data
    SCL var PORTB.1                     ' RTC clock
    DB0 var byte[8]
    TRISB= %11111111
    gosub write_1307
    goto read_1307
    I2CWRITE SDA,SCL,$D0,$00,[$00,$00,$19,$7,$14,$2,$10,$80] ' Write to DS1307
    pause 10
    Feb 2010
    Default Problem solved!
    Ok, so I had forgoten to clear Anselh register, ha.
    Working great now,
    Thanks for the code malcolm!
    Rogerio
    malc-c's Avatar
    malc-c Guest
    Glad to hear you've got it working.
    It's fairly basic in functionality, I just used it as a test to confirm that the hardware is working (hence no fancy set buttons or alarms etc) - there are other examples on this forum and the net which cover the setting of these things to make a fully functional alarm clock, just use the search function or google
    Jul 2007
    this is great!
    I'm not too sure to understand how you get the Decimal values when reading as STR and then displaying them as HEX2?
    also, a bit out of topic but I get a weird error:
    symbol not previously defined (ANSELH)
    when trying to set ANSEL = 0, to use other ports.
    On a 16F876a...
    Ever seen that?
    Feb 2010
    Quote Originally Posted by flipper_md View Post
    On a 16F876a...
    Ever seen that?
    Does the 16F876A have an ANSEL or ANSELH register? Some devices use different registers to acomplish similar tasks.
    Jul 2007
    that is correct
    It's the first time I come accross this but the 16f876a drive those ANalog ports with ADCON and other registers
    thanks
    Oct 2007
    Vancouver, BC, Canada
    Default displaying and adjusting RTC ds1307 on Pic18f2620
    '*  Name    : RTC2620.PBP                                       *
    '*  Author  : KVLV                                              *
    '*  Notice  : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 6/11/2010                                         *
    'Jun11.2010 this program was created using parts of another big program
    'for displaying and adjusting RTC chip DS1307. displaying RTC on a 2x20 LCD
    'the pic chip used pic18f2620
    'press the minus key will get to setting up RTC at startup or after reset
    'some parts or all are copied from the forum and modified<< Thanks.
    'the program can only display the clock in 12hr format with am/pm indicator
    'the day of the week in word ex. Sunday as Sun (also start of week)
    'the month is also in word ex: June as Jun
    'here is the example of the display
    '11:19:00PM
    'Fri Jun 11 2010
    ' the clock is refresh every 100ms
    DEFINE LOADER_USED 1 'for bootstrap loader
    DEFINE OSC 20
    ' Define LCD pins
    DEFINE  LCD_DBIT	4
    DEFINE  LCD_RSBIT   3
    DEFINE  LCD_EREG    PORTC
    DEFINE  LCD_EBIT    5
    Define  LCD_COMMANDUS 2000
    ' Command Delay (uS)
    Define LCD_DATAUS 100 ' Data Delay (uS)
    Line    var byte
    Line1   con $80
    Line2   con $c0
    ButOK   var PortB.0
    ButPlus var PortB.1
    ButMinus var PortB.2
    Debounce con 250
    CounterA var byte
    CounterB var byte
    CounterC var byte
    CounterD var byte
    'CounterX var byte
    EEpromByte   var byte
    TimeOut  var word
    SetMonth var byte
    DB0 var byte[10]
    RTCTemp var byte
    SetYear var byte	' Year
    ' EEPROM 41,[%11111111]      ' xxxx xxx0 = RTC is not set
                                    'xxxx xxx1 = RTC is set
                                    'xxxx xx0x = timer is not set
                                    'xxxx xx1x = timer is set
       ' eeprom 50,["ROOM1ROOM2CLOAKDECALEARTHFLUIDGLASSHEARTINLETJUICE"]
        eeprom 100,["JanFebMarAprMayJunJulAugSepOctNovDec"]
