Oh I clapped my hands when I found this, thought i had got a working example of hserout...
didnt work for me.........
I changed it a little as I like to run at OSC 48 etc, and dont use a boot loader, and didnt need hserin, so just did a hserout and a 1 second pause to see if i could receive at the PC end, but I get the wrong chars, usually =_Y=_Y etc repeated
' Baudrate : 9600 Bauds
' Method : Polling USART interrupts flags
' Pic Definition
' Using PIC 18F2550 @ 48 MHZ '
DEFINE OSC 48
clear
ADCON1 = %00001111
' Hardware configuration
TRISC = %10000000 ' PORTC.7 is the RX input
' PORTC.6 is the TX output
' Serial communication definition
' Using internal USART and MAX232 to interface to PC
DEFINE HSER_RCSTA 90h ' enable serial port,
' enable continuous receive
DEFINE HSER_TXSTA 20h ' enable transmit,
' BRGH=1
DEFINE HSER_BAUD 9600
DEFINE HSER_CLROERR 1 ' automatic clear overrun error
' Alias definition
RCIF VAR PIR1.5 ' Receive interrupt flag (1=full , 0=empty)
TXIF VAR PIR1.4 ' Transmit interrupt flag (1=empty, 0=full)
' Variable definition
SerialData var byte
' Hardware initialisation
pause 10 ' safe start-up delay
toggle portb.0
hserout [65,10,13] ' send it
Also portC.1 goes high ?
led flashes 1 second on and 1 second off so i'd say cpudiv etc is right.
Have i done anything obviously wrong?
