PortB pins will not initialize LOW, only HIGH?
Results 1 to 3 of 3
Threaded View
    Oct 2009
    Austin, Texas
    Default PortB pins will not initialize LOW, only HIGH?
    I am trying to initialize a PIC16F819 and it will not take the PORTB pins to a LOW setting on initialization. It does PORTA just fine, and it does both TRISA and TRISB settings correctly. What is it I am missing here?
    'CODE:
    'Initialize Inputs/Outputs
    TRISA = %01110100
    TRISB = %01000000
    'Initialized Highs/Lows
    PORTA = %10000001
    PORTB = %00000000
    I have also tried to use the (PORTB.0 = 0) way, and it too does not work.
    Neither does (LOW PORTB.0).
    Never had this problem with any of the other chips I have used.
    Here is the .INC file info for MPASM......
    __CONFIG _INTRC_IO & _WDT_OFF & _PWRTE_OFF & _LVP_OFF & _MCLR_OFF & _BODEN_OFF & _DEBUG_OFF
    Last edited by ronbowalker; - 7th December 2009 at 15:44. Reason: Added Info on .INC file
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  2. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  3. Old and beyond help ?
    By DavidFMarks in forum mel PIC BASIC Pro
    Last Post: - 11th December 2008, 16:23
  4. Someone help me to simplify this
    By thrix in forum General
    Last Post: - 21st February 2004, 06:01
  5. Help wanted..
    By thrix in forum mel PIC BASIC Pro
    Last Post: - 18th February 2004, 00:44