        eeprom 136,["SunMonTueWedThuFriSat"]
    'initialization
    PORTA=00
    LATA=$ff
    TRISA=%00000000       '0=output
    TRISB=%00000111       '1 = input
    TRISC=%00000000
    ADCON0=%11000000
    ADCON1=%00000111
    CMCON =%00000111                   ' Comparators = off
    INTCON2.7=0 ' Enable Pull-Up's    PIC18F2620   'VERIFIED
        lcdout $fe,1
        LATA=%11111011  'turn on backlight to lcd, turn all relays off
    ''    gosub write1307
    'press the (-) minus key, will take to the routine of adjusting the RTC
    MinusPressed:
            if butminus=0 then
                gosub AdjustRTC    'this one works
                'lcdout $fe, $0c 'turn off cursor
        lcdout $fe,1
    '    for counterx=1 to 5
            gosub ReadDisplayRTC
    '   next counterx
    'eeprom 100,["JANFEBMARAPRMAYJUNJULAUGSEPOCTNOVDEC"]
    'eeprom 136,["SUNMONTUEWEDTHUFRISAT"]
    AdjustRTC:
        gosub waitbutrelease
        lcdout $fe,line1,"RTC ADJUSTMENT"
        lcdout $fe,line2,"-/+:CHANGE OK:SAVE "
        pause 2000
    '    gosub waitbutrelease
        lcdout $fe,1
    RPTAdjustRTC:
        LCDOUT $FE,$0F  'TURN ON lcd cursor
        while butok<>0  'adjust day of week
            GOSUB ReadDisplayRTC
            lcdout $fe,line2+0
            counterc=db0[3]
            if butplus=0 then
                counterc=counterc + 1
                if counterc>7 then counterc=1
            if butminus=0 then
               counterc=counterc - 1
               if counterc=0 then counterc=7
            db0[3]=counterc
            gosub settime
            'I2CWRITE SDA,SCL,$D0,$00,[db0[0],db0[1],db0[2],counterc,db0[4],db0[5],db0[6],db0[7],db0[8],$90]
            pause debounce
        wend
        gosub rtcwaitnext
        while butok<>0  'adjust month
            lcdout $fe,line2+4
         counterc=db0[5]              'month
            rtctemp =(counterc>>4)*10+(counterc & $0F)  'convert BCD into Decimal
            if butplus=0 then
                rtctemp=rtctemp+1   'increment by 1
                If rtctemp>12 then      '
                    rtctemp=1
                endif              'reset to 0
            if butminus=0 then
               rtctemp=rtctemp-1   'decrement by 1
                If rtctemp=0 then      '
                    rtctemp=12
            countera=rtctemp
            gosub ConvertBCD
            db0[5]=counterb
            gosub settime
            pause debounce
        wend
        gosub rtcwaitnext
        while butok<>0  'adjust date of the month
            lcdout $fe,line2+8
            counterc=db0[4]
            if butplus=0 then
                setmonth=db0[5]
                setyear=db0[6]
                gosub finddays
                If rtctemp>countera then      'If minutes exceeds 59
                    rtctemp=1
                endif              'reset to 0
            if butminus=0 then
                If rtctemp=0 then      'If minutes exceeds 59
                    setmonth=db0[5]
                    setyear=db0[6]
                    gosub finddays
                    rtctemp=countera
            countera=rtctemp
            gosub ConvertBCD
            db0[4]=counterb
            gosub settime
            'I2CWRITE SDA,SCL,$D0,$00,[db0[0],db0[1],db0[2],db0[3],Counterb,db0[5],db0[6],db0[7],db0[8],$90]
            pause debounce
        wend
        gosub rtcwaitnext
        while butok<>0  'adjust the century (100th) year
            lcdout $fe,line2+11
            counterc=db0[8]
          '  rtctemp =(counterc>>4)*10+(counterc & $0F)  'convert BCD into Decimal
