Is this code not initialising the LCD properly?
Results 1 to 9 of 9
    Jan 2010
    In the Shed
    Default Is this code not initialising the LCD properly?
    I have been trying to get a standard 44780 LCD to work but all I get is Lines 1 & 3 lit up with solid blocks, and nothing on Lines 2 & 4. See Photo.
    The PIC is a16F886 and the set-up is all correctly wired and has been proven to work using a HEX file given to me by a friend who programs in ASM. Unfortunately he knows nothing about PicBasic...
    The Code I've tried is;
    '*                 20 x 4 LCD for Display                                      *
    '*            LCD connected as follows:                                        *
    '*              LCD         PIC         PWR                                    *
    '*             01 Vss                  Ground                                  *
    '*             02 Vdd                  5 volts                                 *
    '*             03 Vo                   Ground (contrast)                       *
    '*             04 RS      24 PortB.3                                           *
    '*             05 RW                   Ground                                  *
    '*             06 E       23 PortB.2                                           *
    '*             07 DB0                  No connect                              *
    '*             08 DB1                  No connect                              *
    '*             09 DB2                  No connect                              *
    '*             10 DB3                  No connect                              *
    '*             11 DB4     25 PortB.4                                           *
    '*             12 DB5     26 PortB.5                                           *
    '*             13 DB6     27 PortB.6                                           *
    '*             14 DB7     28 PortB.7                                           *
    '*             15 A                    5 volts (backlight)                     *
    '*             16 K                    Ground  (backlight)                     *
    ' Defines
    DEFINE OSC 4                'using a 4 MHz oscillator
    DEFINE LCD_DREG PORTB       'LCD data port
    DEFINE LCD_DBIT 4           'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTB      'LCD register select port
    DEFINE LCD_RSBIT 3          'LCD register select bit
    DEFINE LCD_EREG PORTB       'LCD enable port
    DEFINE LCD_EBIT 2           'LCD enable bit
    DEFINE LCD_RWREG PORTB      'LCD read/write port (Not Used This Time)
    DEFINE LCD_RWBIT 1          'LCD read/write bit (Not Used This Time)
    DEFINE LCD_BITS 4           'LCD bus size 4 or 8
    DEFINE LCD_LINES 4          'Number lines on LCD
    DEFINE LCD_COMMANDUS 1500   'Command delay time in us
    DEFINE LCD_DATAUS 44        'Data delay time in us
    ' Main Program
        PAUSE 500      ' Wait .5 second for PIC and LCD to boot
        ADCON1 = 7    ' disable A/D converters
        ANSEL = 0     ' disable analog converters
        high portc.4   'Turn on LED to show PIC works
        flags = 0      'Put in in case LCD not initialised on power-up
        lcdout $FE,1 ' Clear LCD
        LCDout "Some words for test"
    The PIC is working OK (LED lights-up)
    Can you see what I'm doing wrong?
    Sep 2008
    Maine, USA
    Default Check wiring
    Nice LCD!
    Do you have your data pins connected to the HIGH 4 bits of the display?? I made the mistake of using the LOW 4 bits once.
    And check your R/W hookup too.
    "Do or do not, there is no try" Yoda
    Jan 2010
    In the Shed
    Yes the High bits are connected (orange wires, LCD Pin1 is on the left)
    I have pulled the R/W pin to ground for permanent write mode.
    It's so frustrating!
    Add ANSELH = 0 to disable PORTB analog.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2010
    PHILADELPHIA, PA - USA
    Also,
    Here is something else to look at, that frustrated me for a while.
    Note on the specs that the Vo LCD voltage may be specified relative to the supply voltage (Vdd) and not ground.
    Use a 20K pot wired as a voltage divider to feed the Vo and check that the output voltage is close to the spec. a 5k or 10k pot will work too.
    On mine at least, there was a fairly narrow range, where the LCD was readable.
    It turned out that mine was working all along, I just didn't know it.
    Bob
    Wozzy-2010
    RW bit ? are you going to read from the LCD memory to the PIC ? IF not
    just tie it to ground, I do the same for the contrast bit, pin 3. I NEVER use a contrast pot and have yet to need one.
    You might try adding FLAGS = 1 into your code, at least until you are sure everything is working. Check the Data Sheet and see if that PIC has comparators on portB and turn them off if so. And Finally TRISB=0
    so your PIC knows the LCD requires outputs.
    "PIC working ok LED lights up"
    That's because the HIGH command will manipulate the TRIS register, I think probably the TRISB = 0 or TRISB = %00000000 will make it work.
    Oh BTW I see you are new here, WELCOME !
    Jan 2010
    In the Shed
    Thanks all for the suggestions, I'll give them a go when I get home from work.
    Cheers
    Jan 2010
    In the Shed
    Talking Sorted
    Thanks all,
    The solution was ANSELH
    I had thought ANSEL covered this chip but I guess there is a high register that needs setting.
    Back to the datasheet...........
    Quote Originally Posted by Platypus View Post
    Thanks all,
    And Thank You for the feedback, It adds to my arsenal of experience.
  1. RF Modules
    By tonyfelloni in forum mel PIC BASIC Pro
    Last Post: - 26th June 2010, 18:42
  2. lcd stops after about 5 minutes and gets stuck
    By robertpeach in forum mel PIC BASIC Pro
    Last Post: - 15th September 2009, 13:03
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Making Program Code Space your playground...
  5. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
