Need help sending a hex serial output
Results 1 to 8 of 8
    Nov 2009
    Default Need help sending a hex serial output
    HI Guys,
    I'm trying to send out a hex serial output using an array. My hex is 4 digits (ex. 0000). Here is part of my program:
    TRISA.2 = 1
    A2 VAR TRISA.2
    COM_CODE VAR Byte[16]
    I VAR Byte
    COM_CODE[0]=$0000
    Loop:
    IF A2==1 THEN
    I=0
    GOSUB Data_file
    GOTO Loop
    Data_file:
    SEROUT2 PORTB.2,19697,[COM_CODE[I]]
    I'm using a 16f88 pic and I think i can only run 8 binary lines but i need to run 16. is there a line that i can use to make it run 16? Do I need to change the com_code var line also? I really need some help
    Perth, Australia
    com_code is a byte variable, so it can only store one byte in each array segment:
    like this for example:
    COM_CODE[0]=$00
    COM_CODE[1]=$00
    COM_CODE[2]=$FF
    COM_CODE[3]=$8E
    COM_CODE[4]=$1A
    and so on...
    to send the whole array via serial use this line
    SEROUT2 PORTB.2,19697,[STR COM_CODE\16]
    (the \16 signifies that you want to send 16 bytes)
    "I think fish is nice, but then I think that rain is wet, so who am I to judge?" - Douglas Adams
    Do you want hex or ASCII hex?
    Nov 2009
    I'm pretty sure that I want to send out an ASCII hex.
    Perth, Australia
    To send ascii 0 0 0 0 you would do this:
    COM_CODE[0]="0"
    COM_CODE[1]="0"
    COM_CODE[2]="0"
    COM_CODE[3]="0"
    SEROUT2 PORTB.2,19697,[STR COM_CODE\4]
    If you want ASCII Hex then every binary number in the range 0-9 should be added to 48 because ASCII 48 is character zero.
    But what about after 9?
    Well Melanie has posted a solution while back:
    MyVar var word
    ' Variable containg 16-bit value
    ' MyVar's contents are destroyed on exit
    MyData var byte (4)
    ' Four byte Array containing ASCII HEX result
    ' MSB is in MyData(3), LSB is in MyData(0)
    CounterA var byte
    ' General Purpose Counter
    For CounterA=0 to 3
    MyData(CounterA)=MyVar&$0F
    MyData(CounterA)=MyData(CounterA)+48
    If MyData(CounterA)>57 then
    MyData(CounterA)=MyData(CounterA)+7
    MyVar=MyVar>>4
    Next CounterA
    Hope this helps,
    So instead of this...
    ...you want to send four digits of HEX...
    SEROUT2 PORTB.2,19697,[HEX4 COM_CODE[I]]
    Hi Melanie.
    Since he has an array, he needs a way to convert it before sending each array element.
    The solution of in-situ conversion I think will not help him.
    Also as kamikaze47 stated his array should be word instead of byte.
    So the example of yours code I gave is really for byte and needs some modification.
  1. Serial Output - for an ASM numb
    By scomi85 in forum Serial
    Last Post: - 1st March 2009, 10:13
  2. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  3. Serious Serial Situation Setbacks...
    By Dansdog in forum mel PIC BASIC Pro
    Last Post: - 7th February 2007, 03:46
  4. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 14:44
  5. Replies: 2
    Last Post: - 20th January 2006, 21:09