            rtctemp=counterc
            if butplus=0 then
                If rtctemp>99 then      'If minutes exceeds 59
                    rtctemp=1
                endif              'reset to 0
            if butminus=0 then
                If rtctemp=00 then      'If minutes exceeds 59
                    rtctemp=99
          '  countera=rtctemp
         '   gosub ConvertBCD
            db0[8]=rtctemp
            gosub settime
            'I2CWRITE SDA,SCL,$D0,$00,[db0[0],db0[1],db0[2],db0[3],db0[4],db0[5],counterb,db0[7],db0[8],$90]
            pause debounce
        wend
         gosub rtcwaitnext
      while butok<>0  'adjust the year
            lcdout $fe,line2+13
            counterc=db0[6]
            if butplus=0 then
                If rtctemp=100 then      'If minutes exceeds 59
                    rtctemp=0
                endif              'reset to 0
            if butminus=0 then
                If rtctemp=$ff then      'If minutes exceeds 59
                    rtctemp=99
            countera=rtctemp
            gosub ConvertBCD
            db0[6]=counterb
            gosub settime
            pause debounce
        wend
         gosub rtcwaitnext
        while butok<>0  'adjust the hour
            lcdout $fe,line1+0
            counterc=db0[2]
            counterd=db0[2]
            rtctemp=counterc & %00011111
            if rtctemp=$10 then rtctemp=10
            if rtctemp=$11 then rtctemp=11
            if rtctemp=$12 then rtctemp=12
            if butplus=0 then
                if rtctemp>12 then rtctemp=1
                if counterd.5=1 and rtctemp=12  then
                    counterd.5=0
                    goto _donesethr
                if counterd.5=0 and rtctemp=12 then
                    counterd.5=1
                    goto _donesethr
            if butminus=0 then
                If rtctemp=0 then rtctemp=12
                if counterd.5=1 and rtctemp=11  then
                    counterd.5=0
                    goto _donesethr
                if counterd.5=0 and rtctemp=11 then
                    counterd.5=1
                    goto _donesethr
     _DoneSetHR:
            if rtctemp=10 then rtctemp=$10
            if rtctemp=11 then rtctemp=$11
            if rtctemp=12 then rtctemp=$12
            db0[2]=(counterd & %01100000) | rtctemp
            gosub settime
            'I2CWRITE SDA,SCL,$D0,$00,[db0[0],db0[1],counterb,db0[3],db0[4],db0[5],db0[6],db0[7],db0[8],$90]
            pause debounce
        wend
         gosub rtcwaitnext
        while butok<>0  'adjust the minute
            lcdout $fe,line1+3
            counterc=db0[1]
            if butplus=0 then
                If rtctemp>59 then      'If minutes exceeds 59
                    rtctemp=0
                endif              'reset to 0
            if butminus=0 then
                    rtctemp=59          '??????????????
            countera=rtctemp
            gosub ConvertBCD
            db0[1]=counterb
            gosub settime
            'I2CWRITE SDA,SCL,$D0,$00,[db0[0],counterb,db0[2],db0[3],db0[4],db0[5],db0[6],db0[7],db0[8],$90]
            pause debounce
        wend
         gosub rtcwaitnext
        while butok<>0  'adjust the second
            lcdout $fe,line1+6
            counterc=db0[0]
            if butplus=0 then
                    rtctemp=0
                endif              'reset to 0
            if butminus=0 then
                    rtctemp=59
            countera=rtctemp
            gosub ConvertBCD
            db0[0]=counterb
            gosub settime   'I2CWRITE SDA,SCL,$D0,$00,[counterb,db0[1],db0[2],db0[3],db0[4],db0[5],db0[6],db0[7],db0[8],$90]
