Using both hardware int and Timer Int together?
Results 1 to 4 of 4
    Default Using both hardware int and Timer Int together?
    Howdy
    Is it possible to use both a hardware interrupt (from PORTB.0 and another from Timer0) using the same interrupt service routine?
    I am using a hardware interrupt based on an external event triggering PORTB.0, and also want to use a timer interrupt, within some other un-related code. If I use the same interrupt handler, and on entry check a flag to see which interrupt caused it, then jump to the related routine, and then use the same exit point, will that work? Or does one somehow write two separate interrupt handlers? That does not seem possible - but then I'm just starting to use interrupts.
    I have done some searching but have not found an answer.
    Ken
    If you use DT_INTS you can have a label name for each interrupt source. If you do it on
    your own, just check interrupt flag bits in the interrupt service routine, and then jump to
    the appropriate interrupt handler with a RETFIE at the end.
    If you're using ON INTERRUPT, I recommend you do everything in a single interrupt handler.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Thanks Bruce
    I am using PBP ON INTERRUPT for the PORTB.0 interrupt
    Would this work?
    ON INTERRUPT GOTO myint ' Define interrupt handler
    INTCON = %10110000 ' enable both RB0 and Timer 0 INTS
    loop:
    Goto loop ' Normal program would be here
    DISABLE ' No interrupts past this point
    myint:
    IF INTCON.1 = 1 THEN RB0_INT 'Go to the PORTB.0 Int Routine
    '''' THE TIMER INTERRUPT ROUTINE WOULD BE HERE
    GOTO INTDONE
    RB0_INT:
    ''''' NORMAL PORTB.0 ROUTINE
    INTDONE:
    INTCON.1 = 0 ' Clear interrupt flag
    INTCON.2 = 0 'Clear Timer 0 overflow
    RESUME ' Return to main program
    ENABLE
    Hi Ken,
    Looks fine to me.
    -Bruce
    tech at rentron.com
  1. Understanding timer issues
    Last Post: - 7th April 2009, 03:56
  2. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
  3. Newb timer problems
    By George in forum mel PIC BASIC Pro
    Last Post: - 7th November 2007, 02:48
  4. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 23:05
  5. Timer Accuracy
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 06:26
