LCD back-light on with command, but no text display on LCD
+ Reply to Thread
Results 1 to 3 of 3
    Nov 2009
    Default LCD back-light on with command, but no text display on LCD
    I have UART1 XD connected to EDE702, then EDE702 connected to LCD.
    I am able to turn on back-light with below fisrt two lines, next few lines to display text, but text not displaying on LCD, can I get some sample code or how can I debug this?. thanks for help.
    //turn on backlight
    uart_putc(1, 254);
    uart_putc(1, 253);
    //display text
    uart_putc(1, 254);
    uart_putc(1, 1);
    uart_puts(1, "HELLO WORLD");
    //2nd line on LCD
    uart_putc(1, 0xFE);
    uart_putc(1, 0xC0));
    uart_puts(1, "2ND LINE DISPLAY");
    Quote Originally Posted by tvnaidu View Post
    //turn on backlight
    uart_putc(1, 254);
    uart_putc(1, 253);
    //display text
    uart_putc(1, 254);
    uart_putc(1, 1);
    //2nd line on LCD
    uart_putc(1, 0xFE);
    You might try giving the lcd an initial delay from 1/20 to 1/4 a second to turn on before you write to it.
    Looks like you are using the wrong language for this forum. We use Michrochip PIC's here, and a language called PicBasic. Hence the name PicBasic Forum.
    There are some examples here for a few different languages:
    http://www.componentkits.com/dslibrary/EDE702.pdf
    http://www.scalerobotics.com
    Nov 2009
    Default no LCD display
    I have given initial delay for LCD to comeup. Then I issued commands like above, first Two lines to turn back-light on, then next command to set cursor, then to display text on LCD, next Three lines for second line to display.
    whatever the language is, I think this isto turn LCD on I believe.
  1. LCD Display
    By lambert in forum mel PIC BASIC Pro
    Last Post: - 16th January 2010, 23:18
  2. assembly in Pic
    By lerameur in forum Off Topic
    Last Post: - 1st May 2008, 21:06
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 08:35
  5. A/D display result on LCD
    By winsthon in forum mel PIC BASIC Pro
    Last Post: - 10th January 2004, 11:09
