IM USING SERIAL LCD TO DISPLAY ONLY SECOND...WHY MY LCD ALWAYS DISPLAY 20 IN HEX....
INCLUDE "modedefs.bas"
DEFINE OSC 20
DEFINE I2C_SLOW 1
TRISC = %00000000
TRISD = 0
SDA var PORTC.5
SCL var PORTC.3
Hours var Byte
Minutes var Byte
Seconds var Byte
RTC var Byte
I2C_Adr_B var byte
RTC = %11010000 ' Device adress on I2C bus
I2C_Adr_B=0
I2CWRITE SDA,SCL,RTC,I2C_Adr_B,[128,0,0,0,0,0,0,128] 'Reset time to 0 and stopped, 12 hour setting
PAUSE 100
gOSUB Start_RTC
PAUSE 900
SEROUT PORTD.1,N2400,[27,"1"]
PAUSE 50
SEROUT PORTD.1,N2400,[27,"P",$80,"TIME :"]
MAIN:
PORTD.2 = 1
GOSUB RTC_Read
PAUSE 100
sEROUT PORTD.1,N2400,[27,"P",$C5]
SEROUT PORTD.1,N2400,[27,"M",Seconds]
GOTO MAIN
Start_RTC:
I2C_Adr_B=0
I2CWRITE SDA,SCL,RTC,I2C_Adr_B,[0,0,0,0,0,0,0,16] 'Start RTC if you put a resistor and LED between the "SEC" pin and 5V it should start flash 1/s
RTC_Read:
I2C_Adr_B=0
I2CREAD SDA,SCL,RTC,I2C_Adr_B,[seconds,minutes, hours] ' in bcd code
