How to index Port variable
Results 1 to 5 of 5
    Feb 2010
    Default How to index Port variable
    In this short program I am trying to index a variable assigned to a port in order to turn on LEDs by indexing it with a counter. But the compiler gives me a: "Bad variable modifier" error. In other words it doesn't like LED.i it wants a number (e.g. LED.0, LED.1, etc) instead of variable.
    Has anyone done this?
    LED var PORTD ' Alias PORTD.0 to LED
    i VAR BYTE
    mainloop:
    for i = 0 to 7
    High LED.i ' Turn on LED connected to PORTD.i
    Pause 250 ' Delay for .5 seconds
    Low LED.i ' Turn off LED connected to PORTD.i
    Pause 750 ' Delay for .5 seconds
    Next i
    Goto mainloop ' Go back to loop and blink LED forever
    California, USA
    try....
    LED.0[i]
    steve
    Last edited by Byte_Butcher; - 14th February 2010 at 18:36. Reason: didn't do that right...
    i VAR byte
    mainloop:
    for i = 0 to 7
    High LED ' Turn on LED connected to PORTD.i
    Low LED' Turn off LED connected to PORTD.i
    Next i
    Hi Jpadin1,
    Byte is a bit array, lose the modifier and it should do what you want see snippet above
    or
    HIGH LED[i]
    pause 750
    LOW LED[i]
    pause 750
    Check this link out:
    http://www.picbasic.co.uk/forum/showthread.php?t=8876
    Feb 2010
    Default I tried that but ...
    Hello and thanks for the reply. I try this shown below but the array indexing is not working either. I can turn it on using the .5 but I can't turn it off using i = 5 and LED[i]
    LED var PORTD ' Alias PORTD all LEDS
    i VAR byte
    i = 5
    mainloop:
    ' for i = 0 to 7 step 1
    'High LED[i] ' Turn on LED connected to PORTD.i
    High LED.5 ' Turn on LED connected to PORTD.i
    'Low LED[i] ' Turn off LED connected to PORTD.i
    ' Next i
    SWITZERLAND (french speaking)
    Default This works
    Counter VAR BYTE
    Output  VAR PORTB.0
    START:
        FOR Counter = 0 to 7
            Output[Counter] = 1  'High
            PAUSE 100
            Output[Counter] = 0  'Low
            PAUSE 100
        NEXT
        GOTO START:
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=4002&stc=1&d=126640253 9">
    Roger
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 01:06
  2. accessing ports pins using an index variable
    Last Post: - 19th March 2008, 21:36
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 18:27
  5. Question on assigning pin port to variable
    By khufumen in forum mel PIC BASIC Pro
    Last Post: - 1st June 2005, 23:25