            pause debounce
        wend
         gosub rtcwaitnext
     '    goto RPTAdjustrtc
    ExitAdjustRTC:
     pause debounce
    RTCWaitNext:
    '    LCDOUT $FE,$0F
    '    lcdout $fe,line2+16,"NEXT",$FE,LINE2+16
     '   PAUSE 500
       WHILE BUTOK<>0
            pause 1
            timeout=timeout+1
            if timeout=10000 then Exit  'RTCWAitNext
        WEND
        pause debounce
    'ExitRTCWAitNext:
    	'	Subroutine Converts back to BCD
    		' CounterA is the entry variable
    		' CounterB holds the converted BCD result on exit
    ConvertBCD:
    	CounterB=CounterA DIG 1
    	CounterB=CounterB<<4
    	CounterB=CounterB+CounterA DIG 0
    	'	Subroutine works out Number of Days in the Month
    		' SetYear - entry variable containing year (0-99)
    		' SetMonth - entry Variable Containing Month (1-12)
    		' CounterA - exits with number of days
    FindDays:
    	LookUp SetMonth-1,[31,28,31,30,31,30,31,31,30,31,30,31],CounterA
    		' Above line gives the 'usual' days of the Month
    		' Section below adjusts for Leap-Year
    	If SetMonth=2 then
    		If (SetYear&$03)=0 then
                CounterA=29
    'setup db0 to db8
    'db0[0]=second
    'db0[1]=minute
    'db0[2]=  hour
    'db0[3]=day of the week, start day=1 for Sunday
    'db0[4]=date of the month
    'db0[5]=month from 1 to 12
    'db0[6]=year from 00 to 99
    'db0[7]=control for the RTC
    'db0[8]=the century (100th of the year)
    SetTime:
        I2CWRITE SDA,SCL,$D0,$00,[db0[0],db0[1],db0[2],db0[3],db0[4],db0[5],db0[6],db0[7],db0[8],$90]
    WaitButRelease:
        lcdout $fe,1,"PLEASE RELEASE",$FE,LINE2,"THE BUTTON"
    _waitButRelease:
        while butminus<>1
        wend
        while butplus<>1
        wend
        WHILE BUTOK<>1
        WEND
        RTCHOUR VAR BYTE
        RTCMIN VAR BYTE
        RTCSEC VAR BYTE
    ReadDisplayRTC:                          ' Read time Secs,Mins,Hours,Day,Date,Month,Year,Control
        I2CREAD SDA,SCL,$D1,$00,[STR DB0\9] ' Read 8 bytes from DS1307
        RTCHOUR=DB0[2]
        RTCMIN=DB0[1]
        RTCSEC=DB0[0]
      	LCDOut $FE,$80
    	If RTCHour.6=1 then
    			' Work-Out 12 or 24 hour Display for Hours
    		CounterA=(RTCHour>>4)&$01
    		CounterA=(RTCHour>>4)&$03
    	CounterA=CounterA*10+(RTCHour&$0F)
    	If RTCHour.6=1 then
    		if countera<10 then
    		  LCDOut $fe,line1," ",#CounterA
    		if countera>9 then
                LCDOut #CounterA Dig 1,#CounterA Dig 0
    	LCDOut ":",#(RTCMin>>4)&$0F,#RTCMin&$0F,":"
    	LCDOut #(RTCSec>>4)&$0F,#RTCSec&$0F    '," "
    	IF RTCHour.6=1 then
    		If RTCHour.5=1 then
    			LCDOut "PM"
    			LCDOut "AM"
         lcdout $fe,line2
        gosub displaydayinword:lcdout " "
        gosub DisplayMonthInWord :lcdout " "       'LOC5
        lcdout hex2 DB0[4]," ",dec2 db0[8],hex2 db0[6]  'bit 4=day, bit 5=month, bit 6=year
    DisplayDayInWord:
    ' eeprom 136,["SUNMONTUEWEDTHUFRISAT"]
     'Sunday start at 1
    ' DB0[3]= day in hex number     'input
    ' day in words                               'out
    ' db0[3] won't change
        counterb=0
        counterb=((db0[3]*3)-3)+136
        for countera=0 to 2
            read counterb+countera, eeprombyte
            lcdout eeprombyte
        next countera
     DisplayMonthInWord:
    ' DB0[5]= MONTH in hex number     'input
    ' month in words                               'out
    'what will happen when the month after October >10
    ' db0[5] won't change for the month of oct, nov, dec
       ' hserout [hex2 db0[5]," "]
        if db0[5]=$10 then db0[5]=10
