Can't read sequential addresses in external EEPROM
Results 1 to 3 of 3
    Jan 2010
    Default Can't read sequential addresses in external EEPROM
    I am using a PIC18F2420 with a Microchip 25LC1024 128k x 8 EEPROM.
    To get my technique down on using the MSSP I wrote the test code below to write data to the first 2 locations in the EEPROM then to read them back.
    If I do two separate reads it works but when I keep the CS low to perform a sequential read and clock the next data byte out of the EEPROM I always get FF.
    What am I missing here?
    '25LC1024 128k x 8 EEPROM
    'PIC18F2420
    CS Var PORTB.2
    dummy_data Var Byte
    Data_Byte1 Var Byte
    Data_Byte2 Var Byte
    DEFINE OSC 32                  	'32 Mhz Osc
    TRISB=%00000000			'Set CS as an output
    TRISC=%00010000			'Set SPI data in, data out and clock out
    SSPSTAT = %01000000    		'Sample in middle, TX rising clock edge
    SSPCON1 = %00100010 		'No collision/overflow, enable port,idle low,Fosc/64
    High CS
    Gosub Write_SPI_data
    Gosub Read_SPI_data
    Gosub Read_SPI_Data_Sequential
    Write_SPI_Data:
    Gosub Write_Enable
    Low CS
    SSPBUF = %00000010		' Send Opcode for WRITE sequence
    While SSPSTAT.0 = 0: Wend 	' Wait for completion
    dummy_data = SSPBUF
    SSPBUF = %00000000		' Send MSByte of EEPROM address
    dummy_data = SSPBUF
    SSPBUF = %00000000		' Send Middle Byte of EEPROM address
    dummy_data = SSPBUF
    SSPBUF = %00000000		' Send LSByte of EEPROM address
    dummy_data = SSPBUF
    SSPBUF = %00000111		' Send data byte
    dummy_data = SSPBUF
    High CS
    Gosub Write_Enable		' Write Enable Latch is reset after
    			             '  WRITE instruction successfully
                                                       ' executed so re-enable.
    Low CS
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    SSPBUF = %00000001		' Send LSByte of next EEPROM address
    dummy_data = SSPBUF
    SSPBUF = %00010000		' Send data byte
    dummy_data = SSPBUF
    High CS
    Read_SPI_Data:			' This works
    Low CS
    SSPBUF = %00000011		' Send Opcode for READ sequence
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    SSPBUF = %00000000		' Send LSByte of next EEPROM address
    dummy_data = SSPBUF
    SSPBUF = %00000000		' Send dummy data byte to clock data out of EEPROM
    Data_Byte1 = SSPBUF		' Get data from address 0. Should be %00000111
                                                       ' and it is.
    High CS                                         ' End of first READ sequence
    Low CS				' Perform next READ sequence
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
                                                       ' out of EEPROM.
    Data_Byte2 = SSPBUF		' Get data from address 1. Should be
                                                       ' %00010000 and it is.
    High CS				' End of second READ sequence
    Read_SPI_Data_Sequential:	             ' This doesn't work
    Low CS
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    SSPBUF = %00000000		' Send dummy data byte to clock next data out of EEPROM
                                                       ' %00000111 and it is.
    				' Internal address pointer is
                                                       ' automatically incremented
                                                       ' out of EEPROM.
                                                       ' %00010000 but is %11111111
    High CS				' End of READ sequence
    Write_Enable:
    'Set the write enable latch (enable write operations)
    Low CS
    SSPBUF = %00000110		' Send Opcode for WREN
    dummy_data = SSPBUF
    High CS
    Jan 2010
    OK, after a lot of trial and error and finally getting a scope to look at some signals I determined what was going on. In the code below I found that I have to put a small delay (Pauseus 25) after each While SSPSTAT.0 = 0: Wend statement. Also had to put some delay between the WRITE ENABLE sequence and the next WRITE sequence. Also found that I can't go immediately from a WRITE into a READ without some delay between.
    Write_SPI_Data:
    Gosub Write_Enable
    Low CS
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    dummy_data = SSPBUF
    High CS
    According to the Datasheets, you need 6mS after performing a WRITE operation (be it byte or block) and upto 10mS for an Erase. Just because Transmission is completed by the Master, doesn't mean that the Slave has had time do what it needs to.
  1. Replies: 1
    Last Post: - 28th January 2010, 22:15
  2. How to define constants that specify eeprom addresses
    By DwayneR in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 04:07
  3. Cleaning up code
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2009, 07:14
  4. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  5. word variable to 25lc640
    By TONIGALEA in forum mel PIC BASIC Pro
    Last Post: - 6th July 2004, 19:59
