How do I use 10 bit A/D on 8 bit Pic? 12F675
Results 1 to 9 of 9
    Nov 2009
    Wagoner, USA
    Default How do I use 10 bit A/D on 8 bit Pic? 12F675
    How do I input the 10 bit A/D value, do math on it and use the value in the program or output it to debug?
    All the examples I've seen only use 8 bits.
    Does it have to be split into 2- 8 bit bytes then ...?
    Yup, needs split.
    A couple of the hard to find examples.... can be found here
    http://www.melabs.com/resources/samples.htm
    and here is one on the forum
    http://www.picbasic.co.uk/forum/showthread.php?t=11947
    Sep 2005
    Campbell, CA
    You don't need to split it. Just save it in a WORD variable. Yes, the PIC is an 8-bit device, but can easily work on number 16 bits long.
    Charles Linquist
    Nov 2009
    Wagoner, USA
    Ok so if I read that right I can store the highbyte & lowbyte A/D value in a word variable (adval) then I can do math on the entire 10 bits of the word?
    For example:
    ADCIN 0, adval	      ' Read channel 0 to adval
    adval=adval *2/10      'do math on 10 bit adval
    Debug "A/D Value: ",dec adval,10,13 'Send decimal value out
    Yes, that should work. Just watch that the math does not over flow the word size var.
    Nov 2009
    Wagoner, USA
    So I can actually do 16 bit math?
    Cool!
    And if you use an 18F part with PBP2.5 or greater you can do 32 bit math.
    http://www.melabs.com/resources/articles/longs.pdf
    Mar 2008
    Default Re: How do I use 10 bit A/D on 8 bit Pic? 12F675
    Can anyone tell me what I am doing wrong? This code just returns " 0 0 " with 3 volts on gpio.0
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    CMCON = 7
    ANSEL = %00000001
    ADCON0.7 = 1
    TRISIO = %00000001
    adval var word
    ADH var word
    ADL var word
    over:
    Serout2 5,16488,[#adval.HighByte," ",#adval.LowByte,13]
    goto over
    Mar 2008
    I got it fixed it was a hardware issue. Thank you!
  1. Serout problem
    Last Post: - 25th February 2007, 13:33
  2. Need help with 16f819 10 bit ADC
    By bannrikae in forum mel PIC BASIC Pro
    Last Post: - 26th September 2005, 15:20
  3. Need clever way to convert 10 bits to 8 bits
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2005, 15:13
  4. Serial Pic to Pic using HSER
    Last Post: - 11th March 2005, 23:14
  5. 8 Bit output
    By barkerben in forum General
    Last Post: - 17th November 2004, 14:39