        if db0[5]=$11 then db0[5]=11
        if db0[5]=$12 then db0[5]=12
        counterb=0
        counterb=((db0[5]*3)-3)+100
        for countera=0 to 2
            lcdout eeprombyte
        next countera
        if db0[5]=10 then db0[5]=$10
        if db0[5]=11 then db0[5]=$11
        if db0[5]=12 then db0[5]=$12
    ''Write1307:
    ''    read 41,eeprombyte
    ''    if eeprombyte.0=0 then
    ''                             ' Set time & date to 19:00:00  14th Feb 2010
    ''                             ' set time to 9:00:00PM, date to 30.05.10, year as register 08h in the ds1307
    ''        I2CWRITE SDA,SCL,$D0,$00,[$00,$10,%01101100,$01,$06,$06,$10,00,20,$90] ' Write to DS1307
    ''        pause 10
    ''        eeprombyte=eeprombyte and $ff
    ''        write 41,eeprombyte
    ''    endif
    ''RETURN
    ________________
    KV
    Oct 2007
    just some code correction. as the above was posted 6 months ago. the attachment is the corrected code.
    ' Dec 18.2010:
    ' rewrite so that we can adjust the day of the month of OCt, November and December
    ' please read FindDays to be clear.
    ' in the FindDays sub, the SetMonth to be in Decimal from 0 to 12.
    ' code rewrite in the adjustment of the date of the month
    ' variable Dummy was created
    ________________
    KV
    Little confused with BCD to Decimal conversion and vice versa.
    Please clarify, if I have 3 variables sec, minu, hrs and want decimal values in them, is the following correct?
    AIM: To get the decimal values inside sec (0-59), minu (0-59) & Hrs (0-23)
    The first thing my code is doing is resetting DS1307 with the following line of code:
    I2CWRITE SDA,SCL,$D0,$00,[$17,$3B,$17,$01,$00,$00,$00,$90]
    The above line only executes once only when PIC is powered for the first time only.
    As you can see I choose a 24Hr format for my time. I also want to start my time with 23:59:23. I am only interested in hrs,min,sec,day only.
    Now if I read back the time:
    and want decimal values in my variables, please guide what is the correct way of doing it as the following is not working
    temp=db0[0]
    sec =(temp>>4)*10+(temp & $0F)
    temp=db0[1]
    minu =(temp>>4)*10+(temp & $0F)
    temp=db0[2]
    hrs=(temp>>4)*10+(temp & $0F)
    Lcdout $FE,1,DEC2 sec," : ",DEC2 minu," : ",DEC2 hrs
    ___________________
    WHY things get boring when they work just fine?
    Thanks Mack, I have seen the code there and tried it as well, but it is giving errors. Also I don't see any variable saving values in Decimal format coming from DS1307 and converting decimal to BCD as well to store in DS1307.
    ___________________
    This is using a different RTC but it has DEC vars.
    http://www.picbasic.co.uk/forum/cont...USB-SD-LOGGING
    Apr 2012
    Ptolemaida
    Default Re: DS1307 RTC example
    Thank you a LOT Malcolm for your owsome code !! i tried on PIC16F628A ( with some modifications [changed the LCD disp with a Serout to my PCTerminal] ).
    It is a rly nice code for starters i can do so many things now !!
    Best regards, Kostas.
  1. 16F628 and an RTC DS1307
    By aurbo in forum General
    Last Post: - 7th March 2011, 22:06
  2. Random seed using the ds1307 RTC
    By rookie11 in forum General
    Last Post: - 25th November 2007, 20:31
  3. PIC 16F877 I2C communications
    By sigmoideng in forum General
    Last Post: - 13th July 2007, 10:28
  4. DS1307 on fire
    By brid0030 in forum General
    Last Post: - 25th November 2006, 02:44
  5. X1226 RTC - Help
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 17:54
